i530j
Nice B6 Photos... Yes Or No?
Mon Jun 05, 2006 8:15 am
I was shooting at MCO today and got these pics and wanted to know from the others here at a.net yes or no?If no tell me and ill do my best to edit.
P.S im gonna resize them before upload.
Justin
Edited for spelling
[Edited 2006-06-05 01:17:32]
"I love you, I love the kids..." then the phone went dead.
ATCme
RE: Nice B6 Photos... Yes Or No?
Mon Jun 05, 2006 8:25 am
First one seems to be cut off.
Second seems okay to me.
Take my advice with a grain of salt because I don't have any photos in the DB.
ATCme  spin
I'm from the FAA, and I'm here to help. Really. Yes I'm serious, I'm here to help you.
FlightShadow
Mon Jun 05, 2006 8:30 am
1) No. Bad motive
2) Has a chance, with proper editing and a little bit of leveling
IMO
[Edited 2006-06-05 01:42:52]
"When the tide goes out, you can tell who was skinnydipping."
ZSOFN
Mon Jun 05, 2006 8:40 am
Hi Justin,
I like those shots, but I reckon the first one wouldn't make it on here; it's not generally an acceptable motive (although I personally like those sorts of shots).
The 2nd one looks good to me - one problem I see is that you've cropped the tail off; this might not be a problem if you crop tighter outside the engines and raise the aircraft in the frame slightly. Additionally you'll need to give it about 1.5 - 2 degrees of CCW rotation. From a levels point of view the shot could probably do with having them tightened up a bit, and also I think the photo's a bit dark; boost the brightness just a touch, watching out for hotspots.
Tom
i530j
Mon Jun 05, 2006 9:21 am
Hello all im j/w why would the first one not be acceptable?
Photo © Justin Idle
Photo © Anthony Russo
These look the same but this is just my  twocents
Justin
Newark777
Mon Jun 05, 2006 9:23 am
I agree that the first is badmotive, and the second should be able to get to proper quality with good editing, however the blown out details on the nose might give you problems.
Harry
Newark777
Mon Jun 05, 2006 9:24 am
Quoting I530j (Reply 4):
Those include the bottom part of the aircraft and the front gear.
Harry
i530j
Mon Jun 05, 2006 9:28 am
Quoting Newark777 (Reply 6):
walter2222
Mon Jun 05, 2006 9:31 am
Hi Justin,
1) as already stated by others.
2) based on the high voltage pylon (in the background), I would use some 1.8 CCW rotation. It seems that there is also a tiny dust spot (on the right of the vertical stabilizer), maybe two (but my eyes need definitively some sleep now...).
I like the angle, certainly the position of the gear and the way you can see the "forces" acting on the tires because of the turn. A small negative remark is the small portion of the red pole with the aircraft warning lights (although it is in the background, it seems to protrude from the aircraft...). Before pushing the trigger, it is advisable to have a detailed view in your viewfinder on how the picture will look two-dimensionally (on paper/on screen)! When looking through the viewfinder, you see your picture, however, three-dimensionally and then - to the untrained eye - you will not notice that something in the background will interfere with your main subject...
Good luck,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
i530j
Mon Jun 05, 2006 9:39 am
Thanks walter I'm not that good at photoshop so if i give u the photo via email do you think you could help?
Justin
walter2222
Mon Jun 05, 2006 6:18 pm
Hi Justin,
I am not a specialist either  Smile ! I am learning day by day, by all the good advise in this forum. If you tell me what kind of tool you are using (Photoshop Elements 2, 3 or 4 or Photoshop CS), I could give you some hints of what I would do (I have Photoshop Elements 2 available as well as Photoshop CS (version 8)), but still it is no guarantee to get a shot accepted...
You can e-mail me, of course, and I can see what I can do and I can explain you the steps so that you can do it afterwards and see the effects yourself (because it is your picture)!
Walter
aero145
Mon Jun 05, 2006 7:03 pm
Here's my job:
Big version: Width: 1023 Height: 682 File size: 521kb
Great Blue Sky
Cw rotation, crop, resize, canvas size, sharpen, curves, brightness.
IMO, you should use your Digital Rebel in Av mode, not in Auto, as there you can set most of the things yourself. Aparture 7.1 is all right, but I'd go for a little more on a sunny day, then set the Exposure compensation (by pushing the Av button and pushing the four-way controller to the left) two steps lower. I think, then you'll be in good "hands".  Silly
I'm interested why there's such grain on ISO 100, can it probably be because the photo was shot at 230mm (x 1.6) and there was heat-haze?
At least Justin thread starter, I don't think this picture will make it:
Blurry, over-exposed on nose...
Just my  twocents
-David
JeffM
Mon Jun 05, 2006 9:40 pm
Quoting Aero145 (Reply 11):
Bad advice. You're telling him to compensate by "two steps" (what are "steps"?) and you have no idea what his shutter speed is or what the scene calls for. He would be better off shooting a test frame or two and adjusting via his histogram.
viv
Mon Jun 05, 2006 9:58 pm
Oh dear. Why go to all that trouble? And why go for an even bigger aperture than f/7.1 on a sunny day????
[Edited 2006-06-05 15:08:12]
aero145
Mon Jun 05, 2006 11:20 pm
Well Jeff I saw the exif.
Vivion, I use most often f/11-13 on a sunny day. The photo will be sharper with the higher f/.
I do not understand "trouble" here, as bigger f/ = sharper pic. For me, f/7.1 is just nothing... It's really too low number for me.  Silly
-David
i530j
Tue Jun 06, 2006 2:10 am
Thanks all a lot
Justin
viv
Tue Jun 06, 2006 4:31 am
Quoting Aero145 (Reply 14):
That is a SMALLER aperture than f/7.1. We are talking at cross purposes. You are talking high or low aperture NUMBERS. I am talking the size of the aperture, i.e. how big or small the HOLE is.
JeffM
Tue Jun 06, 2006 11:59 am
Wonderful, but that advice isn't accurate for every instance.
Wrong. It only means more will be in focus. Where did you learn about Photography?
You can get a sharp image with an aperture of f2.8 The trouble is you are giving lousy advice.
viv
Tue Jun 06, 2006 4:16 pm
Quoting JayDavis (Reply 18):
don't argue with JeffM, he is perfect and knows everything about everything; especially when it comes to photography and cameras.
Actually, I was agreeing with him!
What I do not agree with is your gratuitous and unfounded sarcasm, but I'm sure that Jeff will ignore it.
aero145
Tue Jun 06, 2006 4:26 pm
Quoting Viv (Reply 16):
Sorry, I was talking about the size of the number. Sorry for the misunderstanding.
-David.
[Edited 2006-06-06 09:46:42]
JayDavis
Wed Jun 07, 2006 9:31 am
Aero145,
Great shot!
aero145
Wed Jun 07, 2006 6:43 pm
Quoting JayDavis (Reply 20):
Aero145,
Great shot!
 Confused
What shot? Are you maybe trying to make a fool of me because of my misunderstanding?
At least, there was no shot.
-David
