Parsival
Vignetting On Canon 5D - A Small Test
Wed Jul 12, 2006 8:02 am
Hi all,
I want to show some pics to demonstrate the vignetting on a Canon EOS 5D. I'm interested in your opinions and experiences to avoid those effects especially on a 5D (as it is not such an issue on APS/C sensor cameras I think). I think it's also helpful for those who plan to purchase one of the tested lenses to use on a 5D or another camera with a full format sensor. I do not want to demonstrate sharpness or any other characteristics of these lenses. Thats why all pics are downsized to 800x533 because the vignetting is easier to see on such a small size. Most of the pics are shot with a Sigma EX 80-400 4.5-5.6 OS DG and some with a Canon 70-200 2.8 L USM. All shots taken with ISO100. I have only chosen pics where the aircraft doesn't cover the whole picture because vignetting is much better visible in the sky areas.
Sigma 80-400 F6.3 400mm
http://www.tombombadil.de/bupics/testvign/80400F63FL400.jpg
Sigma 80-400 F8 315mm
http://www.tombombadil.de/bupics/testvign/80400F8FL315.jpg
Sigma 80-400 F10 400mm
http://www.tombombadil.de/bupics/testvign/80400F10FL400.jpg
Sigma 80-400 F16 350mm
http://www.tombombadil.de/bupics/testvign/80400F16FL350.jpg
Sigma 80-400 F16 315mm
http://www.tombombadil.de/bupics/testvign/80400F16FL315.jpg
Sigma 80-400 F10 250mm
http://www.tombombadil.de/bupics/testvign/80400F10FL250.jpg
Sigma 80-400 F6.3 142mm
http://www.tombombadil.de/bupics/testvign/80400F63FL142.jpg
Sigma 80-400 F6.3 116mm
http://www.tombombadil.de/bupics/testvign/80400F63FL116.jpg
Canon 70-200 F2.8 200mm
http://www.tombombadil.de/bupics/testvign/70200F28FL200.jpg
Canon 70-200 F4 200mm
http://www.tombombadil.de/bupics/testvign/70200F4FL200.jpg
Canon 70-200 F6.3 200mm
http://www.tombombadil.de/bupics/testvign/70200F63FL200.jpg
If you want to download these pics then the filenames contains the lens type, aperture and focal lenth (i.e. 80400F10FL315.jpg - Sigma 80-400, F10, 315mm).
Bjoern
sorry for my broken english...
JeffM
RE: Vignetting On Canon 5D - A Small Test
Wed Jul 12, 2006 1:07 pm
Quoting Parsival (Thread starter):
wow. I would return it. I know two people that own 5ds, I asked them if they experience that as bad as this and they don't. Could be they are lucky, but the images they showed me show little if any signs of it.
Honestly, that is not very appealing.
Parsival
Wed Jul 12, 2006 4:30 pm
Quoting JeffM (Reply 1):
Do you mean the camera or the lenses? Do the people you have asked use the same lenses on this cam? Perhaps I had to explain that I also have lots of pictures with only a little of this effect. Here I wanted to show some extremes.
Bjoern
DLKAPA
Wed Jul 12, 2006 4:45 pm
I thought vignetting was strictly a lense problem?
RWY-16
Wed Jul 12, 2006 5:09 pm
I had the same problem with my 70-200/2.8 on the 5D. Pictures are okay with f8. I also tried the 20mm/2.8 with f8. Not really good. After all, I sold my camera immediately and changed to Nikon with 1.5 crop. Now I am happy with 12 mio. pixel.
Regards, Andi
aviopic
Wed Jul 12, 2006 7:08 pm
Bjoern now I have a look at it I think that my concern was justified.
It seems you have a serious problem.
Photo 1 and 3 show almost no difference although the aperture changed from F6.3 to F10.
Then again the last Sigma image does not show much vignetting at F6.3 so the problem is not consistent, this is however a more or less a result I could have lived with.
Little vignetting and aperture almost wide open on a full size sensor.
Normally I would be suspicious about the lens but since the Canon shows the same problem the problem can only be in the camera.
It seems your 5D has a problem to adjust the aperture properly.
If it was mine I would have taken it back to the shop for a check.
Good luck with it,
Willem
The truth lives in one’s mind, it doesn’t really exist
eddl
Wed Jul 12, 2006 7:38 pm
Quoting Aviopic (Reply 5):
It's just the way it is unfortunately, no camera problem here ... there are numerous discussions on the web concerning 5D and vignetting. It's no different with the 1Ds MkII. Even some very expensive L prime lenses have this problem on the digital full frame sensors.
Phil / EDDL
chris78cpr
Wed Jul 12, 2006 8:21 pm
I agree with Phil int he fact that on a full frame sensor vignetting will always be a problem. And the 5D in particlar has had complaints made that the 24-105 lens vignetts on it at 24mm wide open. However, i have not seen any real problems with people experiancing vignetting at longer focal lengths, especially not any that bad. I would ask for a replacement camera to be honest. There is no way that it should be that bad at 400mm. Especially when the lens is stopped down.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
viv
Wed Jul 12, 2006 8:39 pm
That's why I don't like cameras with full-frame sensors. But vignetting at 400mm? Something is wrong ....
aviopic
Wed Jul 12, 2006 9:39 pm
Quoting Viv (Reply 8):
and F10................. is totally unacceptable what ever brand and or type involved.
Quoting EDDL (Reply 6):
This camera is flawed.
If it was not we would have seen a consistent vignetting for every aperture at a given focal lenght but this thing is clearly mixed up.
Even in the unlikely case it is not a camera failure I would still bring it back to the shop and ask for a refund as this camera does not do what could be expected from this equipment.
A camera(in the given price segment) that can't be used wider then F10 is useless and I bet anybody will win the argument about the refund.
Parsival
Wed Jul 12, 2006 10:34 pm
First thanks for your replies guys so far!
But the last picture is taken at 116mm. I think the vignetting problem is getting more worse with higher focal lenght (300mm and more) and I think this is a general problem, not only a problem with my 5D body.
Vignetting on full frame sensors is reality but on the other hand:
Quoting Chris78cpr (Reply 7):
Quoting Aviopic (Reply 9):
I totally agree with these opinions except that I would bet "..anybody will win the argument about the refund".
I will give back my experiences and dissatisfaction as feedback to Canon. I will try to make some test shots with other 5D bodies to compare to my body and see if the problem is a body-specific one or a general 5D problem. If it is body-specific I think it will be no problem to get a refund. If it is not - hm, then I think I have to activate my negotiating skill...  box
I just wanted to mention that "DXO optics pro" is a very useful program that can outstandingly correct these vignetting and other problems on many digital cameras even on a 5D but not in combination with the Sigma 80-400 - how sad!
Bjoern
timz
Mon Jul 17, 2006 9:00 am
Did you guys see that stitched panorama taken with a 5D at 200 mm? (It's 5 MB).
http://upload/wikimedia/org/wikipedi...sland_Ferry_Corrected_Jan_2006.jpg
Think he had to correct vignetting?
Parsival
Mon Jul 17, 2006 6:35 pm
Quoting Timz (Reply 11):
Sorry, can't open this link. Neither with IE nor with mozilla. Am I the only one having this problem?
Bjoern
LH526
Mon Jul 17, 2006 11:21 pm
Quoting Parsival (Reply 12):
5MB pic - be patient  Smile
Mario
LH526
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
timz
Tue Jul 18, 2006 2:33 am
Sorry-- didn't have time to check that link for typos. I'll try again:
http://upload.wikimedia.org/wikipedi...sland_Ferry_Corrected_Jan_2006.jpg
