Airplanepics
Possible Bad Center?
Wed May 17, 2006 11:48 pm
Hi all,
Would the following image have a chance of being rejected for Bad Center? I was attempting to go for a wide angle feel, to show one of the GA areas of the airfield.
Any advice would be greatly appreciated.
http://img.photobucket.com/albums/v223/Airplanepics/IMG_9535.jpg
Simon.
Simon - London-Aviation.com
timdegroot
RE: Possible Bad Center?
Wed May 17, 2006 11:53 pm
I'd place it a bit lower in frame.
Tim
Alderman Exit
glennstewart
Wed May 17, 2006 11:54 pm
Quoting Airplanepics (Thread starter):
Bad Center?
Horizontally this is a hard one to get right. I think you're borderline. Vertically though, you're way off... should be lower.
More obvious than the centre (and therefore I am surprised you didn't ask), is:
a) colour has a red cast
b) angle requires CW
c) extra sharpening
Glenn
Respected users.... If my replies are useful, then by all means...
Airplanepics
Wed May 17, 2006 11:56 pm
Quoting TimdeGroot (Reply 1):
Thanks Tim.
Quoting Glennstewart (Reply 2):
Yeah, I wasn't sure. Going to have another play around with it. Just wanted to get the centering correct, then I'll go on to the rest of the editing. Only gave it a quick sharping!
Cheers for the help.
Simon.
Airplanepics
Thu May 18, 2006 12:14 am
Ok, how's this edit?
I've lowered it in the frame, and attempted to get rid of the red colour cast...
http://img.photobucket.com/albums/v223/Airplanepics/IMG_9535-21.jpg
Simon.
[Edited 2006-05-17 17:18:47]
viv
Thu May 18, 2006 12:21 am
Still not level.
bla bla bla message too short
Airplanepics
Thu May 18, 2006 12:23 am
Quoting Viv (Reply 5):
Still not level.
Hmmm, I used the radar as a reference?
viv
Thu May 18, 2006 12:39 am
Try using the horizon. The wide angle means that verticals at the edges of the shot will lean outwards.
[Edited 2006-05-17 17:40:54]
Airplanepics
Thu May 18, 2006 12:42 am
Quoting Viv (Reply 7):
The runway isn't level though, if I was to level the horizon, the verticals would lean to the left?
viv
Thu May 18, 2006 12:50 am
The radar mast is actually leaning a bit to the left in your shot. By using it as a vertical reference, you make the shot lean to the right.
