yultopei
Another Crazy Rejections.
Wed Aug 16, 2006 6:55 am
Another time, i ask you guy's what i can do with my last rejection batch...
Brand new Canon 30D, L glass series but still have complete batch rejection !!!
Can you help me ??????
Thoses 2 are rejected for over exposed... and i don't understand why!!
http://www.airliners.net/addphotos/rejections/big/20060815_30D7aout06119PH-BFC.jpg
http://www.airliners.net/addphotos/rejections/big/20060813_30D7aout06030F-GISE.jpg
And this one for level... the vertical line are perfect ???
http://www.airliners.net/addphotos/rejections/big/20060813_30D7aout06196G-YMMG.jpg
Any advice are welcome.
PEI in Colombia!!!. [Canon T2i]
bubbles
Crew
RE: Another Crazy Rejections.
Wed Aug 16, 2006 6:59 am
Quoting YULtoPEI (Thread starter):
I feel it needs slight CCW rotation.
Air France looks a bit overexposed.
_Hongyin_
[Edited 2006-08-16 00:04:17]
waketurbulence
Wed Aug 16, 2006 7:01 am
The over exposed shots don't look too bad from my screen. I can say they are a little bright, but I wouldn't say too bad. The level rejection needs some CCW rotation, but that was just an eyeball, not using photoshop.
-Matt
B076
Wed Aug 16, 2006 7:16 am
KLM shot is over exposed on the tail and overall to bright.
Air france shot is over exposed on nose and mid section of fuselage and look a bit soft on my screen.
BA shot need some CCW rotation as mentioned and looks soft.
Hope this helps
Just my  twocents
William
bottie
Wed Aug 16, 2006 7:20 am
That's still no guarantee for having top-shots ...
AF is overexposed, especially nose and in the middle
KLM, the tail is on the limit, maybe a little over the limit
Bram
norfolkjohn
Wed Aug 16, 2006 7:49 am
Both the KLM and Air France shots are overexposed. The whites are too bright. If the shots were taken in RAW it may be possible to correct this by going back to the original files. If they were taken in .jpg format there is scope for some adjustment through levels in PhotoShop but I fear this will not quite produce a good enough result.
There are a few things you can do to reduce the chances of overexposure / excessively bright whites. Firstly you can try setting a little under exposure compensation. This is what I do in bright lighting conditions and I find that minus one third of a stop works in most cases. As mentioned above you can shoot RAW and then try to correct the exposure at the post processing stage. (I don't do this as I find it harder than sorting the exposure in the camera). You can also look at the white balance setting on the camera and perhaps use a custom white balance setting based on a standard grey card. (Details are in the camera instruction book). Finally the method most likely to achieve genuinely correct exposure in the camera would be to use a separate hand held incident (as opposed to reflected) light-meter.
I stick with a little exposure compensation and careful adjustment of levels in PS. I only have Elements 2 and am no expert on the editing front but I usually manage a satisfactory result via this route.
Apart from the exposure issues I would say that all three shots are a bit softish and could stand a further kick of sharpness. There are also dust spots visible on the KLM and Air France shots. If you can't see them equalize the images and you will not be able to miss them.
I would agree that in the BA shot the verticals are vertical but the shot feels like it is not level. This is an old debate but within reason you just have to go with what looks right. I am no Screener but in this case I would not have given a rejection for level but would not have been happy with the sharpness or the fact that the horizontal tail fin had been cut off.
My thoughts for what they are worth.
All the best,
John
One thorn of experience is worth a whole wilderness of warning.
yultopei
Wed Aug 16, 2006 8:02 am
Thank you guy's for your fast reply...
I will try another time for sure, but for the overexposed, i think is really, but really small overexposed.
Sometime i really not understand screeners eyes.
maybe a answer of a screeners can clarify this situation.
JeffM
Wed Aug 16, 2006 9:36 am
Learn not to use your camera's exposure. Those shots are overexposed, it's easy to see why too.
NicolasRubio
IMHO, they are not crazy rejections but fair... With a 30 seconds work on each photo I got to this...
http://img96.imageshack.us/img96/5291/2006081530d7aout06119phbfcsy7.jpg
http://img96.imageshack.us/img96/4874/2006081330d7aout06030fgiseea7.jpg
http://img96.imageshack.us/img96/5980/2006081330d7aout06196gymmgnl4.jpg
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
GVerbeeck
Wed Aug 16, 2006 10:23 am
Quoting YULtoPEI (Reply 6):
I guess the other contributors summed it up fairly well, but here you go:
- the BA's angle looks odd even though the verticals appear to be more or less ok.
- the AF and KL are overexposed and soft.
No crazy rejections here IMO.
Giovanni
IL76
Wed Aug 16, 2006 2:42 pm
Quoting NicolasRubio (Reply 8):
I have no idea what you did there, but the first two planes look like they have military camouflage colours now.
