pavvyben
First Picture - Will It Get Accepted?
Tue May 09, 2006 10:48 am
Hello all,
Just wondering whether you think this will get accepeted as my first shot into the db  Smile
http://www.airliners.net/addphotos/big/ready/DSC_7227.JPG
Ben
Fly747
RE: First Picture - Will It Get Accepted?
Tue May 09, 2006 10:52 am
My guess would be no. It is too low in the frame, a bit too sharp which causes jaggies and the sky is grainy as well.
Ivan
agd
Tue May 09, 2006 11:00 am
Hello Ben,
I like the motive behind those kind of shots.
However, as Ivan wrote, it seems low in the frame and some jaggies can clearly be seen. Plus, IMO, I don't like the lower part of the engine being cut off, probably due to the crop you did. Finally I don't think the size of the picture is appropriate for A.net (not wide enough).
That said, I personally don't think it is "that bad". Keep shooting!
Alex
NO URLS in signature
waketurbulence
Tue May 09, 2006 11:02 am
It is close in terms of overall quality, but could use some tweaking as Ivan has said. Re-crop it higher into the frame, sharpen a bit less, and if you know how to make a duplicate layer, you can erase jaggies after you sharpen too much. Also before sharpening use the magic wand and select the entire sky, then invert the selection so you can sharpen only the aircraft. Grain becomes more visible as you sharpen, and the sky does not need to be sharpened at all. Also you should make a unique file name on what you save. Good luck.
-Matt
[Edited 2006-05-09 04:05:46]
vasanthd
Tue May 09, 2006 11:18 am
And ofcourse... do remember to change your filename to something unique to ya...
Vas
One Lucky shot deserves another!
