malandan
Sharpening In Photoshop
Sun Sep 03, 2006 4:05 am
Apologies if this subject has been raised previously but a search revealed nought.
I've had a moment of uncertainty regarding the settings to use when sharpening the final image.
I looked among the various processing procedures that have been published in the forums and there appears to be significant variation, namely
Radius 0.4 Threshold 0
Radius 0.3 Threshold 3 recommended twice
Radius 0.3 Threshold 0 recommended twice
Radius 0.2 Threshold 0
Would anyone care to comment as to these settings and is there an obvious preference?
Malcolm.
My interest lies in the future as I am going to spend the rest of my life there!
Psych
RE: Sharpening In Photoshop
Sun Sep 03, 2006 4:26 am
Hello Malcolm.
Everyone seems to have their favourite where this is concerned, but after various adventures I settled on 0.2 and 0, and I feel it serves me well. Generally I begin with the settings 500%, 0.2 and 0.
That's what I would recommend.
All the best.
Paul
ChrisH
Sun Sep 03, 2006 4:50 am
Easiest way is to use your eyes? I never understood the fascination with always sharpening using set values. Each shot requires its own setting
what seems to be the officer, problem?
malandan
Sun Sep 03, 2006 5:50 am
Quoting Psych (Reply 1):
Thanks Paul.
Quoting ChrisH (Reply 2):
Sounds suspiciously like a put-down Chris!
Are you saying that you can look at an image and decide that it needs 0.2 and 0 or 0.3 and 3?
As regards the percentage, you have to start somewhere and work progressively, logically using diminishing values.
I strongly suspect that most of us use fixed radius and threshold values and I was interested to know what these were.
Maybe film should be treated differently to digital?
Anyone else care to comment?
Malcolm.
dendrobatid
Sun Sep 03, 2006 6:07 am
The threshold certainly needs to be higher than 0 with scanned film to avoid oversharpening the grain though increasing it reduces the efficacy of USM so being counter productive at high levels.
The photoshop book says,
Scans made from 35mm film originals may benefit from being sharpenedwith a higher threshold setting than would need to be applied to a 120 film scan.
As to sharpening with set values, whilst I agree that each shot needs its own, they are a variation on a theme in my mind. I have a set value that I increase or reduce a bit to suit the image.
I use CS smart sharpen around 80% at 0.3 as my starting point.
Mick Bajcar
garry
Sun Sep 03, 2006 6:12 am
Hi Malcolm - I've wondered about this myself and like Paul have 500, 0.2 and 0 as the starting settings.
A point perhaps you may also consider is what the sharpness settings are in the camera itself. Perhaps its the combination of this setting and the subsequent setting in Photoshop that may be of interest. For example, if the sharpness is turned off in camera, or to its lowest setting, it would be reasonable to assume that additional sharpness would be required while editing. Similarly, a modest application of sharpening in camera may require less in editing.
I'm not sure there is a right or wrong answer, i for one, have recently had a photo rejected for oversharp, only then to have it subsequently rejected for soft.
 worried
www.garryridsdale.com
ChrisH
Sun Sep 03, 2006 6:54 am
Quoting Malandan (Reply 3):
yes of course, just drag the sliders and look at the image, look for a good overall look and presto. If you see jaggies, paint them away with history brush or use the duplicate layer technique.
aviopic
Sun Sep 03, 2006 7:21 am
Quoting Malandan (Thread starter):
My first comment would be "do not use PS usm in the first place" Malcolm.
My second comment "there is no fixed setting".
Every lens needs a different usm setting as does a change in distance, camera setting, light circomstances and so on.
Without a dedicated tool like Fred Miranda's Sharpening Pro it will remain a case of trial and error in my view.
Willem
The truth lives in one’s mind, it doesn’t really exist
Airplanepics
Sun Sep 03, 2006 7:43 am
Quoting Aviopic (Reply 7):
I agree with Willem, take a look at third-party sharpen plug-ins. I've just tried out a plug-in called Focal Blade, and now love it!
Simon.
Simon - London-Aviation.com
Newark777
Sun Sep 03, 2006 9:47 am
Photography is an art, not a science. Good luck trying to blindly enter settings in and hoping to get the best results.
Harry
malandan
Sun Sep 03, 2006 6:34 pm
Sorrry but I am unable to reply using the “quote selected text” function due to a modem problem.
Thanks, Mick, for a helpful response, and I understand the point about variation. Unfortunately I am using Elements so do not have access to “smart sharpen”.
Gary, I always keep the in-camera sharpening turned off, preferring to have greater control over the sharpening process even if it results in an increase in process time.
I understand the point you are making Chris, and will not deny the part that the Mark 1 eyeball plays in the process, but you continue to ignore my original question. The sharpening function in Photoshop requires the entry of values in to the parameters. I was looking for guidance as to what values to choose, even as a starting point
Willem’s and Simon’s suggestions are appreciated and I will certainly have a look at the software you refer to.
“Photography is an art, not a science. Good luck trying to blindly enter settings in and hoping to get the best results.”
Like the man said, Harry – “you can’t be serious”
Also it is rather an insult to suggest that I may be “blindly” and “hoping”, just the type of words which set so many threads spinning off in the wrong direction, but I refuse to rise to your bait.
How often have we seen threads raised by individuals who have purchased the right equipment but who lack the knowledge to process their results to acceptable levels. That surely is the science bit. The relationship between speed and aperature, depth of focus, exposure, and so much more, are surely also the science part of our activities. A camera is merely a tool which without an understanding of its function and potential, the achievement of photographic artistic aspirations is unlikely.
Malcolm.
flybhx
Sun Sep 03, 2006 7:10 pm
I saw a letter in a magazine this week which suggested that using high pass was better than USM. Any comments on the use of this for aviation subjects?
aviopic
Sun Sep 03, 2006 7:36 pm
Quoting Newark777 (Reply 9):
The "art" part is a nice bonus for interesting idea's but you still need the "math" to make it work.
Without the right numbers you are left with just nice idea's but nothing usable.
Quoting Malandan (Reply 10):
"Photography is an art, not a science. Good luck trying to blindly enter settings in and hoping to get the best results."
Like the man said, Harry -- "you can't be serious"
 checkmark
Willem's and Simon's suggestions are appreciated and I will certainly have a look at the software you refer to.
To my best knowledge USM works on a contrast difference, noise is also a difference in contrast.......... I am sure you can feel it coming Big grin
USM enhances noise as well and apart from that it sharpens everything in the frame which is usually unwanted.
With the dedicated tool from Fred Miranda it is possible to isolate the subject from the rest.
Quoting Flybhx (Reply 11):
Don't know how this filter is used in the sharpening process.
Fiveholer
Sun Sep 03, 2006 11:02 pm
CRTL-J, Filter/Other/Highpass, 0.3, set layer to "Linear Light", adjust layer opacity to your liking/erase jaggies with your favorite eraser settings if necessary, flatten layers. I made an action that does this for you up to the point where you adjust opacity/erase jaggies.
Danny
[Edited 2006-09-03 16:04:03]
[Edited 2006-09-03 16:04:46]
Bring back Bethune!
coninpa
Sun Sep 03, 2006 11:59 pm
There are no settings which work all the time. So many factors can intervene (paint schemes can provoque immediate jaggies, ligth, etc...). The camera and lenses used also induce different processing methods.
If jaggies are likely to appear, I usually start with CS2 Smart sharp (between 40 and 80 at 0,3) but on a mask (Process described by Jeff Miller) so as to "paint" the sharpness only where it is needed and to avoid jaggies
Next, to finish or reinforce sharpness where needed, I do an extra-sharoenning (on a mask) with USM 200-500 at 0.2 and paint again.
I often do several copies with different settings that I then compare. Then I go for a break and come back with rested eyes. Usually, I still find some corrections to make or sharpness to add.  Wink
Nevertheless, I still get rejections for oversharpened or soft...  Sad
One day maybe... Cool
Patrick De Coninck
Newark777
Mon Sep 04, 2006 1:26 am
Exactly, it is just a tool, as is PS, yet photography is much more than the tools used. You must have the eye for the subject, and know what you are looking for.
That is why setting a standard procedure in PS and saying it applies to most photos is ridiculous. Each photo must be dealt with on its own.
Quoting Aviopic (Reply 12):
That applies to just about anything in the physical world. Math is a part of everything.
Harry
