jckat2
Strange Landing + Comment On Photo
Mon Aug 07, 2006 1:37 pm
Hi all,
This afternoon I was at Montréal Dorval Airport and I saw a A330-300 landing with just the left engine thrust reversed. The Airplane seemed to go very slowly an I didn't hear the sound that normally make a full throttle during thrust reverse. The landing was very "soft".
Full size at http://www.airliners.net/addphotos/big/ready/CGHKX060806.jpg
The airplane stopped with no problem.
Who can explain me this landing ? Is it normal ? There was wind coming from the right of the airplane, is it possible that the engine did not revert to compensate ?
What do you think of the photo ? All comments are welcome.
Jean Christophe
[Edited 2006-08-07 06:58:40]
Newark777
RE: Strange Landing + Comment On Photo
Mon Aug 07, 2006 1:48 pm
Inversion? I assume you are talking about Thrust Reversers
And no, thrust reversers are not required for the plane to land, and aren't even factored into the landing distance equation. I don't know what the MEL for the A330 says about flying with one reverser inoperable, but it is also possible it went MX in flight.
As for the photo itself, the quality looks like it will be a problem, especially the grain.
Harry
[Edited 2006-08-07 06:51:43]
jckat2
Mon Aug 07, 2006 1:55 pm
Thank you Harry,
Yes I was talking about Thrust Reversers. If should find a better dictionary and take english lesson  Wink
But in this case, is it possible that when just one thrust reverse is working it can "unbalance" the airplane and make it going out of the runway ?
J-C
Newark777
Mon Aug 07, 2006 2:18 pm
Quoting Jckat2 (Reply 2):
I doubt the force would be strong enough to steer the plane off course, and it would be nothing the rudder and steering couldn't handle.
Harry
p51
Mon Aug 07, 2006 3:27 pm
It's also possible they just used the reverser at idle power. Nevertheless the aircraft can be handled quite good with one working reverser during touchdown and rollout. I also noticed a deflection of the rudder...
Josef
AJ
Mon Aug 07, 2006 3:31 pm
Quoting P51 (Reply 4):
Idle reverse will open the reverser door/buckets. In this case the reversers are likely locked shut due to a malfunction and subsequent deferral under an MEL. It is not at all uncommon!
skidmarks
Thrust reversers should work together and not singly. It will give the pilot some severe problems on landing as, if he was unaware that one was not working, he would have one engine trying to reverse and one at full throttle trying to go forward.
If he was aware of the problem, however, he could, in theory, just use one and not power up the opposite engine. But this I think is highly unlikely. The correct action would to be to dispense with thrust reversers completely and land using spoilers, flaps and brakes.
As for the picture, that doesn't look right to me. Shouldn't the thrust reverse ring go all the way around the engine cowl? That actually looks as if something were open rather than the TR system.
Andy  old
Growing old is compulsory, growing up is optional
Thom@s
Mon Aug 07, 2006 3:40 pm
Quoting Skidmarks (Reply 6):
The appearence of the TR system varies from aircraft to aircraft.
B737
Photo © Christian Galliker
A330
Photo © Alexander Watts
Edit: Should rather have said that the TR appearence varies from engine to engine, as these two pics of A330 shows:
Photo © Nicolas St-Germain
Photo © Pascal Gaudreau
Thom@s
[Edited 2006-08-07 08:44:30]
"If guns don't kill people, people kill people - does that mean toasters don't toast toast, toast toast toast?"
skidmarks
Mon Aug 07, 2006 4:12 pm
Indeed Thomas, you are right. However, the opening on the aircraft in question is just on the lower RH side. Even under normal circumstances this will give an unbalanced flow. Which is why I queried that it was actually a TR component.
But, as none of the aircraft I currently deal with has thrust reverse, and the last aircraft was the Nimrod some 12 years ago, my memory may be a tad rusty. Big grin And systems may have improved somewhat!
Be interested to get to the bottom of this though.
Andy  old
Thom@s
Mon Aug 07, 2006 4:23 pm
Quoting Skidmarks (Reply 8):
Get your reading glasses out Skids...  Wink
If you look closely on the large version of the image in the thread starter, you'll notice a small "tap" underneath both engines. Look just behind the "tap" on the engine to the right. Looks like part of the TR on the other side of the engine to me. In other words the reversers are working as normal on the engine to the right.
But if I'm mistaken, it wouldn't be the first time.  Smile
Thom@s
ThierryD
Head Support
Mon Aug 07, 2006 4:42 pm
Quoting Jckat2 (Thread starter):
Seems like normal operation with one thrust reverser inoperative; the inoperative thrust reverser was probably deactivated (locked) by maintenance for whatever reason and operational procedures would have the crew activate the reverser normally at idle thrust thus no sound from the engines spooling up at higher thrust.
As Harry said correctly the deceleration effect of thrust reversers are not considered in the calculation of landing distances and thus this kind of landings with only one open t/r are "normal" operation and nothing to be worried about.
Thierry
"Go ahead...make my day"
Q330
Mon Aug 07, 2006 5:09 pm
Not on an A330. Reverse thrust is activated by pulling the thrust levers back past idle. If I'm not mistaken, the levers will not move past reverse idle until the reversers are fully deployed (in this case the buckets open), so it wouldn't be possible for one engine to be going forward at full throttle in a situation like this.
-Q
Long live the A330!
jckat2
Mon Aug 07, 2006 10:34 pm
Thank you all for answer.
I just improve the image, so the first link does not work any more.
Full version : http://www.airliners.net/addphotos/big/ready/C-GHKX060806.jpg
But now the question is : If the crew did know that one engine was damaged or locked for maintenance and it is not possible to use thrust reverser if both can work, why did he tried to use it ?
I personnaly think the problem appeared at landing and the crew just did not know that before. Do you think I'm right ?
J-C
[Edited 2006-08-07 15:40:33]
f4wso
Mon Aug 07, 2006 11:28 pm
It is not common, thanks to good mechanics, but landing with one thrust reverser deferred isn't a problem with yaw. I have done it in the CRJ with no adversities. Thrust reversing is not figured into the performance data because if there is a rejected takeoff for engine problems, there is no thrust to reverse on the malfunctioning engine. Likewise, landing single engine.
Gary
Cottage Grove, MN, USA
Seeking an honest week's pay for an honest day's work
pavvyben
Mon Aug 07, 2006 11:58 pm
Quoting F4wso (Reply 13):
 thumbsup
The PIC obviously still wanted to use the other engine to slow down, compensating with the rudder which can be seen. Ive seen this on a 737 coming into LHR before.
ThierryD
Head Support
Tue Aug 08, 2006 12:09 am
Quoting Jckat2 (Reply 12):
Maybe because, like in some other planes, activating the thrust reverser also deploys the liftdumpers (spoilers), should they not deploy automatically when touching down. By not activating the thrust reversers, even if they know one doesn't work, they would deprive themselves of this additional security measure.
Thierry
pavvyben
Tue Aug 08, 2006 6:08 am
Quoting ThierryD (Reply 15):
Spoilers deploy as soon as the wheels touch the ground. Remember that some planes quite often don't use reverse thrust, just use the autobrake and spoilers. Quite often you will find a plane rolling out without reverse thrust just at idle throttle (well quite alot of BA stuff).
ThierryD
Head Support
Tue Aug 08, 2006 6:21 am
Quoting Pavvyben (Reply 16):
Yep, but sometimes they don't for whatever reason and there are planes which, as a backup, deploy them "manually" with the activation of the reversers in case they do not deploy automatically.
Thierry
pavvyben
Tue Aug 08, 2006 6:49 am
Well if you want to deploy them manually, you pull the lever next to the throttle quadrant on a Boeing aircraft at least, an Airbus is fairly similar to. There is a detent on the 747 in which you can pull it to a certain point during flight to slow the aircraft down, for example when given a speed restriction. Then "Up" when you are on the ground, which the FO makes sure that has happened. If not, they will do it. And if they don't do this very quickly, you hit the TOGA button on the throttle and go around  Smile or they can just increase the autobrake on a Boeing or Airbus, from MED (Airbus) or 2 (Boeing) which is normally used to MAX (Airbus) or 3-5 (Boeing) which will increase braking on the wheels.
[Edited 2006-08-07 23:52:02]
ThierryD
Head Support
Tue Aug 08, 2006 7:38 am
Quoting Pavvyben (Reply 18):
Well if you want to deploy them manually, you pull the lever next to the throttle quadrant on a Boeing aircraft at least, an Airbus is fairly similar to. There is a detent on the 747 in which you can pull it to a certain point during flight to slow the aircraft down, for example when given a speed restriction. Then "Up" when you are on the ground, which the FO makes sure that has happened. If not, they will do it. And if they don't do this very quickly, you hit the TOGA button on the throttle and go around or they can just increase the autobrake on a Boeing or Airbus, from MED (Airbus) or 2 (Boeing) which is normally used to MAX (Airbus) or 3-5 (Boeing) which will increase braking on the wheels.
I guess someone's been playing too much MS Flight Simulator...  Embarrassment
Thierry
pavvyben
Tue Aug 08, 2006 7:47 am
Quoting ThierryD (Reply 19):
hehe, or knowing a few BA pilots helps  Smile
paparadzi
Tue Aug 08, 2006 4:36 pm
There is no problem using he thrust reverser only on one engine as long as there is no slippery runway or strong crosswind. You should open up the operative TR slowly to give you time to counteract any yaw with the rudder.
I've landed the 737 with single reverser many times before.
Rules are made for the guidance of wise men and the obedience of fools.
jckat2
Mon Aug 14, 2006 1:38 pm
Thank you all.
Finally the photo was rejected because :
"The image quality of these photo(s) does not meet the very high standards
of Airliners.Net."
http://www.airliners.net/addphotos/r...ions/big/20060812_C-GHKX060806.jpg
Some advise to make it good enough for Anet ?
Thank you
J-C
