Karlok
Motiv Rejection
Wed May 17, 2006 4:08 am
This is the photo I am talking about.
http://www.airliners.net/addphotos/r...H-BFD_Boeing_747-406M_KLM_Asia.jpg
And here are some items it may could cause this rejection.
* Photos that include window reflections (for shots taken through glass such as terminal windows).
-- Ok, some flash reflections on the display. Need for rejection?
* Photos showing just a part of an aircraft (with no motivation for doing so, like a special sticker, damage etc.).
-- Yes, it's part of an aircraft. The Cockpit :-/
* Photos with distracting or obstructing objects in the foreground (this is especially true for gate shots which are very difficult to get accepted due to their common nature and the large amount of equipment which usually surrounds the aircraft).
-- obstructing object in the foreground? The Yokes on the foreground maybe????
* Photos that do not show an aircraft or anything sufficiently related to aviation at all.
-- Yes, it is an aircraft
* Photos showing the date in the lower left or right corner of the image (some cameras do this, please diable this feature)
-- No date visible.
Can someone tell me why this belongs to a motiv rejection? Or was it just a wrong selection of rejection reason.
Kar-lok
timdegroot
RE: Motiv Rejection
Wed May 17, 2006 4:32 am
Reflections from the flash.
Tim
Alderman Exit
waketurbulence
RE: Motiv Rejection
My eyes are drawn to the flash reflection on the display screens. I would say this is probably why it was rejected for motive.
-Matt
Tim beat me to it by 25 seconds.
[Edited 2006-05-16 21:33:19]
Karlok
RE: Motiv Rejection
Wed May 17, 2006 4:38 am
Quoting TimdeGroot (Reply 1):
Thank you!
Kar-lok
timdegroot
RE: Motiv Rejection
Wed May 17, 2006 4:52 am
Karlok, it looks like this was a nightshot, or inside a hangar or something. Shot like that usually don't benefit from a flash and come out better if shot without it.
Tim
Alderman Exit
aero145
RE: Motiv Rejection
Wed May 17, 2006 5:19 am
If you're using a add-on flash, I would put something to bounce this. For example on pretty-cheap Sigma flashes, there's a thingy which goes out and bounces. If you have that, I would use it.
I have this same problem, it sometimes works to have the camera enough facing down... Smile
-David
glennstewart
RE: Motiv Rejection
Wed May 17, 2006 9:38 pm
You can also try flash compensation. Drop it by -2/3 EV. If the screens aren't on and there is little light in the cockpit, hand held shots without flash are fairly difficult.
One of the best ideas is to estimate the conditions before you go into the cockpit (if you have limited time), and to take several shots with varied settings. This way you can make the call on all of your shots as to which one would come out better after post processing.
Glenn
Respected users.... If my replies are useful, then by all means...
QANTAS077
RE: Motiv Rejection
Wed May 17, 2006 11:12 pm
here is a tip, just use the bandaid tool in PS and the flash reflections will be non-existent.  Wink if you can do it for dust then i can't see why you can't do it for flash reflection?
Karlok
RE: Motiv Rejection
Thu May 18, 2006 4:57 am
Quoting QANTAS077 (Reply 7):
That is one for a manipulation rejection I think?
timdegroot
RE: Motiv Rejection
Thu May 18, 2006 5:25 am
Quoting Karlok (Reply 8):
Indeed.
Tim
Alderman Exit
QANTAS077
RE: Motiv Rejection
Thu May 18, 2006 7:54 am
obviously it is because they know about the pic, if you did it in the first place you might have been successful?
if it can be done with minimul disturbance to the original image then is it acceptable? those flash reflections are on a par with the dust spots that we clone, i don't see the harm?
flyfisher1976
RE: Motiv Rejection
Thu May 18, 2006 10:02 am
Quoting TimdeGroot (Reply 9):
Indeed.
Tim
Sorry to get off topic...but this is a blatant double-standard. We are encouraged to clone out dust, but anything else is labelled as "manipulation"?  Yeah sure
QANTAS077
RE: Motiv Rejection
Thu May 18, 2006 11:13 am
question is, if it were a dust spot in the same location of the flash reflections it would be ok to clone them? i seriously don't know what the issue is with a few minor flash reflection clones from the LCD, it doesn't lessen the quality of the image in any way, just makes it a poofteenth more acceptable?
JeffM
RE: Motiv Rejection
Thu May 18, 2006 12:13 pm
Quoting GlennStewart (Reply 6):
Even better if you measure the light separately.
Quoting QANTAS077 (Reply 12):
poofteenth
....not showing up in the dictionary....  Smile
glennstewart
RE: Motiv Rejection
Thu May 18, 2006 12:40 pm
Quoting JeffM (Reply 13):
That's one of those strange west coast (Perth) words. It's also used the describe the amount of heat haze Perth experiences in winter.
Glenn
(obviously from the east coast)
QANTAS077
RE: Motiv Rejection
Thu May 18, 2006 2:13 pm
Quoting Glennstewart (Reply 14):
it's actually a footy term to describe something so minute that it ridiculous, bit like the word itself, but it describes the situation perfectly.  Wink
glennstewart
RE: Motiv Rejection
Thu May 18, 2006 3:49 pm
Quoting QANTAS077 (Reply 15):
I can think of a couple of things that would earn the description then  Smile
Glenn
Karlok
RE: Motiv Rejection
Sun May 21, 2006 7:53 pm
Received an another motive rejection today, could someone explain this to me? I see a lots of engines close-up in the database. This one shows a brand new and clean engine.
Please explain the differents to other engine photos in database?
http://www.airliners.net/addphotos/r...0_PH-AOD_Airbus_A330-203_KLM-2.jpg
Quoting TimdeGroot (Reply 4):
Yes, a hangar shot. Will try again later to produce a better shot
Kar-lok
Sinkrate
RE: Motiv Rejection
Sun May 21, 2006 8:00 pm
Hey
Quoting Karlok (Reply 17):
I Dont know? frown
I would say that its overexposed on the engine cowling, leading edge of the wing and the winglet.
I personally really like that motive.
Michael
[Edited 2006-05-21 13:03:27]
QANTAS077
RE: Motiv Rejection
Sun May 21, 2006 8:29 pm
overexposed i'd say more then anything...
