nucky
Nikkor 80-400VR...mode 1 Or 2
Mon Aug 21, 2006 10:43 pm
Could anyone out their please explain the difference between the VR modes 1 and 2, and which mode you find best for our purpose?
I have very recently obtained the lens and I'm still not sure even after much research!
Many thanks for any guidance/advice offered?!
Best regards...Paul. confused
clickhappy
RE: Nikkor 80-400VR...mode 1 Or 2
Mon Aug 21, 2006 10:46 pm
Vibration reduction is turned on and off via a three position switch on the left side of the lens. VR mode 1 reduces vibration from the moment the shutter is lightly pressed and the meter is activated. This allows you to see the effect in the viewfinder. Mode 2 only activates VR when the shutter is fully depressed.
skidmarks
Mon Aug 21, 2006 11:09 pm
Paul, I use Mode 2 simply because I dislike the view when the VR kicks in - the image seems to jump slightly and I find it offputting.
Best thing to do is take it out someplace and experiment. Try not to use it anywhere you could get arrested for being a pervert or peeping tom though!! Big grin
Andy  old
Growing old is compulsory, growing up is optional
nucky
Mon Aug 21, 2006 11:29 pm
...thanks for the replies chaps.
I appreciate your concern Andy....nor would I want to be considered a threat to the countrys security!!!! wink
Any more offers/suggestions?
psyops
Tue Aug 22, 2006 12:38 am
The only other advice I would give would be contrary to what you have gotten already. Mode 1 allows the VR to stabilize better before the shutter fires. I have read that using mode 1 gives better "results" as the system has more time to stabilize the picture.
If you can live with the "jumpy" viewfinder image, mode 1 will give better results.
Pete
redfox
Tue Aug 22, 2006 1:14 am
Use mode 1, stabilisation when shutter button half depressed always as it takes VR several seconds to fully stabilise. I have not seen mode1/mode2 on any other VR Nikkor. I believe 80-400 f4.5-5.6 was the first VR Nikkor.
Forget about mode 2.
My copy did not have a jumpy image using mode 1 the image should be static during mild vibration due to camera shake. It actually works very well in windy conditions.
[Edited 2006-08-21 18:15:37]
Kereru
Tue Aug 22, 2006 10:21 am
I use it as follows:
Jets and fast moving objects Aperture Priority f8 setting VR off above 1/500th second.
Prop aircraft Shutter Priority set between 1/200 - 1/30(depends on what effect I want) VR on mode 1 and pan with action.
I haven't used mode 2 as yet.
On the 70-200 VR lens the second mode is used when you are in a vehicle and need VR on both vertical as well as horizontal axis. Correct me if I am wrong and this doesn't apply to the 80-400 lens?
Colin
Good things take Time.
nucky
Wed Aug 23, 2006 11:10 pm
...thanks again for your replies...I'm hoping to get more practice in over the next few days?! thumbsup
