andersosl
Pre-screening Help
Wed May 17, 2006 8:21 pm
Hi.
Here are some shots, taken at Kjeller, 14th May:
http://home.no.net/ssaero/anet/IMG_7687%20copy.jpg
http://home.no.net/ssaero/anet/IMG_7465%20copy.jpg
Do they have a chance getting accepted?
viv
RE: Pre-screening Help
Wed May 17, 2006 8:30 pm
Very nice, especially the Mustang.
The first one could use a bit of sharpening, I think.
andersosl
Wed May 17, 2006 8:50 pm
Thanks, Viv!
BTW, should the Mustang-pic be categorized as a warbird?
Airplanepics
Wed May 17, 2006 9:07 pm
Nice photos, however I feel that the Mustang is too low in the frame?
Simon - London-Aviation.com
andersosl
Wed May 17, 2006 9:16 pm
Might be true, Airplanepics.
Is there any techniques to make a picture correct vertical centered?
I use Photoshop CS2 and 3:2-crop.
ptrjong
Wed May 17, 2006 9:23 pm
Quoting Andersosl (Reply 2):
Yes.
Quoting Airplanepics (Reply 3):
I agree, a bit higher in the frame and it would look even better.
If there's nothing left at the bottom of your photo, you could decrease space a bit at the top and sides.
Peter
viv
Wed May 17, 2006 9:53 pm
If it has a civil registration, yes.
glennstewart
Wed May 17, 2006 11:46 pm
Quoting Andersosl (Thread starter):
Yes, but I feel both are slightly over-saturated.
The mustang needs to be higher. I think the F-16 is sharpened just enough.
Glenn
Respected users.... If my replies are useful, then by all means...
andersosl
Thu May 18, 2006 12:12 am
walter2222
Thu May 18, 2006 7:39 am
Quoting Andersosl (Reply 8):
What about this one:
Hi there,
Nice shot, but I think it's a bit low in the frame. It is was mine, I would crop it even tighter and cut some of the main rotor blades (they are just there to lift the "chopper", no added value to the picture  Smile ...) because that would give - according to me a much more dramatic effect...
Good luck with uploading,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
andersosl
Sun May 28, 2006 3:56 am
The Mustang-pic was rejected for info and category.
http://www.airliners.net/procphotos/...?filename=20060527_mustanganet.jpg
Categorized as "Warbird". I guess that is the reason for the category rejection?
I don't understand the info rejection.
Anyone?
Thanks.
ptrjong
Sun May 28, 2006 4:24 am
Please list all the information you uploaded?
andersosl
Sun May 28, 2006 5:27 am
I used the auto complete form to find information about the aircraft. The reg. which was used : 414450.
Country/Location: Lillestrom - Kjeller (ENKJ) (typed manually).
Airline:: Scandanavian Historic Flight (typed by "Auto complete")
Aircraft: North American P-51D Mustang (typed by "Auto complete").
Date: 14th May 2006
Identification numbers: only the reg. number.
No remark, No watermark.
I don't remember which one i choosed: "Single engine prop" or "Airline or other".
The owner: Warbird
Paint Scheme: Normal (i guess)
Photo is picturing: Normal or Other.
ptrjong
Sun May 28, 2006 5:40 am
It is a Warbird because it has a civil registration even if it is invisible.
That registration is N167F, and construction number is 122-40417.
The military registration number painted on it is probably not the original one and anyway, you don't need it for your upload.
So Reg: N167F, code: none, Cn: 122-40417.
It's a Single engine prop because it's a single engined propeller aircraft. You probably went wrong there. Again, it is a Warbird.
andersosl
Sun May 28, 2006 5:44 am
Thank you very much !!
