aero145
Will This Be A NOA_double?
Wed May 24, 2006 12:31 am
Hi guys.
I was thinking of uploading this photo:
Big version: Width: 1100 Height: 733 File size: 764kb
But I didn't think it could be accepted because of a similar photo of the same aircraft in the DB:
Photo © David Alfred Eliasson - Reykjavik Spotters
What do you think?
Upload: Yay or Nay?
If you see some other things that can be fixed on the photo, could you tell me what's wrong with them?  half
David  sun  Big grin
dcrusafon
RE: Will This Be A NOA_double?
Wed May 24, 2006 1:17 am
Hi David,
I think it will be NOA_DOUBLE as the other pic is yours and it is very similar and same angle. Are they from the same day?
Here you have more info http://www.airliners.net/procphotos/reasons.php
Also, it looks (for me   ) a little bit dark.
Just my
Brgrds,
DARIO
[Edited 2006-05-23 18:21:51]
aero145
Wed May 24, 2006 1:27 am
Dario,
I have no problems of this link, thanks anyways.
I have got a photo accepted, which was taken at a similar angle as another photo, which was in the DB. Not long time ago. That was because of the smoke changing the picture.
Thanks at least...  Smile
Waiting for more answers...
-David
Psych
Wed May 24, 2006 1:49 am
Hi David.
This issue has recently been discussed in this thread and I have been in recent correspondence with Glenn about the issue. I am hoping that Glenn will add to that thread, but others from the crew may see fit to make an addition here.
It does look as though there is some confusion with this rule that needs clarification. But, as someone who has been on the wrong end of the rule in the past and had discussions about it here, I feel quite clear:
If you have a previous photograph already on the database of a particular registration - as you do with this example - and you then submit a further photo that has a similar motive - e.g. angle/stage of flight etc - then you are likely to get a rejection for NOA_Double. It DOES NOT make any difference that the photos were taken on a different days.
Thus - though it is a subjective judgement call - some would argue that this new photo has the plane at the same angle, from the same side, and so it is a candidate for this rejection. Others I guess might argue that the plane is not physically in the same place. To unpick that one would require the input of one of the screening team. My hunch - for what it is worth - is that it will get a double rejection.
I hope this helps.
All the best.
Paul
aero145
Wed May 24, 2006 2:25 am
Thanks Paul,
What do you think of this?
Two pictures, similar angles, smoke on one...
I am wondering if this can make the difference.
Of course, the photos weren't taken at the same day.
BCW and BCX.
-David
asgeirs
Wed May 24, 2006 9:58 am
David,
Although the angle is similar in both photos, it differs by a few degrees + they are differently cropped. In my opinion, the smoke as well as the different location/background should make the photos distinct enough so as not to get categorized as doubles.
Asgeir
Reykjavik Aviation Photography - Just bring the aircraft to us and we'll photograph them! :-)
glennstewart
Wed May 24, 2006 12:02 pm
Quoting Psych (Reply 3):
Any updates from crew, I'll post  Smile
But on this one, please upload as the variance in smoke and day should be enough. Of course, it will take a screening to finally find out in this case.
Glenn
Respected users.... If my replies are useful, then by all means...
aero145
Sat May 27, 2006 4:06 am
Thanks for the posts, Asgeir and Glenn!
I will curve the photo up a bit, and then upload it later this month, or in the beginning of June.
Time for archiving now!  Smile
David Big grin
glennstewart
Mon Jun 05, 2006 4:28 pm
The doubles issue btw is still being looked at.
aero145
Mon Jun 05, 2006 6:42 pm
Thanks, but why can't the thread bee locked?  Wink
-David  Smile
JeffM
Mon Jun 05, 2006 9:30 pm
Quoting rules, :
In order to receive this rejection, the other (similar) photos in the database must also have been taken by you, at the same day and at the same airport.
waketurbulence
Tue Jun 06, 2006 12:54 am
Jeff also from the rules:
"In certain cases you can also get this rejection if there are photos in the database that are nearly identical to the one(s) rejected here, but taken on another date by you. Examples of this are photos of stored or preserved aircraft that have not moved since you took the other photos."
-Matt
