frippe
Private Or Not?
Sun Jul 09, 2006 5:16 am
Hello,
Please forgive my asking for advice once again, but I can not afford an unnecessary rejection for INFO!
http://www.airliners.net/addphotos/big/ready/N212LT3003nef.jpg
The photos in the database have differing INFO:
1. PROP and nothing else
2. PROP and PRIVATE
Which one is correct?
Thanks in advance for your help,
Frippe
jumbojim747
RE: Private Or Not?
Sun Jul 09, 2006 5:45 am
Its a prop and if its not commercially used it would be private also.
I'm at work i cant look up the operator of this aircraft .
Hope that helps .
On a wing and a prayer
airkas1
Crew
RE: Private Or Not?
Sun Jul 09, 2006 5:51 am
Registered Owner:
Name AIRCRAFT GUARANTY TRUST LLC TRUSTEE
Street 515 N SAM HOUSTON PKWY E STE 305
City HOUSTON
County HARRIS
Country UNITED STATES
So I guess Private?
Airliners.net Crew - Head Photo Screener
jumbojim747
RE: Private Or Not?
Sun Jul 09, 2006 5:56 am
Quoting AirKas1 (Reply 2):
So I guess Private?
Thanks Kas so its private and single engine prop tick both and you will be ok.
Dont forget to put untitled also
[Edited 2006-07-08 22:59:14]
dc10tim
RE: Private Or Not?
Sun Jul 09, 2006 8:51 am
If one of the screeners reads this, could they chip in here?
Generally, if a prop as such is untitled, I'd upload it as 'private', however, if it has any form of titling, I'd upload it with that.
Is this the correct way to go about doing things? Further advise would be great.
Tim.
Obviously missing something....
jumbojim747
RE: Private Or Not?
Sun Jul 09, 2006 10:25 am
Tim I'm not a screener but i think i can answer this question.
If the aircraft has any sort of markings identifying the company then that is what you upload it as.
But if it has no such markings then it should be uploaded as untitled.
Hope that helps
paulc
RE: Private Or Not?
Wed Jul 12, 2006 9:07 pm
So the private category on the upload form will be reinstated then ? as untitled / etc is meaningless. Am still going through all my GA pics adding Private in the remarks category!
English First, British Second, european Never!
AirMalta
RE: Private Or Not?
Thu Jul 13, 2006 12:29 am
I was told that props like PC12;C421;Navajos;C340s; are privates while bizjets C550;C560,Gulfstreams are called Business....SW3s are classified with airlines or freighters if so like Convairs etc etc...hope this helps
Malcolm
