OlegShv
File Error - What To Do?
Tue Jul 25, 2006 11:19 am
I got one of mine rejected with the following explanation:
During or after uploading these photo(s), an error occurred. This may be
due to an incorrect or not unique filename or to a server problem. Please
note that our scripts cannot process files whose names include "jpg" or
"jpeg" in the main filename (before the dot). Example: 747jpg.jpg would
not work. Furthermore, the filename needs to be shorter than 50 characters
and fairly unique (1.jpg would be a very bad filename). If your filename
seems OK, then it's probably our problem and we ask that you accept our
apologies and please try to upload the shot again.
http://www.airliners.net/procphotos/...name=20060724_n495ca-1-olegshv.jpg
So it should be OK concerning the length and uniqueness. I'm wondering if there is a way to not count such glitches in calculations of acceptance ratio since the queue limits were cut in half and it became more important than ever.
Anyone else had something similar? Should I reupload or give up on that one?
Thanks in advance,
Oleg.
JeffM
RE: File Error - What To Do?
Tue Jul 25, 2006 12:01 pm
Was it rejected, or did it just fail to upload correctly? I don't remember hearing that upload failures count against your queue limits.
Quoting OlegShv (Thread starter):
...it's got a lot of fringing, and it appears soft to me.
OlegShv
Tue Jul 25, 2006 12:10 pm
Quoting JeffM (Reply 1):
I got a rejection email with the explanation I quoted above. I guess I would agree that it's kinda soft, but where's the fringing? I don't notice any.
eadster
Tue Jul 25, 2006 1:43 pm
Error's do go towards rejection percentages or ratios.
All you can do is reupload the shot - maybe with a different name this time around, just to rule that out as the issue.
Users browsing this forum: scbriml and 1 guest
