777MechSys
Rejected
Sun Jul 16, 2006 2:18 am
I was doing so well with 6 acceptances in a row. Then I got a bad info on this one.
http://www.airliners.net/addphotos/r...ons/big/20060715_southwest_pae.jpg
REG. N247WN
CN 32508
Southwest Airlines
Boeing 737-7H4
Boeing 737-700 (BBJ/C-40 Clipper)
I marked paint as special. Since it has no paint. Maybe this is where I went wrong. Did I tick the wrong box?
I also marked "Dusk" CI 747 that I took a picture of 15 minutes prior was marked dusk and was accepted.
-Erick
ptrjong
RE: Rejected
Sun Jul 16, 2006 2:38 am
Quoting 777MechSys (Thread starter):
Southwest Airlines
It's Untitled.
Peter
eddl
RE: Rejected
Sun Jul 16, 2006 2:42 am
Reg: N247WN
CN: 32508/1989 ... don't forget the line number
Untitled (Southwest Airlines)
Boeing 737-7H4
Category: Hybrid/other_paint ... NOT special. Dusk/dawn is a bordercase here ...
Could need some extra sharpening as far as I can see, I am no screener though.
Hope this helps,
Phil / EDDL
[Edited 2006-07-15 19:44:07]
777MechSys
RE: Rejected
Sun Jul 16, 2006 2:53 am
Quoting EDDL (Reply 2):
Well I basing it on time before sunset and the fact that a picture I took 15 before was accepted as dusk.
Hybrid/Special paint confused me because it said "Airliners without paint scheme or in an all white paint scheme should also be included here."
Maybe it was just the Untitled Southwest.
Erick
Woody001
RE: Rejected
Sun Jul 16, 2006 2:58 am
The image is also a little soft, if you do sharpen it more, watch the quality - it's borderline as it is.
Best of luck with it,
Ian.
If I could just get the afterburner working...
eddl
RE: Rejected
Sun Jul 16, 2006 3:00 am
Quoting 777MechSys (Reply 3):
No ... badinfo for airline, c/n AND category ... trust me.  Smile
Phil / EDDL
777MechSys
RE: Rejected
Sun Jul 16, 2006 3:05 am
Quoting EDDL (Reply 5):
trust me.
Will do.  Wink
Maybe some changes to wording in the help files would help out people like me.  Smile
I may rework it and resubmit. I may just through off to my screensaver folder.
Erick
ptrjong
RE: Rejected
Sun Jul 16, 2006 3:19 am
Quoting 777MechSys (Reply 6):
I second that, although in this case... You noted that the aircraft is unpainted, and still chose SPECIAL COLOURFUL PAINT SCHEME (first option) instead of HYBRID/SPECIAL MARKING (second option, for hybrids, special markings, without paint and all-white? I don't get it.
Or did you choose the second option? In that case you were correct.
eddl
RE: Rejected
Sun Jul 16, 2006 3:21 am
Don't know where your confusion is coming from ... help me please  Smile
Phil / EDDL
eddl
RE: Rejected
Sun Jul 16, 2006 3:23 am
Quoting Ptrjong (Reply 7):
Faster than me again .......... Big grin
777MechSys
RE: Rejected
Sun Jul 16, 2006 3:38 am
I should have said Hybrid/Special.
I forgot the other category was called special.  banghead  My mistake. I didn't realize two categories had similar names. I apologize for causing confusion.
-Erick
ptrjong
RE: Rejected
Sun Jul 16, 2006 3:44 am
Quoting 777MechSys (Reply 10):
That's what I thought Wink Not your fault - the names are confusing, especially as they're called different again (COLOURFUL/OTHER) in other places on the site.
