flamedude707
What Settings Do You Use At Night?
Sun Aug 27, 2006 6:15 am
I have always been amazed by some of the fantastic shots that come to this website that are taken inthe late eveing and at night. What settings are optimal, say for shots like this one here, which by the way is excellent.
Photo © Jason Bisson
Time you enjoy wasting, is not wasted.
aero145
RE: What Settings Do You Use At Night?
Sun Aug 27, 2006 8:10 am
When I shoot at night, I tend to put the aperture to 7.1 or 8, and use mirror lockup and a remote control, in Av mode. Then I shoot, and hope for luck.
Maybe that's not the right way, but it is the way I use, and it works for me...
jumbojim747
Sun Aug 27, 2006 8:28 am
Quoting Flamedude707 (Thread starter):
They are achieved in the way of Timed exposures for instance 10-20-30 second exposures.
With a tripod and very low ISO settings to help reduce the grain and noise.
On a wing and a prayer
NicolasRubio
Sun Aug 27, 2006 1:48 pm
In my case, I only shot two photos at night with my SLR (see my signature)...
The first time, I used f/8 and 6 seconds of exposure, and the second time I used f/11 or f/13 (I can't remember) and an exposure of 30 seconds... No mirror lockup, no remote control and M mode (all manual)...
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
flamedude707
Mon Aug 28, 2006 11:48 am
dumb question, i know, but I'm still not very knowledgable w/ all this stuff. How do you setthe exposure. Is that the same thing as the shutter speed?
Lanas
Mon Aug 28, 2006 12:53 pm
Quoting Flamedude707 (Reply 4):
No, shutter speed indicates how long the shutter remains open for capturing the image. Together with the aperture they are the variables that you have to control in order to set the exposure to your requirements. The aperture represents the diameter of the light that reaches the sensor. The bigger the diameter, the more light that you get in your pic. The slower the shutter speed, the more light you allow to feed your capture.
The aperture values are measured using the f numbers (f2.8, f4, f5.6, and so on...). By increasing the f number the diameter gets smaller. The shutter speed is measured in seconds.
You can also increase the ISO level for a better lighting configuration, but doing so might decrease the quality of the picture.
My two cents. Hope it helps.
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
maiznblu_757
Mon Aug 28, 2006 2:46 pm
Quoting JumboJim747 (Reply 2):
Alan, how could you leave the 205 or 180 second exposure out?!?!  Wink
flamedude707
Tue Aug 29, 2006 10:02 am
question... when my camera says 30'' on the screen under Tv (shutter priority) is that a 30 secnd exposure?
Also, people have said that when I am in Tv mode, the camera adjusts the aperture automatically. How do I change that to allow mysef to use a certain aperture say f8 or f11?
Lanas
Tue Aug 29, 2006 10:37 am
30" means 30 second exposure.
Shutter priority lets you program the shutter speed and the camera then compensates the exposure with the aperture value.
If you want a specific aperture value you should switch to Aperture Priority or Manual function.
Cheers!
Lanas.-
flamedude707
Tue Aug 29, 2006 10:40 am
would the aperture the camera sets give me good results on shots at night like that?
Moose135
Tue Aug 29, 2006 10:45 am
Yes, that means the shutter will be open for 30 seconds
You can shoot in Manual mode - that will allow you to set both shutter speed and aperture.
Lanas
Tue Aug 29, 2006 10:55 am
Quoting Flamedude707 (Reply 9):
Yes, I believe it´s better to control the aperture while at night. I´ve never done night shots, but I believe it must be that way. Maybe someone can enlighten you better.
Cheers!
Lanas.-
flamedude707
Tue Aug 29, 2006 12:08 pm
I should probably find this out from someone who can see my camera but just wondering, on most Canon film SLR's, I have a EOS Elan 2, howdo you set it to manual mode?
Thanks in advance. You guys have been very helpful.
Stealthz
Tue Aug 29, 2006 12:09 pm
NO
Quoting Lanas (Reply 11):
Not quite enough you need to control Aperture AND shutter speed
Quoting Moose135 (Reply 10):
Yes you do need to shoot Manual.
If you shoot in Aperture mode the camera will set a shutterspeed that will result in an average properly exposed picture.
Sample A set at 30sec f22 manual exposure-
Big version: Width: 800 Height: 542 File size: 66kb
Sample B if shot in aperture priority the result would be something like this-
Big version: Width: 800 Height: 542 File size: 231kb
(Disclaimer: Sample B was produced in Photoshop using levels but gives an idea of what the camera would attempt if set Av mode)
Chris
flamedude707
Tue Aug 29, 2006 12:23 pm
Thank You A ton for all the insight.
One more question? After all of this that I have learned, should I use flash on these? I would be using just the internal built in one.
[Edited 2006-08-29 05:33:53]
Stealthz
Tue Aug 29, 2006 12:51 pm
Quoting Flamedude707 (Reply 12):
On the Elan 2 which was called an EOS 50 in the "outside" world the program dial is on the left of the upper body(holding the camera in normal picture taking mode) it has some pictographs and an L in a red square(Lock) then the Creative mode settings. P-Program, Tv- Shutter prority, Av-Aperture priority and M-Manual, just rotate that dial to M and set shutter with the wheel behind to the shutter release and the aperture with the command wheel on the back.
There are some other settings, DEP & CF that are beyond this discussion.
(Note to DSLR users ... damn I love the simple controls on the EOS 100/50 series of film SLRs!!)
Quoting Flamedude707 (Reply 14):
No, unless there is something quite close (a few feet) in the foreground that you wish to illuminate but mixed flash/time exposure photography is whole new skill that is best left until you ave some grasp of the basics.
Users browsing this forum: vikkyvik and 1 guest
