aero145
Contrast Rejection... Could Anybody Help?
Wed Aug 23, 2006 1:52 am
Ahoy guys.
I just got a very (IMO) strange contrast rejection... It seems that sun+me means bad contrast...
http://www.airliners.net/procphotos/...e=20060822_N90MB-9514-15082006.jpg
Could you tell me your opinion?
Aero145
clickhappy
RE: Contrast Rejection... Could Anybody Help?
Wed Aug 23, 2006 1:53 am
not sun, but high, mid-day sun.
Also your shoot is not level.
aero145
Wed Aug 23, 2006 1:59 am
Not level? Where do you see that?  confused
bubbles
Crew
Wed Aug 23, 2006 2:07 am
Quoting Aero145 (Reply 2):
Not level?
Hi David,
I agree with Royal. I feel the image needs a bit CW rotation.
_Hongyin_  wave
aero145
Wed Aug 23, 2006 2:12 am
OK CW it is then.
Thanks very much!
 wave
TZ
Wed Aug 23, 2006 2:13 am
The image is quite dark (check your histogram for the white end of the spectrum). The sun was not side-on to the aircraft, which has caused problems.
But most of all, as Royal says the sun is high in the sky and that always causes issues with unpleasant contrast. Try the shot a few hours earlier in the day (or a fair bit later) for a much nicer result.
TZ
TZ Aviation - Aeropuerto de los Banditos Team Images
aero145
Wed Aug 23, 2006 2:51 am
Quoting TZ (Reply 5):
Thanks very much!
I wasn't there earlier, because I sleep so much. :-P The pic. was taken at 12 AM, and I like to spot then. But - as you said - it is better to spot earlier in the mornings... So... I'll do as you advised.  Smile
David
PS: Salvagable, or just for the personal collection?
http://www.airliners.net/uf/view.fil...0831&filename=1156267725uT8eRh.jpg
