Dahlgardo
Rusty Editing Skills
Mon May 08, 2006 9:41 pm
Hi all
I'm beginning to find time for some uploading again, but with the ever increasing standards on a.net I would love some feedback on the shots I currently have queued. This is just to make sure I'm not wasting my time.
http://www.airliners.net/addphotos/big/ready/hl7601-02102004-lax.jpg
Does the sticker on the side justify "hybrid" selection ?
http://www.airliners.net/addphotos/big/ready/cgaus1-06102004-mhv.jpg
Is quality OK ?
http://www.airliners.net/addphotos/big/ready/vhean1-09102004-vcv.jpg
Quality, motive ?
Thanks for any help.
/Jakob
leave your nines at home and bring your skills to the battle
Knighty
RE: Rusty Editing Skills
Mon May 08, 2006 10:16 pm
Not sure about what category the first one falls into, the last 2 look a little heat hazed to me. Just out of interest, in the 3rd shot is the aircraft closest to camera VH-EAN?
Knighty
Ian Knight - Proud Canon shooter!
Sinkrate
Mon May 08, 2006 10:31 pm
Quoting Knighty (Reply 1):
Knighty, it looks like it to me. Thats also what the file name says. smile
Michael
Kukkudrill
Tue May 09, 2006 12:49 am
No. 1: Not sure about the category either, but I can't help feeling that the rear fuselage does not look as sharp as the front. I would try a little selective sharpening.
No. 2: Either heat distortion as Knighty says, or else (just possibly) artifacts introduced as a result of resizing in one step -- something that has happened to me in the past. I'm referring in particular to the apparent unevenness of the vertical stabiliser leading and trailing edges.
No. 3: I don't see any heat distortion on this one. I think the tape on the aircraft was simply applied unevenly. I would recrop to get the aircraft more vertically centred, but other than this I like the motive.
Charles
Make the most of the available light ... a lesson of photography that applies to life
Dahlgardo
Tue May 09, 2006 1:14 am
It certainly is. VH-EAO is behind it.
Quoting Kukkudrill (Reply 3):
The blurryness is possibly caused by the jet blast. I'll see if I can improve it.
I thought re-sizing in one step was the best thing to do, to minimize loss of data ?
Thanks for your help
/Jakob
Kukkudrill
Tue May 09, 2006 1:22 am
Quoting Dahlgardo (Reply 4):
Exactly what I used to think, until I went from 3.2 to 8 megapixels and I started getting stepped diagonals. These days I resize in stages of around 400 pixels at a time.
Charles
Stealthz
Tue May 09, 2006 9:55 am
Quoting Kukkudrill (Reply 5):
What do you use to edit/resize you photos?
Using PSCS and before that PS7 I crop to a 3:2 or 4:3 aspect ratio image at orig resolution. If I have framed properly at shooting stage that will give me an image 2,200 to 3000px wide, then I do all the editing steps(leveled prior to crop if needed). I then resize to 1024 or 1200 wide in one step and save as Max jpg. I don't have the jaggie issue you speak of.
Chris
Kukkudrill
Wed May 10, 2006 1:33 am
Quoting StealthZ (Reply 6):
Chris,
I use Photoshop Elements 2.0. I follow pretty much the same workflow as you do, except that I sharpen after resizing as the very last step.
After I got my 350D I had a couple of photos rejected due to jaggies in areas where I had deliberately refrained from sharpening altogether. The effect was more one of steps rather than the normal sawtooth jaggies, a bit like the cheatline in this older photo (taken with a 4mp camera)
Photo © Charles Polidano
but much more pronounced. Then I read that some people resized in stages, and now that I've started to do the same I haven't had the problem again. Maybe my version of Elements can't handle a lot of resizing at one go?
Charles
eadster
Wed May 10, 2006 7:51 am
The shots of the 767's should be ok.
Korean is soft and I don't think the quality is there with that shot. If it could be improved and accepted - I would put into special category, but if that marking is on other aircaft, I'd place into Hybrid.
That's my take on things.
Dahlgardo
Fri May 12, 2006 4:20 am
Quoting Eadster (Reply 8):
Thanks for your input. I'll pull the KE 747 from the queue and see if I can re-work it.
/Jakob
Users browsing this forum: withak and 1 guest
