airkas1
Crew
How To Get Rid Of These Jaggies?
Mon Aug 21, 2006 3:52 am
Hi all,
I took the following shot today in a bit of nast yweather:
http://www.airliners.net/uf/view.fil...3132&filename=1156099500semT64.jpg
The hor. stab. has some major (IMHO) jaggies and also the engine pylons aren't that jaggiefree. These jaggies appeared before sharpening, about right after I resized the image.
I was thinking about uploading, but I think these jaggies are killing it. How did they get there and how can I remove them?
Many thanks,
Kas
Airliners.net Crew - Head Photo Screener
diezel
RE: How To Get Rid Of These Jaggies?
Mon Aug 21, 2006 4:07 am
Hey Kas, nice pic (and nice plane)!
The jaggies are kind of disturbing (at least to me). I don't know if you did but this picture is the ideal candidate for shooting in RAW. You then could have set the sharpening to none and work with layers to sharpen all parts of the airplane as necessary.
Roel.
Never be afraid of what you like. (Miles Davis)
9VSPO
Mon Aug 21, 2006 4:15 am
Is there any way you could post the original for people to have a look at?
bottie
Mon Aug 21, 2006 4:23 am
I had sometimes the same problem. Try to resize in small steps:
eg: 3000 - 2750 - 2500 - 2250 - 2000 - 1750 - 1500 - 1250 - 1200
That helped for me
rgrds,
Bram
airkas1
Crew
Mon Aug 21, 2006 4:39 am
Quoting 9VSPO (Reply 2):
I've tried to upload it, but it's 2.4M, too big for the a.net photo upload.
Quoting Bottie (Reply 3):
I'm trying this as we speak. After I'm done I'll let you all know if it worked.
Kas
9VSPO
Mon Aug 21, 2006 4:45 am
Quoting AirKas1 (Reply 4):
Just open a free account at www.flickr.com and you can link from that.
airkas1
Crew
Mon Aug 21, 2006 4:49 am
That helped for me
It helped me aswell!! It's fixed, thank you very much Bram!  praise
Quoting 9VSPO (Reply 5):
Thanks Ian, I'll do that to make sure I can link in the future!
Kas
bottie
Mon Aug 21, 2006 5:30 am
Quoting AirKas1 (Reply 6):
Glad I could help, Kas  Smile
jumbojim747
Mon Aug 21, 2006 8:32 am
I noticed resizing in steps you lose a pixel.
For instance when you re size in steps to
1200-800 = 1200-799
1024-683 = 1024-682.
Not sure why this happens and not sure if its enough for a size rejection.
On a wing and a prayer
aero145
Mon Aug 21, 2006 11:09 am
Hey Kas.
Do you shoot RAW?
If you do, I'm surprised that you get jaggies. I was just editing a bunch of RAW pictures today and the photos were too soft...
No jaggies at all!  Confused
Stealthz
Mon Aug 21, 2006 11:44 am
Quoting Aero145 (Reply 9):
Do you shoot RAW?
Was going to ask the same question, if not RAW what sharpness level to you have you in camera jpg processing set to?
I tried a RAW image and a 0 sharpness JPG and could not produce enough jaggies to evaluate Bram's technique.
Chris
dlednicer
Crew
Mon Aug 21, 2006 2:03 pm
Quoting JumboJim747 (Reply 8):
1200-800 = 1200-799
I did get a size rejection on that and learned to check my final size after using progressive resizing. I make sure the last resize has one dimension correct (eg. 1024) and the other too big. Then I switch the marquee tool in Photoshop to fixed size (set to the 1024x768) and crop one more time.
bottie
Mon Aug 21, 2006 4:36 pm
When resizing, I always stop at 1203 x .... (I mostly upload at 1200x800), Final step for me is 'Canvas size', that way I avoid also bad_borders (eg. 1203 x803 becomes 1200x800)
airkas1
Crew
Mon Aug 21, 2006 8:44 pm
1200-800 = 1200-799
Hmm, You're right! It's indeed 1024x682.
Do you shoot RAW?
The photos from yesterday weren't shot in RAW.
Quoting StealthZ (Reply 10):
I'm not sure what you're talking about. Sharpening the image in the camera? I haven't touched anything regarding that, so it's probably at standard.
Anyways, I might have to retry tomorrow, as it's scheduled for the 22th again  Smile
-Kas
Stealthz
Mon Aug 21, 2006 9:02 pm
Quoting AirKas1 (Reply 13):
Then with all due respect you need to read your camera manual.. the JPG settings in your camera have several sharpening settings and depending on which camera model you use the standard settings may or may not be appropriate for aviation photography.
linco22
Tue Aug 22, 2006 12:41 am
I dont personally shoot RAW alot, but I have never really found sharpening an issue in RAW. I cant say that RAW images are softer from the camera. Take off an in-camera shapenning for sure just to be safe. YOU choose the level of sharpness in the RAW image. YOU control it.
The resizing steps is very interesting. Something i've never tried and never really had too. I'll bear it in mind next time I have trouble.
Colin  Smile
airkas1
Crew
Tue Aug 22, 2006 3:23 am
Quoting StealthZ (Reply 14):
Hi Chris,
I couldn't find it in the manual, but I checked it in the menu of my camera. The sharpness is standard, the meter stands right in the middle.
I have a Canon 300D, is this setting suitable for aviation photogrpahy?
-Kas
Stealthz
Tue Aug 22, 2006 8:31 am
Kaz,
I beleive that is the appropriate setting, perhaps someone with a 300D can confirm.
For your reference the 300D English language Manual has a section on Setting Processing Parameters on page 55
Chris
Users browsing this forum: Yahoo [Bot] and 1 guest
