andersosl
Will These Make It?
Fri May 12, 2006 10:07 pm
Hi,
I've edited some photos taken in March.
Since I'm rather new, I would appreciate your help finding possible reject reasons.
Here are the shots:
1#
http://home.no.net/ssaero/anet/IMG_6672%20copy.jpg
2#
http://home.no.net/ssaero/anet/IMG_6775%20copy.jpg
9VSPO
RE: Will These Make It?
Fri May 12, 2006 10:12 pm
Both photo's seem to have some sort of 'pinkish' colour cast on them unless it's my eyes.
[Edited 2006-05-12 15:13:54]
linco22
Fri May 12, 2006 10:13 pm
Andersosl,
Both very nice images. On my works monitor they both look a little soft. Apart from that they are very nice images!
Colin  Smile
viv
Fri May 12, 2006 10:15 pm
The first one is backlit - a pity.
The second one is soft.
andersosl
Fri May 12, 2006 10:18 pm
Thanks !
I will try to fix the softness if it's possible.
BTW, what is your unsharp mask-settings?
NIKV69
Fri May 12, 2006 10:23 pm
Poor lighting on the first. Both are soft. Second is a nice shot I would do a re-edit on the second one.
The Juice is loose and he is in Vegas!
viv
Fri May 12, 2006 10:28 pm
Quoting Andersosl (Reply 4):
It depends on the shot. There is no hard and fast rule.
A couple of suggestions:
Sharpen just the aircraft, not the whole image. Do a first sharpening at 0.2, 0, 500, then experiment with 0.3, 0, xxx.
VIAF
Sat May 13, 2006 2:24 am
How to sharp just the aircraft ?
[Edited 2006-05-12 19:25:57]
9VSPO
Sat May 13, 2006 2:28 am
Quoting VIAF (Reply 7):
Some Excellent Tutorials (by 9VSPO May 10 2006 in Aviation Photography)
VIAF
Sat May 13, 2006 2:32 am
Thanks Ian !!
VIAF
andersosl
Sat May 13, 2006 4:55 am
Ok, I have sharpened the pic once more. Is it any better?
Is it oversharped?
http://home.no.net/ssaero/anet/koreanaircargo2.jpg
fuffla
Sun May 14, 2006 3:49 pm
It looks better. However, it looks oversharpened, this is evident by the pixilated registration and winglets. I think everything else is fine. I am not sure how you would fix that though.
walter2222
Sun May 14, 2006 6:08 pm
Quoting Andersosl (Reply 10):
Is it any better?
Hi, I would also change the cropping if your original allows (I would put the aircraft slightly higher in the frame to give it a more balanced look: centering the fuselage would be too much because there is also the tail section to take into account).
It is a nice picture, but to me also the snow (although it is nature  Smile ) in the right lower corner distracts a bit from the subject, so if possible - if the original allows - I would try to see wheter a crop closer to the tail section would not give better focus on the subject... just my thought...
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
