malandan
Reasons For Rejections.
Wed May 17, 2006 3:53 am
I thought this image to be a little different but the screeners rejected it for quality.
Would someone care to point out to me where I've gone wrong?
http://www.airliners.net/procphotos/...stang_G-CDHI_Bre_Apr_22_2006bN.jpg
On perhaps a lighter note, this one was rejected for "quality people grainy" - when I get it wrong .................. !
http://www.airliners.net/procphotos/...ns_RV-4_G-VANS_Bre_Apr_22_06aN.jpg
Quality - yes OK!
Grainy - well a bit!
But people - surely that's a plaster bust unless my eyes deceive me!
Ah well!
Malcolm.
My interest lies in the future as I am going to spend the rest of my life there!
codeshare
RE: Reasons For Rejections.
Wed May 17, 2006 3:58 am
(IMHO)
1) Look at the gear: it is overexposed and soft. The left part of the photo is generally out-of-focus- a little bit.
2) People? I can't see anything here.
Hmm soft at the sides? I think
Keep trying  Smile
KS/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
cosec59
Wed May 17, 2006 4:12 am
Quoting Codeshare (Reply 1):
There's a dummy just behind the rear of the cockpit  stirthepot
Rules are for the obedience of fools but for the guidance of wise men
glennstewart
Wed May 17, 2006 4:59 pm
Too much saturation in both of these. The second is slightly soft or has a DOF problem happening. A lot of purple fringing that you might not be able to avoid (unless the lens was changed).
What camera are you using?
Glenn
Respected users.... If my replies are useful, then by all means...
viv
Wed May 17, 2006 5:30 pm
Di you use a flash for the Mustang shot? The foreground is over-exposed and a lot of detail has been lost as a result.
malandan
Thu May 18, 2006 7:15 pm
Quoting Glennstewart (Reply 3):
Canon EOS 20D with 17-85mm IS lens.
Quoting Viv (Reply 4):
From the EXIF - no flash.
Tv( Shutter Speed ) 1/100
Av( Aperture Value ) 7.1
ISO Speed 400
I would guess that the effect you refer to results from the bright sunlight entering the front of the hanger and the darkness of the rear.
Not sure what the answer is as a reduction in aperature (f8+) and reduction in ISO would result in an unaccepably low shutter speed.
How do you believe I should have set the camera?
Malcolm.
viv
Thu May 18, 2006 8:28 pm
Quoting Malandan (Reply 5):
Exposure compensation of, say minus 1/3 or minus 1/2 a stop might have saved the highlights in the foreground.
If you had shot with a larger aperture and a shutter speed of, say 1/60th, you would have had a bit more depth of field. You can easily hand-hold a 17-85mm lens at 1/60th.
malandan
Fri May 19, 2006 12:58 am
Quoting Viv (Reply 6):
Not too sure about that!  old
Thanks Glenn & Viv.
Users browsing this forum: 727LOVER and 1 guest
