jumbojim747
Struggling With The Sharpening Advice Wanted
Tue Aug 29, 2006 7:24 am
I just had a lot of rejections for SOFT can i please get some advice how this shot looks after i have given it another kick of USM this new monitor is a bit difficult in judging the right amount of sharpening that i need.
This is the rejected shot 1 from 4 in a row for the same reason thats why im asking this time
http://www.airliners.net/addphotos/r...g/20060828_g-bnlb090806sydalan.jpg
And this is the new version.
http://www.airliners.net/uf/view.fil...6234&filename=1156803754NXemAq.jpg
Any help will be appreciated
On a wing and a prayer
Woody001
RE: Struggling With The Sharpening Advice Wanted
Tue Aug 29, 2006 7:30 am
I can see a clear difference, the second one is much sharper.
I wouldn't add anymore though around the edges, it is on the verve of showing 'halos' now.
It may take a little more fine selective sharpening around the front windows and nose area, which still looks a little soft.
Best of luck with it,
Ian.
If I could just get the afterburner working...
JeffM
Tue Aug 29, 2006 7:32 am
I like the second attempt better, with the exception of the halos around the lettering. Are you sharpening the entire image? If so, don't.
Lanas
Tue Aug 29, 2006 10:52 am
I agree with Jeff. Too soft the rejected, better the second one but oversharpened titles.
I was wondering, Alan: Did the rejected one look sharp in your new monitor?
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
jumbojim747
Tue Aug 29, 2006 1:38 pm
Ian, Jeff and Lanas..
Thank you i appreciate your comments.
Quoting Lanas (Reply 3):
Actually yes it did but that image was edited on my old monitor but when i viewed it on the new one before it went into screening it looked fine.
I think this is a gray area that i need to get my teeth around otherwise it will cause me to be put off uploading .
eadster
Tue Aug 29, 2006 1:52 pm
Hey Jimmy,
I too agree, the second image is the best. Too me the first one looks as though it was resized off the camera then uploaded!!
Quoting JumboJim747 (Reply 4):
I agree with this too. What I would like to know is whether screeners use CRT or LCD monitors. This would then determine how much sharpening is needed.
IL76
Tue Aug 29, 2006 3:07 pm
I don't think this is a 'soft'-case, I think this is a 'blurry'-case. The shot looks a bit blurry to me and I'm not sure if more sharpening will/can correct that without getting jaggies or halos.
E
jumbojim747
Tue Aug 29, 2006 9:29 pm
Martin and Eduard thanks for your input .
Maybe the shot is blurry but its just i seem to get everything rejected for soft.
But i will keep going and try to sort this mess out.
Cheers and thanks one again to all who replied
Users browsing this forum: Baidu [Spider] and 6 guests
