coninpa
Canon Converter 1,4x With 100-400 L Is F/5,6
Wed Aug 16, 2006 2:35 am
Hi all,
I have the Canon 100-400 f/5,6 L IS lense.
Can you comment on your experience with the combination of this lense with a Canon converter 1,4x II, regarding the quality of the image, autofocus, etc ?
Any other suggestion welcome.
Thanks in advance
Patrick
Patrick De Coninck
Smalbany
RE: Canon Converter 1,4x With 100-400 L Is F/5,6
Wed Aug 16, 2006 2:46 am
I have the 1.4TC and use it with the 70-200 F4. It works well on the 300D.
With the 100-400 I believe that AF will only work on a 1 series body. Since the 100-400 is known to be a little soft at the 400 end, I would imagine that the TC would make that worse.
I have not heard of any aviation photographers that have used the combo with success (at least anet standards).
aero145
Wed Aug 16, 2006 3:15 am
 redflag  no
Photo © Javier Guerrero - AirTeamImages
Javier Guerrero has done it!
I think you can get some auto-focus by taping some contacts on the Extender... I don't know which contacts, you can find that out on the net.
But AFAIK it isn't an extremely successful thing.
NSMike
Wed Aug 16, 2006 3:43 am
I've tried the tape thing, but the AF hunts a lot and the image quality isn't there in my opinion.
Pearl Snares, Taye Drums, Sabian Cymbals, Remo Heads, Los Cabos Sticks
Tin67
Wed Aug 16, 2006 3:54 am
I was at Farnborough and chatting to a guy who was using a 1Ds with a 100-400 and 1.4 extender. As mentioned above the EOS 1 range will autofocus with this combo and he claimed he was getting good results.
I wouldn't want to use manual focus though!
coninpa
Wed Aug 16, 2006 5:00 am
Quoting Tin67 (Reply 4):
Do you know if anyone has used the EOS 5D (my body) with that combination ?
Patrick
Patrick De Coninck
javibi
Wed Aug 16, 2006 7:38 am
Quoting Coninpa (Thread starter):
AF: you may try the tape trick, but I think you'd better learn to use MF, as AF will work poorly. The trick is described here:
www.fredmiranda.com/TipsPage/
As for quality, it does suffer, but if you are not only shooting for A.net, you'll find the increase in range (for a relatively low price) is worth it:
www.airteamimages.com/33659.html
www.airteamimages.com/33634.html
My 2 cents
j
birdlike
Thu Aug 17, 2006 1:21 am
My experiences with the 100-400 + 1.4 Canon converter (on a 5D) are not satifying for A-net use. MF is not fast enough for flying aircraft, unless you are very trained. So I think it would bring you more quality to crop than to make your lens more "powerful" by help of a converter.
We fly to find out that the birds are more elegant than us ...
coninpa
Thu Aug 17, 2006 4:27 am
Thank you all for your advices and opinions.
Patrick
Patrick De Coninck
planedoctor
Fri Aug 18, 2006 12:23 am
I've used the 1.4x on the 100-400 IS and I was not satisfied with the results overall. The shot shown above by Javier Guerrero is fantastic, but for a long exposure he may very well have stopped it down on a tripod for the 6 second exposure, in which case the image quality would be much improved over the wide-open shooting you'd typically be doing while hand-holding the lens.
Ken
timdegroot
Fri Aug 18, 2006 12:29 am
I've used it and when you focus correctly it isn't all that bad. You also need stop it down quite a bit to eliminate at least some vignetting.
Photo © Tim de Groot - AirTeamImages
It's ok to try it sometimes, but I would never ever count on it as something I'd shoot with all day. You just lose to many shots using MF, which is a pain on the 100-400 especially when extended at 400mm.
Like Javier said, it's ok to try different things which will most likely not make in onto a.net.
Tim
Alderman Exit
coninpa
Fri Aug 18, 2006 5:15 pm
Nice shot though Tim ! I definitely have to go to Schiphol...
Thanks again all. I'll not buy it... Other forums have basically the same opinion and a friend pro photographer has got too many problems with it and stopped using it.
I'll spare money to buy another longer lense... Sad
Patrick
Patrick De Coninck
Users browsing this forum: hkg82 and 1 guest
