ei a330-200
What Do You Guys Think?
Sat Jul 22, 2006 2:29 am
This is my second attempt at submitting a photo to a.net. The first photo was rejected, and I'd like to know if you guys think this stands a chance, and if not, how should I change it?
[Edited 2006-07-21 19:36:56]
mikephotos
RE: What Do You Guys Think?
Sat Jul 22, 2006 2:31 am
Remove the little red x and all should be fine  Smile
MIke
Granite
Sat Jul 22, 2006 2:33 am
Brian
Yes, fix the link.
We're here to help.
Gary
ei a330-200
Sat Jul 22, 2006 2:38 am
It works now, folks.
Brian
bubbles
Crew
Sat Jul 22, 2006 2:39 am
Hi Brian,
At least I feel it isn't properly levelled. Some CCW rotation is needed.
_Hongyin_
eksath
Crew
Sat Jul 22, 2006 2:46 am
and distance to far.
World Wide Aerospace Photography
ei a330-200
Sat Jul 22, 2006 2:47 am
OK, I can understand that, but why was this one rejected? The reason given was "quality", but I just don't understand. They really should have the screeners give a better explaination.
http://www.airliners.net/addphotos/rejections/big/20060721_USMC-LAR_Disaster_Response_Exercise_008.jpg
bubbles
Crew
Sat Jul 22, 2006 2:58 am
Quoting EI A330-200 (Reply 6):
It looks soft and grainy, IMHO.
_Hongyin_
ei a330-200
Sat Jul 22, 2006 3:05 am
Well, I have a 5mp camera. Is that too low? What is the minimum MP you guys reccomend? I'm also using Photoshop CS to edit the photos.
Brian
bubbles
Crew
Sat Jul 22, 2006 3:11 am
Hi Brian,
First I suggest you should crop the photo and resize your image in 1024 x 683, and do some sharpening work on the plane itself. And there is a document elaborating the whole editing process. It's very easy to follow. And I believe your image will benefit from it.
http://www.airliners.net/addphotos/PsProc.pdf
Hope it helps!
_Hongyin_
[Edited 2006-07-21 20:12:38]
mikephotos
Sat Jul 22, 2006 3:12 am
I'd have to agree with the quality rejection. There's just too much .jpg compression which is certainly a quality issue. Is this photo straight of the camera?
Mike
Granite
Hi all
For future screener applicants:
Jpeg compression, distance, centred and only very slight angle (passable)
Brian, probably your camera settings at fault here. Make sure the very best quality is selected. Possible your processing.
Can you upload your original image for us to see?
Gary
mikephotos
Sat Jul 22, 2006 3:13 am
Quoting EI A330-200 (Reply 8):
For a ground shot like that, 5mp should be more than enough.
Mike
D L X
Sat Jul 22, 2006 3:16 am
For a 1600x1200 picture? Perhaps. But you can shrink that down to 1024x768 or 1024x683 and 5MP is probably just fine.
You also need to sharpen and recrop the image. Personally, I like how you used the rule of thirds, but for this site, you need to put the plane in the center of the frame for most shots.
Finally, I'd boost the contrast just a little. Just be careful that you don't make the tires so contrasty that you lose detail.
nice shot!
