walter2222
First Try At Panning... Sufficient Quality?
Thu Jun 29, 2006 6:27 am
Hi there,
I have just put this one in the queue:
http://www.airliners.net/addphotos/b...060617_CRW_5025_RT8_WVB_1200px.jpg
Does it have enough quality to stay in the queue? It was my first attempt with panning...
Any comments welcome!
This is one from my personnal site:
http://walter2219.fotopic.net/p30698168.html
Would this have a chance or would it be rejected for partially "backlit" (and other NOA's)?
Thanks for ant feedback!
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
aero145
RE: First Try At Panning... Sufficient Quality?
Thu Jun 29, 2006 6:35 am
I'd say the panning shot is blurry. Backlit isn't really making it better.
The second has a very much amount of grain, and is backlit.
I'd pull the panning shout out.
-David
9VSPO
Quoting Walter2222 (Thread starter):
I would say a bit of sharpening is needed Walter. Looks a bit soft to me.
Kukkudrill
Thu Jun 29, 2006 6:46 am
The Hunter looks slightly blurred in the nose area and the drop tanks (panned shots often turn out blurred in one place and sharp elsewhere - at least that's been my experience). I would reduce the photo to 1024 pixels width and apply a little more sharpening to the areas in question. I would also rotate the photo slightly counter-clockwise.
I'm not sure about the Fat Albert photo. Could be borderline backlit, but I'd take a chance and upload if this was the only concern. However, the undersides of the aircraft look rather noisy: when you lighten an underexposed area it often brings out the noise. The starboard wing leading and trailing edges also look like they need a bit of selective sharpening.
Make the most of the available light ... a lesson of photography that applies to life
JeffM
Thu Jun 29, 2006 9:36 am
First one is blurry, second one would fall to 'quality'.
walter2222
Thu Jun 29, 2006 8:21 pm
Hi All,
Thanks for the feedback!
I will just keep them in my personal site and pull it from the queue.
Walter
