senorcarnival
Should I Upload These Or Let It Go?
Thu Apr 27, 2006 9:49 pm
You know how sometimes you have a picture you really like but you're not sure it's quite up to a.net standards? Well, welcome to yet another one of such threads. All these photos were roughly edited just to have a slight idea of what it would look like and if it can be improved. Photo 1:
http://www.pbase.com/senorcarnival/image/59281540
I like the late afternoon sunlight on it, but I think the fact the tail is somewhat cut off (even on the original, I know, my fault...) would get the dreaded motive boot.
Photo 2:
Big version: Width: 768 Height: 1024 File size: 769kb
Are extreme nose close-ups acceptable if the pilots aren't waving or any of that? Also, is that white speck under the cockpit a hot pixel or just a plane showing signs of age? I wasn't sure if I should clone it out or not.
Photo 3:
Big version: Width: 1000 Height: 750 File size: 733kb
Another sort of close-up. Would it be correct to say that the reflections (especially near the U.S. flag and on the landing gear "door") on the plane would botch this shot?
Thanks for any help.
Oh no, she's getting impatient! Take a stab at it!
viv
RE: Should I Upload These Or Let It Go?
Thu Apr 27, 2006 9:57 pm
I think No. 2 would have the best chance.
ZSOFN
Thu Apr 27, 2006 10:34 pm
Image 1
I presume you've compressed the first image on that site? You'll need to start again with it. Nevertheless you'll probably get a badmotive rejection there.
Image 2
Nice, but the shot's not level - it needs some CCW rotation. Also there are some serious quality issues with the background. Did you use NeatImage?
Image 3
Looks good, perhaps a little too much noise though. The main issue is with the centering - it's much too low in the frame.
senorcarnival
Fri Apr 28, 2006 4:29 am
Quoting ZSOFN (Reply 2):
I applied some post processing to it and resized it to 1024 X 768, just like I would if uploading to a.net.
No, however, I applied USM to the whole picture b/c I didn't feel like taking the time to apply it only to the plane and get feedback saying it's no good.
Looks noisy probably because I used the same strategy as above.
bubbles
Screener
Fri Apr 28, 2006 4:36 am
Hi,
I do not know if image No 3 has the centering problem, as I feel it is not balanced vertically.
_Hongyin_
ZSOFN
Fri Apr 28, 2006 4:47 am
Quoting Senorcarnival (Reply 3):
In that case, make sure you're saving in best quality jpeg format as there's an unacceptable level of jpeg compression for this site.
I'd recommend you take the time to do so  Wink I can understand you not having done so thus far as you mentioned in your first post that you want to see whether it's worth working on them properly.
You're showing some promise with your shots but post-processing takes practise and involves constant learning, not to mention a lot of time if you want to get the very best out of your image.
glennstewart
Fri Apr 28, 2006 1:07 pm
Very quick review:
1.
JPEG COMPRESSION: The JPEG compression is high - try to have the size non compressed but below 1MB
MOTIVE
2. Motive, size
3. Centre, size
Why are you cropping square? This is immediately noticible!
Please try to maintain the ratio of the original shot where possible.
Glenn
Respected users.... If my replies are useful, then by all means...
senorcarnival
Fri Apr 28, 2006 1:56 pm
Quoting Glennstewart (Reply 6):
2. Motive, size
I had to use a 3:4 crop ratio because I couldn't crop it on a 2:3 (or 3:2 for that matter) without cutting something out, like part of the landing gear. What is wrong with the motive? Mind you, I'm not disputing your opinion, I just want to gain insight as to what you feel is bad about the motive. What about size? Is it just the square thing?
3. Centre, size
I can indeed get better centering on a 3:2 ratio, this would make the fuselage centered but the furthest away engine still sits low in the frame. If the fuselage is centered, would it correct the centering part?
I know you have some photos to screen, so thanks a lot for taking your time to help me out.
glennstewart
Fri Apr 28, 2006 4:49 pm
Quoting Senorcarnival (Reply 7):
I guess in this particular example, size and motive go hand in hand.
In the reply above you've explained the motive behind the size.
The size rejection takes into account both size and ratio:
SIZE Rejection reason
The size of your photo(s) was too small or they had a very unusual width/height ratio.
See also: Clarification Of Minimum Photo Dimension (by PUnmuth@VIE Apr 20 2005 in Aviation Photography)
I suggest when taking the photo initially, think about centering. If you want to prepare for some flexibility with editing, you can also decrease your zoom while taking the shot.
Some might say to just clone some extra sky in, but that is a big no-no and could also lead to rejection.
EDITING Rejection reason
Deliberate attempts to alter the image, i.e. by digitally removing or adding objects, or by purposely changing certains items in the image.
For reference motive can be easily explained with:
MOTIVE Rejection reason
Your photo(s) showed a motive that is not accepted by Airliners.net. This problem may be due to a very wide range of reasons.
Some examples are:
...Photos showing just a part of an aircraft (with no motivation for doing so...
Not a problem! I'm glad to be of assistance.
Glenn
Users browsing this forum: No registered users and 4 guests
