D L X
What's Wrong With This Shot?
Sun Apr 16, 2006 12:24 am
I'm a little baffled by this rejection. Would you guys mind giving me your critiques? I'll let you know the official reasons it was rejected after a response or two.
http://www.airliners.net/procphotos/...5_DTW_031806_N374NB_DSC_0813_2.jpg
is my personal screening somehow off?
Damon
viv
RE: What's Wrong With This Shot?
Sun Apr 16, 2006 12:26 am
A bit soft, perhaps?
Jan Mogren
Sun Apr 16, 2006 12:38 am
Exposure?
 scratchchin
/JM
AeroPresentation - Airline DVD's filmed in High Definition
Interpaul
Sun Apr 16, 2006 1:06 am
Maybe too grainy?
Jan
D L X
Sun Apr 16, 2006 1:21 am
Now, my question is, are those guesses at why this shot was rejected, or are you fairly certain?
I just noticed that this was rejected by a screener in training, so the email says "If you have any objections please do not hesitate to use the appeal function linked to lower down." I was pretty sure this shot would get accepted, so I was obviously surprised. I hate that we have to appeal and risk lowering our acceptance rates further like this.
viv
Sun Apr 16, 2006 1:30 am
Quoting D L X (Reply 4):
Yes and no, respectively.
flyfisher1976
Sun Apr 16, 2006 1:37 am
My guess would be quality.
D L X
Sun Apr 16, 2006 1:42 am
Quoting Flyfisher1976 (Reply 6):
the catch-all rejection.
Jan Mogren
Sun Apr 16, 2006 1:52 am
Quoting D L X (Thread starter):
What reason was it?
/JM
philhyde
Sun Apr 16, 2006 1:53 am
I see problems with grain, and a little over-exposure perhaps where the sun is glaring. Quality is not peaking on this example.
However, it is not centered horizontally. So my vote is badcenter.
Phil
Canon junkie - Aviation Nut
viv
Sun Apr 16, 2006 1:58 am
You have had 10 replies.
Spill the beans!
D L X
Sun Apr 16, 2006 2:05 am
Quoting Jan Mogren (Reply 8):
What reason was it?
Quality, centering, and grain.
The reason I resisted was because I want fresh opinions, not primed ones. It's easy to say "oh yeah, there's grain" when someone told you it was rejected for grain.
I can't say I understand any of the three.
[Edited 2006-04-15 19:07:10]
philhyde
Sun Apr 16, 2006 2:19 am
Quoting D L X (Reply 11):
Do you see the grain on the right-hand-side engine and underwing (where it is shaded)? Not desireable.
Also, there is more space in the picture in front of the nose than behind the tail. Thus, the badcenter.
Given the brightness of the shot, I would guess this was not taken on a low (e.g. 50-100) ISO setting.
Hope that helps,
Phil
9VSPO
Sun Apr 16, 2006 2:34 am
Quoting Philhyde (Reply 12):
I hadn't noticed that but now you point it out it sticks out like a sore thumb. I really respect the screeners for being able to spot things like that. I guess it's easier to spot when you are "in the job".
I guess we are looking at the aircraft itself rather than everything else going on in the shot.
[Edited 2006-04-15 19:36:40]
D L X
Sun Apr 16, 2006 2:45 am
Thanks Phil for your comments.
I see the grain now, but I had to look at it from an inch away from the screen to see it. It's an unfortunate fact of DSLR shooting that there will be noise in the shadows. I shot this at ISO 200 (the lowest on a D70), and since Neat Image is the devil around here, I really don't know what the screeners want us to do.
As for centering, if this is a reason for rejecting, that's very upsetting. The distance from the front of the fuselage to the edge is 0.142, while the distance from the back of the fuselage to the edge is 0.138, according to CS2. If I centered on the end of the horizontal stab, there would be a lot of empty blue to the right, making the whole thing feel like it was leaning left. Honestly, I think a centering rejection is somewhat tacky here.
As for quality... that could be literally anything. Do you have any thoughts on particulars?
Would you like to take a stab at it? I can send you the RAW file if you like.
I know my tone sounds awfully critical in this thread, but want you to know I really do appreciate your help.  Smile
C133
Sun Apr 16, 2006 3:20 am
If you sharpen on a layer you can then gently (low opacity) erase the sharpening in shadow areas. I've found this helps a lot with minor noise/grain. Or even try the blur tool in the same places.
Terry
Fine: Tax for doing wrong. Tax: Fine for doing well.
D L X
Sun Apr 16, 2006 3:56 am
Thanks C133. I went back and did that. What do you think of the edit?
http://i39.photobucket.com/albums/e199/D_L_X/DTW%20Mar18/DTW_031806_N374NB_DSC_0813_3.jpg
philhyde
Sun Apr 16, 2006 4:21 am
Quoting D L X (Reply 14):
Centering is a common reason for rejecting, so you had better get used to it in this playground.
Big version: Width: 976 Height: 651 File size: 472kb
DLX_edit
Here is an edit showing tight cropping, which is normally preferred. I also brightened up the shadows 10%. Finally, 50% USM at 0.3 radius. This is just a quick job, and you should probably re-do the photo incorporating the technique that Terry mentioned.
Phil
9VSPO
Sun Apr 16, 2006 4:34 am
Quoting Philhyde (Reply 17):
That's too tight on the nose.  Wink
ptrjong
Sun Apr 16, 2006 4:36 am
Hi all,
Sorry Phil, but I don't like that extremely tight crop. In my opinion, the breathing space off the nose should be related to the that off the tailcone, NOT that off the tailplane which can indeed be tightly cropped.
So if Damon's original crop was badcenter at all, it only needs a slight amount of cutting on the nose side, in my opinion.
Peter
flyfisher1976
Quoting D L X (Reply 7):
Would be nice if they could clarify this rejection with more specifics...
Looks like they already did.
DLKAPA
Sun Apr 16, 2006 4:46 am
I don't think it needs any sharpening like you've just done, just very lightly lower the noise in the sky and kick the contrast. Excellent starting point I think.
D L X
Sun Apr 16, 2006 4:52 am
Quoting Ptrjong (Reply 19):
Absolutely. But it seems that the screeners don't agree, and I feel that our artistic license has been revoked in that respect.
philhyde
Sun Apr 16, 2006 5:04 am
Yes, I did cut it a bit close on the nose, eh? Anyways, this is a matter of taste to some degree, and illustrates the necessity of centering the subject. I've never had a single rejection for badcenter using this technique.
Photo © Phil Hyde
Phil
[Edited 2006-04-15 22:05:51]
ptrjong
Sun Apr 16, 2006 5:09 am
Quoting D L X (Reply 22):
Well, sometimes they do.
Photo © Peter de Jong
D L X
Sun Apr 16, 2006 5:15 am
Just got another rejection. This new screener is killing my ratio. *sigh*
PUnmuth@VIE
Quoting D L X (Reply 16):
Dirty. 1 cm from the top border. Go up a vertical line from the rear cokpit window and you are there.
Peter
ptrjong
Sun Apr 16, 2006 5:17 am
Phil, our two shots (nice antipodes) prove that, like I've said before, the screeners are usually not harsh in centering issues.
I think the centering rejection for Damon's shot is unusually harsh.
philhyde
Sun Apr 16, 2006 11:06 am
Very nice shot Peter. Based on my experience here, I'd say that screeners most often prefer tight crops. There are always exceptions, as screening is a subjective task. In the case of your shot, there are many other subjects in the field of view that balance the shot. If you asked me, without seeing it first, I probably would have advised to crop yours tight(er) as well.
So, where is there dirt above the cockpit? I don't see it. I see a small fleck above the "n" in nwa, but that could easily be cloned out.
Big version: Width: 800 Height: 543 File size: 556kb
DRX equalized
Phil
