ua935
Rejection Assistance
Mon May 29, 2006 8:15 pm
Afternoon,
I previously had this image rejected jagged so re worked it and reuploaded.
Today it has been rejected for Quality, Centred, Dark, Common.
If it was rejected for all of these the first time I would not have bothered re editing if I didn't think the quality was there.
I cannot see that the image has gone from just suffering from jaggies to being an image which warrants 4 rejection reasons.
I have never received 4 rejection rejection reasons for an image, especially one where on the initial rejection I received a personal message from the screener advising that they could see jaggies on the titles and I should re edit.
Your thoughts and views would be appreciated.
http://www.airliners.net/addphotos/r...big/20060529_9MMPB3LHR08042006.jpg
Simon
Live every second like you mean it
ptrjong
RE: Rejection Assistance
Mon May 29, 2006 8:33 pm
Well, I don't know what the first edit looked like, but this one is certainly dark in my opinion.
Should have been given COMMON the first time to indicate extra high
standards are required.
The centering rejection I don't understand.
The distracting building to the left doesn't help the photo though.
Peter
flyingzacko
Mon May 29, 2006 9:38 pm
Just be glad it didn't get motiv as well for the disturbing building on the left. Well, the photo is definitely dark. You can hardly make out the wheels. Common, yes there is a lot of the Wunala livery out there. Quality, I think this one's definitely lacking some of that. Center, I'm not sure, to me it looks alright.
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
ua935
Mon May 29, 2006 10:04 pm
Quoting FlyingZacko (Reply 2):
Wunala livery
It's Hibiscus and there is not one other ground shot of the aircraft at Heathrow in the database.
vasanthd
Tue May 30, 2006 12:06 am
Hey Simon,
The engines defn looks dark. Maybe a touch of the shadow/highlight tool might help ya.
I can see some jagginess over certain places. Check the text - "An experience redefined". Maybe that's an quality issue? Other than that, I dont see any quality issue.
Vertical centering is the issue here. See the space from the top of the tail and compare that with the space from bottom to the gears. This 747 sure requires moving down a bit.
Since its a pretty common plane, they expect the pic to be flawless. and that's the reason for Common. Cure all the other issues, and you shld be able to get this accepted.
Cheers!
--Vas
--Vas
One Lucky shot deserves another!
flyingzacko
Tue May 30, 2006 1:55 am
Quoting UA935 (Reply 3):
Sorry for mistaking that, my bad.
Sebastian
walter2222
Tue May 30, 2006 2:05 am
Quoting VasanthD (Reply 4):
 checkmark
I would also crop tighter to the nose (equally to the tail, to keep horizontal centering OK) to get rid of that awkward part of that building (this attracts attention away from the plane)!
Good luck with the re-edit!
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
