unattendedbag
Level Reject
Mon Jul 03, 2006 3:59 am
need some more eyes on this one.
based on the vertical lines in the center of the photo, this one looks level.
http://www.airliners.net/addphotos/r...ons/big/20060702_06n229jb0616a.jpg
anyone disagree?
thanks!
Slower traffic, keep right
eddl
RE: Level Reject
Mon Jul 03, 2006 4:11 am
Needs a CW rotation.
Phil / EDDL
Psych
RE: Level Reject
Mon Jul 03, 2006 4:25 am
Hello John.
That hangar does present you with a bit of a levelling nightmare.
One option to tackle this is to use the 'transform' function in PS, as I have tried to do in this edit below:
Big version: Width: 700 Height: 475 File size: 281kb
John's photo - corrected
Now I don't know if this would count as 'manipulation' (what does anyone else think on this?), but the plan here was to correct the distortion created at either side by your lens. You would need to do this with the original to ensure it looked better, as the process has cropped the nose off here. But now all the verticals appear as vertical. You may then need to tweak other aspects of the image, so the plane looks okay, but this is just to give an idea.
If you need any further help with this let me know.
All the best.
Paul
ptrjong
RE: Level Reject
Mon Jul 03, 2006 5:06 am
Leveling on the verticals the centre should be fine in principle, right?
Paul's exercise should not be necessary.
Peter
Users browsing this forum: acontador, Baidu [Spider] and 14 guests
