aviationwiz
Help With Photo - Grainy
Tue Apr 25, 2006 6:15 am
Now, like so many others here, I've had *EVERY* photo I've ever
submitted rejected. Like so many other people, I just get right back
up and try again, which I've done, time and time again. Here's the
photo in question:
http://www.aviationwiz.net/photo/saa_winglet.jpg
Can anyone help me with that one? I'm at a loss. I've had other people
look at it and they say it's one of the best shots they have seen.
It was rejected for:
"There is too much grain or digital noise in these photo(s). All scans
contain a certain amount of grain, and all images from digital cameras
contain a certain amount of digital noise, but these amounts should be
kept at acceptable values."
Proudly from the Home of the Red Tail.
diezel
RE: Help With Photo - Grainy
Tue Apr 25, 2006 6:39 am
Hi,
Try uploading the image with a width of 1024 instead of 1600. Also the color is a bit off and there are a couple of tiny white dots. In the upper left and right corner there is some vignetting (?) visible. But I do like it!
I did a quick edit to make the colors look more natural (Actually this is the perfect picture to get the colors right as there is white, grey and black in the picture) and got rid of most of the noise by reducing the size. Hope you like it.
Big version: Width: 1024 Height: 776 File size: 369kb
Roel.
Never be afraid of what you like. (Miles Davis)
JRadier
Tue Apr 25, 2006 7:13 am
Roel, to me the colour on your pic is far too warm (while in Avi's it's right.) I recon it has to do with monitor temperature (9300K here)
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
aviationwiz
Sun May 07, 2006 1:39 pm
I got some help from D L X, and reuploaded it, and it got rejected for "quality". That's it, nothing else mentioned. Any ideas? To say this is getting frustrating would be the understatement of the year!
http://aviationwiz.net/photo/anet/20060507_AviSAA.jpg
777MechSys
Sun May 07, 2006 1:48 pm
I am no expert by any means. I am still learning. I barely know which end of the camera to look through.
On the second shot I see alot of JPEG compression artifacting (I believe that is what it is called) along the leading and trailing edge. Possibly a tad over sharpened. The grain is gone  Smile and replaced with other issues  Wow!.
I'm not sure how to fix but that is the problems I see.
-Erick
777MechSys
Sun May 07, 2006 1:51 pm
Sorry for the double post... I just upgraded Opera and apparently there are issues with it and a.net
-erick
[Edited 2006-05-07 06:53:31]
JeffM
Sun May 07, 2006 1:58 pm
Quoting Aviationwiz (Reply 3):
Did you do the editing, or did DLX?
D L X
Sun May 07, 2006 5:41 pm
I gave him an edit, and showed him what I did. I said that if he wanted to, he could use my edit, without credit.
flyfisher1976
Sun May 07, 2006 10:50 pm
I like this shot a lot. The first edit really had an over-processed appearance to it. The secong shot still looks a bit over-processed or compressed. What workflow are you using?
JD
aviationwiz
Mon May 08, 2006 2:28 am
I use a combination of Apple iPhoto and Adobe Photoshop.
-Avi
Psych
Mon May 08, 2006 5:16 am
Hi Avi.
I must say that the subject lends itself to a photograph, with all those vibrant colours on the winglet against the lovely blue sky.
I have a couple of thoughts - though I am somewhat biased in favour of the more traditional 3:2 aspect ratio, I think it would be better suited to this image, as there is quite a lot of 'dead' sky at the top of the image that doesn't really add anything. I think that could be cropped out and it would benefit the image.
I have to agree with Erick that there is quite a lot of compression noticeable in the second shot. The suggestion to upload at the smaller size was definitely correct, but I wonder whether the quality problems are inherent in the original file. Were you using a non-DSLR camera? It seems to me that it is increasingly difficult to get over the quality hurdle these days with non-DSLR equipment, and one of the key factors in the quality is the graininess of the image and that compression. Also I think the more the camera does to the image at the time of shooting - i.e. saturating colour, adding sharpening etc - the worse the outcome for those trying to upload here. If you can switch that off do so - and deal with things in post-processing, where you have more control.
If you feel I may be able to help with the image just let me know.
Paul
flyfisher1976
Mon May 08, 2006 11:13 am
Quoting Flyfisher1976 (Reply 8):
Quoting Aviationwiz (Reply 9):
My question was not pertaining to what software, but which workflow you are using. Your results seem to be inconsistent and over-processed. A workflow is important because it helps you to achieve predictable consistent results every time you edit a photo. Check out Fergul's workflow on the photo upload page.
ANITIX87
Mon May 08, 2006 12:49 pm
I tried using iPhoto for my first few edit attempts and found it completely useless. There is a great workflow for Photoshop available on this site in the photo upload page created by A.Netter Fergul. (As a PDF file). I've used it and it works quite well once you get the hang of it, because it leaves quite a bit open to interpretation (which is good, so that you can be creative).
TIS
aviationwiz
Tue May 09, 2006 10:22 am
Quoting Psych (Reply 10):
Yeah, I took that on a Canon PowerShot G5, before I got my Rebel XT.
Quoting Flyfisher1976 (Reply 11):
Quoting ANITIX87 (Reply 12):
Thanks! I checked it out, and used that with the recommendations I've received in this thread, and here's what I've got:
http://aviationwiz.net/photo/anet/AviSAA-3.jpg
How's it look now?
aviationwiz
Mon May 22, 2006 1:47 pm
Here it is, my first acceptance:
Photo © Avi Goldstein
Thanks all! I was so happy today when I got the acceptance email, been getting a lot of congratulations emails from friends,  Smile
Users browsing this forum: No registered users and 9 guests
