Cadet57
Setting F-stops On The Nikon D50
Thu May 18, 2006 10:28 am
Quick question on how to do this, cant seem to figure it out.
senorcarnival
RE: Setting F-stops On The Nikon D50
Thu May 18, 2006 10:35 am
Do you not have an owner's manual? I have no idea how to do that, but here's the owner's manual, have at it.
http://www.nikonusa.com/pdf/manuals/noprint/D50_en_noprint.pdf
Oh no, she's getting impatient! Take a stab at it!
viv
Thu May 18, 2006 8:30 pm
Quoting Cadet57 (Thread starter):
Read the manual, kindly provided by Senorcarnival.
It's just Photography 101, not rocket science.
Cadet57
Thu May 18, 2006 10:09 pm
Quoting Senorcarnival (Reply 1):
I do. Problem was is that it diddnt work and it seemed clunky and hard to do. It was on a friends camera and neither of us figured it out. So i figured id ask and see if anyone had any tips...
Stealthz
Thu May 18, 2006 10:27 pm
I don't have a D50 in front of me (a number of Canons tho) but a quick look at page 44-45 of the user manual do not make your situation look that difficult.
Chris
viv
Thu May 18, 2006 10:28 pm
From kenrockwell.com:
Exposure Mode Dial (Left side): I use "P" for program auto exposure. In this mode the camera chooses the f/stop and shutter speed for you. If I want to use different apertures or shutter speeds I rotate the rear command dial, which selects alternate combinations of f/stops and shutter speeds which give the same exposure. Nikon calls this "Program Shift." A "*" is added next to the P on the top LCD to let you know you've chosen a different combination for exposure.
If you want to use only one aperture or one shutter speed then use S or A mode. If you want to set it the hard way, use M, manual, mode.
Aperture Button (icon of a camera iris, this is also the same button as the compensation button): Hold this and spin the rear control knob to change the aperture setting an Manual (M) exposure mode.
