walter2222
Off-center, Allowed Or Not?
Fri Aug 04, 2006 8:07 pm
Hi there,
Will this be acceptable or will it be rejected for off-center?
http://www.airliners.net/addphotos/b...060721_CRW_5992_RT8_WVB_1400px.jpg
PS: I cropped it this way because of the smoke...
Thanks for your comments (other advice also welcome)!
best regards,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
Rotate
RE: Off-center, Allowed Or Not?
Fri Aug 04, 2006 8:10 pm
As the smoke is barely visibel and not colourful or something like that - I think it is NOA_Center.
Robin
ABC
timdegroot
Fri Aug 04, 2006 8:11 pm
Quoting Rotate (Reply 1):
Yes
Tim
Alderman Exit
walter2222
Fri Aug 04, 2006 8:16 pm
Hi Robin, Tim,
Thanks for your fast replies! Much appreciated (certainly now that the queue is going so fast)!
PS: Would it be acceptable if I restart editing and crop it so it is perfectly centered?
Walter
timdegroot
Fri Aug 04, 2006 8:17 pm
I would think so if you can do so without a loss of quality.
Tim
Alderman Exit
walter2222
Fri Aug 04, 2006 8:25 pm
Thanks Tim!
I will pull this one and start again from the original! (The original was almost without any crop, so it should be feasible...).
Walter
