LukasMako
Good Lens For Nikon
Tue Apr 18, 2006 9:26 pm
Hi,
I consider to spent some money for a new lens. The one I use now is a 180€ Nikkor AF-S 70-300mm. It is a solid lens but a lot of pictures are unsharp, strong lights on dark objects often appear violett when the apperture is open which forcese me to set it higher and use higher ISO in order to get good shutterspeeds.
It should be max. 500€ and Telezoom. Would be nice if it goes from 100mm up to 400mm.
Can you give me any recommendations. The camera is D50.
NIKV69
RE: Good Lens For Nikon
Tue Apr 18, 2006 9:36 pm
I'll let Royal handle this one, but you better raise your budget a bit! (biggrin)
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
viv
Tue Apr 18, 2006 9:52 pm
At that price, (new) Nikkor lenses will be out of reach.
Have a look at used Nikkor, or new Sigma.
[Edited 2006-04-18 15:00:32]
LukasMako
That is not possible for a student like I am...
edoca
Tue Apr 18, 2006 10:24 pm
Well, I don't know if you travel to the US or know someone who does, but at the current EUR-USD exchange rate you could buy the splendid $800 Nikkor 80-200 F/2.8 and only pay around EUR 675. Still a bit over EUR 500, but definitely worthwile! You could buy one online of course but shipping (and duties potentially) might ruin the cheap price... You can try finding this one second-hand in Europe as well of course, but I assume you want a new one really.
It seems like you are looking for very high quality, so that is what I would recommend. With a max aperture of 2.8 throughout you could later on add a TC without losing too much light.
ptrjong
Tue Apr 18, 2006 11:07 pm
Quoting Edoca (Reply 4):
 checkmark
In a reliable store you can find a really good used one, as people buy hot new VR lenses.
Peter
clickhappy
Tue Apr 18, 2006 11:09 pm
Yes I think a 80-200 f/2.8 would be a good option.
NIKV69
Tue Apr 18, 2006 11:25 pm
Quoting Clickhappy (Reply 6):
Def, $800US and a teleconverter should do the trick.
LukasMako
Wed Apr 19, 2006 12:13 am
Hi,
Thanks for your help. The lowest price for that lens in the german speaking region (Swiss, Austria, Germany) is more than 1100€. More than twice I can afford and without TC 200mm in LOWW is not really optimal.
Of course I will consider buying used. But it is still a bit hard to get optimal lenses which optimaly fit Digital Photography.
What about Tamron and Sigma. Is there such a differenc to Nikkor lenses?
JRadier
Wed Apr 19, 2006 12:18 am
Allthough I'm not a Nikon shooter (Canon here) I can still recommend the 50-500 from sigma. Allthough it's not the greatest in less then optimal weather it's still usable, and it's a super lens in sunny weather. Range and price are good as well!
edoca
Wed Apr 19, 2006 12:37 am
Quoting LukasMako (Reply 8):
That's $1320 for something worth $800 (in USD)... Terrible. I would never ever buy any photo equipment in Europe any more...
Quoting JRadier (Reply 9):
I have seen similar reports, this might be a better option then for you, haven't used it though. But I just wonder if it is going to be significantly better than your current Nikkor 70-300.
I also have an old Nikkor 75-300, predecessor to your 70-300, which is optically better according to some reviews. But of course it's bigger and heavier and not different on paper... I used it quite often before switching to the 80-200 /2.8. Let me know if you want more info on that 75-300 though.
LukasMako
Wed Apr 19, 2006 12:44 am
There would be other options in my mind.
The 70-300mm is also sold in ED version for under 400€ (do you think that brings a significant advantage?)
And Sigma has also a 70-200mm 2.8 EX DG. That is 800€. Can you tell me why the Nikkor which is pretty much the same costs that much more? Just becaus its a Nikon?
And what about the TC: Nikon's TC are in the 500€ range while some of Tamron and Sigma are way less. Why?
mikephotos
Wed Apr 19, 2006 12:56 am
Quoting LukasMako (Reply 11):
Quality! and yes, because it's a Nikkor/Nikon. I've owned a Sigma 70-200/2.8 and while it's a great lens I do find the Nikon to be better (IMO) in build and quality. However, I don't think you'll go wrong if you end up with the Sigma, it's not a bad lens at all.
Same as above.
Mike
edoca
Wed Apr 19, 2006 1:00 am
An opinion I trust in these matters is www.kenrockwell.com
Have a look, you'll probably find the info you're looking for over there. I know Mr Rockwell may have some controversial views to some, but I find his reviews very informative usually.
LukasMako
Wed Apr 19, 2006 1:17 am
Well,
This statement is completly wrong after my experience:
I would really like to have more ISO settings on my D50.
ISO: I use 200. If the light gets dim and my images would get blurry from slower shutter speeds I increase the ISO to 400, 800 or 1,600. I never bother with in-between settings like 250 or 640. The D70 looks fine at ISO 1,600 if you need it. I'd much rather have a slightly grainy but sharp image than a less grainy but blurry one. Unlike film, the D70 looks great at high ISOs, so I use them anytime I need them.
About the TC:
All Nikon TC cost about 500€ while the Sigma only costs 150-200€. I simply cannot imagine why the Nikkon costs 2-3 times more just because it isbetter in quality.
And BTW: what does "quality" in photography refer to? Is it performance or simply well made and it can take rough conditions like water, heat, cold. etc. ...
JRadier
Wed Apr 19, 2006 2:13 am
Quoting Edoca (Reply 13):
Another source is www.fredmiranda.com wich has user reviews.
Quoting Edoca (Reply 10):
If you make sure you get a good one it is significantly better then a 70-300. And I agree, it isn't a prime, but for the price and range it is far ahead of the competition.
But I would suggest trying out some lenses, preferebly at the airport. So perhaps a meetup with some other photographers?
LukasMako
Wed Apr 19, 2006 4:25 am
Do I lose the AF when using a TC?
mikephotos
Wed Apr 19, 2006 4:30 am
Quoting LukasMako (Reply 14):
When referring to lenses it could be both but I guess lens/glass quality (sharpness, color, etc.) would be more important. But usually the more expensive "quality" glass usually comes in a "quality" build as well.
Quoting LukasMako (Reply 16):
What lens were you referring to? If the 80-200/f2.8 or 70-200/f2.8, no.
Mike
LukasMako
Wed Apr 19, 2006 3:40 pm
Hi,
What about the new VR version of the 70-200 2.8. Is the price difference worth the VR funtion. And does it make sens to buy such a Lens for a D50?
viv
Wed Apr 19, 2006 3:51 pm
Any lens that designed for a film SLR and the fits your digital SLR will give full coverage of the sensor.
There is a difference in quality, but the best SIGMA are close to Nikkor.
Nikon's TCs are far superior.
Not with a Nikon TC.
Quoting LukasMako (Reply 18):
Yes and yes.
Bottom line: You get what you pay for.
OlegShv
Thu Apr 20, 2006 1:15 am
I use the ED version that you talk about. I noticed that it handles CA better than the less expensive G version. I have never used 80-200 f/2.8. However, from the sample pictures and reviews I've read and on various websites, 70-300 ED is not up to par in terms of sharpness with 80-200 f/2.8. I'm saving money myself for that one. Also a student here  Smile
70-300 ED is OK, I managed to get a couple shots with it into DB, and I think I have a bunch more that are of reasonable quality to be accepted here. As Viv mentioned above, you get what you pay for.
Also, I heard rumors about the upcoming 70-300 ED VR version due sometime this year. I can't afford 80-200f/2.8 +TC right now, so while I save money, they might release that one and I think I would be tempted to try this one out.
Oleg.
mikephotos
Thu Apr 20, 2006 1:18 am
Quoting OlegShv (Reply 20):
I have used both the 70-300 ED and 80-200/f2.8 and can confirm the above. The 70-300ED can produce some very nice results but it's just not as consistent as the 80-200.
Mike
LukasMako
Thu Apr 20, 2006 2:49 am
Hi,
Thanks for your comments.
Just would wonder if a VR 5,6 is superior to a normal 2,8.
I just would like to have a lens which I also can under low light circumstances and also for motion blurs. Just wonder how a VR exactly works. Can you give me some data ...
OlegShv
Thu Apr 20, 2006 5:25 am
From what I understand, VR is useful for shooting static subjects under low light. It essentially allows you to use slow shutter speeds, like 1/10-1/20 sec. Those who have VR lenses may tell you how slow can you go to get a decent shot. If you want to freeze motion in low light, then f/2.8 is your best friend since wide aperture allows more light, which, in turn, results in faster shutter speeds.
Hope that helps,
Oleg.
