dcrusafon
How To Center The Plane?
Fri May 12, 2006 7:04 pm
Hello,
I have this picture and honestly I don't know if it is properly centered.
http://www.airliners.net/addphotos/big/ready/DSC_5373SXBEM10APR06LHR.jpg
If I center the A300 then I cut the A340 that is behind...So what do you recommend?
DARIO
[Edited 2006-05-12 12:09:25]
dc10tim
RE: How To Center The Plane?
Fri May 12, 2006 7:14 pm
Hi Dario,
That's a nice shot. Definitely don't crop the nose of the AC A340. The A300 could be cropped a little more on the right and I'd also lose some of the foreground, cropping the aircraft a little lower in the frame.
I wouldn't worry too much about the A300 not being centred as it's obvious what the motive of the shot is.
Just my thoughts.
Tim.
Obviously missing something....
walter2222
Fri May 12, 2006 7:23 pm
Quoting Dcrusafon (Thread starter):
Hi Dario,
I would crop closer to the tail of the Olympic and leave equal space between the tail as there is before the nose of the Air Canada.
For the vertical centering, I would (but that's purely my personal view) put them slightly lower (just a little bit) in the frame (now, it's just the fuselage that is centered and not the full aircraft, including tail). It will look more balanced.
PS: I think it can also use somewhat extra sharpening.
Good luck,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
dendrobatid
Fri May 12, 2006 7:27 pm
Quoting DC10Tim (Reply 1):
Totally agree and I find that a comment to the screener often helps to show that you know, have considered the rules and explain why you have broken them.
Quoting Walter2222 (Reply 2):
I agree
Mick Bajcar
ZSOFN
Fri May 12, 2006 7:34 pm
I would say actually it would be best to centre it vertically by having the centre of the photo running along the top of the Olympic fuselage.
beechcraft
Fri May 12, 2006 10:15 pm
Dario,
as already said before, kill the dead space on the right and put them just a bit lower in the frame.
Quoting Dendrobatid (Reply 3):
Absolutely, leave a short note about why you did what.
Nice shot,
Denis
That's it! You people have stood in my way long enough. I'm going to clown college!
mygind66
Sat May 13, 2006 1:40 am
Hi Dario....
What are you doing so far from home?
About to center the a/c, I'd say to balance the photo. All that green makes the gap larger than it is...
Take care
Salu2
Enrique
dcrusafon
Sun May 14, 2006 7:13 pm
Thanks for your comments... I will edit the picture and summit.
DARIO
dendrobatid
Sun May 14, 2006 7:33 pm
Quoting Dcrusafon (Reply 7):
Dario,
When you re-edit, beware, the image has a magenta cast too....the sky is pinkish.
Correct that by adding some green and the grass will be greener too.
Mick Bajcar
dcrusafon
Mon May 15, 2006 8:28 pm
Mick,
Thanks for the comment. I have resummit the picture according to your comment too.
Hope it is fine  Smile
http://www.airliners.net/addphotos/big/ready/DSC_5373SXBEM10APR06LHR3.jpg
Brgrds,
DARIO
dcrusafon
Fri May 26, 2006 4:03 am
The picture has been accepted Big grin
Photo © Dario Crusafon - Iberian Spotters
Thanks for helping me  Smile
Brgrds from Spain,
DARIO
Users browsing this forum: Bing [Bot] and 24 guests
