extremetrek
My First Time (Critique)....
Fri Aug 04, 2006 8:57 am
Greetings All!
Now that I have posting access I would absolutely love for you to take a look at my most recent rejection. By no means do I think that the rejection was in error, nor is this my favorite picture just the most recently rejected. I am merely looking to recieve hints and tips on my edit and how to improve in my editing process. I did with this the same things I do will all of my photos. Leveling, Levels, saturation, contrast, unsharp mask. My camera is the Panasonic Lumix FZ-5.
The original is here
The final edit is here
Reject reasons: Quality, Level, and Soft
Again, I completely agree and am only looking to learn from my mistakes and correct them in the future...thanks in advance!
John
Even scientists say...everything is just light...not created/destroyed but eternally bright!
eadster
RE: My First Time (Critique)....
Fri Aug 04, 2006 12:03 pm
Hi there John,
I have downloaded the original and am having a bit of a play and will let you know how I go.
extremetrek
Fri Aug 04, 2006 12:15 pm
Eadster,
Thanks for having a go at it. If its not too much trouble could you post the steps you take as well as the finalized picture? I don't plan to reupload using anyone else's edit and as I stated in the original post, would just like to use this as a learning experience.
Thanks again,
John
AJ
Fri Aug 04, 2006 2:51 pm
I had a little go at it, I think the level in your first edit was ok judging by the buildings!
N358PH
extremetrek
Fri Aug 04, 2006 3:23 pm
AJ,
Thanks for the edit...could you please post the steps you took to get to this edit? Thanks a million!
John
viv
Fri Aug 04, 2006 3:43 pm
The final edit looks good, although the crop is a bit too tight for my taste. But the tail was up against the frame on the original, so not much can be done about it.
eadster
Fri Aug 04, 2006 7:16 pm
Mine came out pretty much the same.
The steps I took are as follows (feel free to add anyone!):
Steps of PhotoShop CS2
1. Level the shot
2. Apply colour correction (image -> adjustments -> auto colour) and check histogram (image -> adjustments -> levels). Should be no flat areas at the start of the end of the graph.
3. Crop image to desired size, usuall around 1100 px wide or 1024 wide.
4. Equalise the shot to suss out any dust spots.
5. Copy the existing layer to make two layers.
6. Apply USM to top layer. (filter -> sharpen -> unsharp mask). Adjust percentage accordingly. Radius = 0.2 threshold = 0 (these will be different for different users).
7. If jaggies appear, erase these from the top layer - the smoother versions will then appear from the bottom layer.
8. Export (ctrl + alt + shift + S), making sure that the file size it not over 1mb.
That's how it comes to that...I think! Hope I have not missed anything along the way.
Anyone want to ad or remove any steps?
Hope this helps you out, John.
extremetrek
Sat Aug 05, 2006 12:33 am
Martin,
Thanks for the steps. Thats pretty much what I do as well, except checking for dust spots, which is something I am just NO GOOD at seeing. I guess in this case the problem was the original photo and not the editing steps. Thanks for the assistance!
John
eadster
Sat Aug 05, 2006 8:24 am
Only difference was AJ hadn't applied as much sharpening therefore end result was a bit better. That's all.
