EZYAirbus
Motiv Problem?
Mon Aug 21, 2006 4:36 am
I spent yesterday at AMS and see JAL Cargo 747 taking off, i decided to shoot it with AMS tower in too, would it get reject for motiv? also is quality ok for Anet?
http://www.airliners.net/uf/view.fil...2248&filename=1156102096pR0z6O.jpg
Glenn
http://www.glenneldridgeaviation.com
9VSPO
RE: Motiv Problem?
Mon Aug 21, 2006 4:42 am
Quoting EZYAirbus (Thread starter):
I like it but as you probably know it's getting harder and harder on here to pics accepted. Given the quality required I would say the aircraft is a bit too far away.
JRadier
RE: Motiv Problem?
Mon Aug 21, 2006 4:56 am
Quoting 9VSPO (Reply 1):
image quality and distance are 2 totally difirent things. I let some more expirienced people give some comment tho.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
bottie
RE: Motiv Problem?
Mon Aug 21, 2006 5:27 am
I think a bad_distance is possible, also bad_centered. The plane isn't in the middle because the tower 'has to be' in the picture to make it a special picture. For me, just crop the plane, drop the tower  Smile
jumbojim747
RE: Motiv Problem?
Mon Aug 21, 2006 6:46 am
Glenn i would crop the wing tip out all the way to the engine and that way it would be easier to center it with the tower providing you have more room to work with in the original .
Also the contrast is very high i would tone it down a bit.
Nice shot and good luck with it.
On a wing and a prayer
eadster
RE: Motiv Problem?
Mon Aug 21, 2006 8:27 am
And sharpen it - it's heaps soft here.
