airbusA346
Rejection - Help
Fri Apr 28, 2006 5:27 am
Can you please tell me where this image is soft and why was it rejected for category.
The category was 'NOSE'
http://www.airliners.net/addphotos/rejections/big/20060427_Martinair-038TW.jpg
http://www.airliners.net/addphotos/r...s/big/20060427_Martinair-038TW.jpg
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
ZSOFN
RE: Rejection - Help
Fri Apr 28, 2006 5:36 am
Try adding a little USM; it doesn't look to me like you'd do any "damage" in doing so.
In terms of category, it's not really a "nose" shot  Wink
JeffM
Fri Apr 28, 2006 5:37 am
It can't be "nose" when the entire aircraft is visible. Check the help section on that, it describes it well. I can't comment on the soft part as I'm sitting in traffic at the moment using my laptop.
9VSPO
Fri Apr 28, 2006 5:52 am
I'd say the fuselage was over-exposed more than anything!
bubbles
Crew
Fri Apr 28, 2006 5:57 am
Quoting JeffM (Reply 2):
 checkmark
_Hongyin_
sulman
Fri Apr 28, 2006 6:08 am
Is it you causing the traffic jam?  Smile
glennstewart
Fri Apr 28, 2006 12:41 pm
Quoting AirbusA346 (Thread starter):
Just to reiterate, this would be an INFO rejection in addition to anything else. NOSE is only for use when it's a shot purely of the nose.
Glenn
Respected users.... If my replies are useful, then by all means...
glennstewart
Fri Apr 28, 2006 12:45 pm
Very quickly looked at the shot more carefully. I'm reviewing on my work LCD (which isn't adequate for actual screening)... but note the following:
1. Contrast - too much
2. Angle - ever so slightly an amount CW (maybe 0.25 degrees).
As for soft... I think this might be due to the contrast. Sometimes over contrasting can take out detail. I may or may not have rejected it for soft. As I noted, I am reviewing on my work LCD and I might note soft when at home.
Glenn
QANTAS077
Fri Apr 28, 2006 12:56 pm
Quoting Glennstewart (Reply 7):
don't go their mate...your gonna get a mouthful if your talking about a bees diaphram in angle!  Wink
glennstewart
Fri Apr 28, 2006 4:37 pm
Quoting QANTAS077 (Reply 8):
Bugger.... I just realised that it's my work chair. It's off kilter by 0.25 degree CCW :P
QANTAS077
Fri Apr 28, 2006 7:25 pm
Quoting Glennstewart (Reply 9):
bit like the exposure on your 30d  Wink
