spotterke
Rejected Picture....advice Wanted!
Thu May 18, 2006 4:31 am
Hi all,
What can i do to improve the quality of this picture??It got a rejection for bad quality,but this very same pic is accepted on other airplane databases.
http://www.airliners.net/procphotos/....main?filename=20060517_OO-TUM.jpg
christeljs
RE: Rejected Picture....advice Wanted!
Thu May 18, 2006 4:42 am
I agree with that the quality lacks and please don't compare other airplane databases to a.net
I have photos on here that didn't get on planepictures.net ! I asked them why and they simply said they have different standards... "Hmmm I thoght".
Christel A Photography
Newark777
Thu May 18, 2006 7:00 am
Looks very soft to me, along with some JPEG artifacts visible.
Harry
walter2222
Thu May 18, 2006 7:51 am
Quoting Newark777 (Reply 2):
 checkmark
What work-flow did you use? It seems that exposure is not corrected...? Can you show the original picture?
PS: There are several threads in this forum that give very good guidance on how to perform the processing of the shots, before uploading
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
spotterke
Thu May 18, 2006 7:04 pm
Unfortunatly i don't have the original anymore.I took this shot in Raw and worked on white balans and a little exposure correction.When saved i did aply a bit of sharpness.The program i use is Rawshooter essentials,and i think it is a strange program.In the program the photo's are good.But when i convert them to jpeg they look soft.Any idea's how this comes?
walter2222
Thu May 18, 2006 8:06 pm
Quoting Spotterke (Reply 4):
Hi Marc,
Are you processing your pictures after you have converted them from RAW into JPG? I am not familiar with Rawshooter, but I assume you still have to perform sharpening (e.g. in Photoshop) on your JPG's (after the conversion from RAW).
PS: Here 's the link to the thread with a lot of tutorials:
Some Excellent Tutorials (by 9VSPO May 10 2006 in Aviation Photography)
Good luck,
Walter
spotterke
Fri May 19, 2006 8:08 pm
Hi walter,
I try to process as much as possible in rawshooter,then i convert them to jpeg and that's where i loose some sharpness.Usually before i convert,my pictures looking fine in rawshooter.
Guido
Mon May 22, 2006 4:57 am
I guess it's a contrast problem.
Did you select higher contrast before converting ?
Once the belly or engines get a yellow tone .. it's over the hill for a.net.
I'm also a 'raw' shooter and the contrast selection is my biggest problem before converting.
I noticed that often reducing the contrast but increasing saturation helps to get it accepted.
