pavvyben
Is This Good Enough?
Fri Sep 22, 2006 7:05 am
Hello,
http://img98.imageshack.us/img98/2082/bcc1019mk7.jpg
Just trying to figure out the boundries on here still  Smile
Would this be good enough for the db?
Help appreciated
Ben
Fly747
RE: Is This Good Enough?
Fri Sep 22, 2006 7:10 am
Looks pretty good on my screen, maybe a tad "hot" on the nose but I think it's within limits. Good luck with it.
Ivan
globalpics
Fri Sep 22, 2006 7:11 am
Doesn't look too bad to me, no jaggies and centred correctly.It might be a tad dark in some areas if I'm being picky and also needing a tiny touch of contrast to just give it that lively kick.
By the way was it you and your father I briefly spoke to about executive B767?Just after the smart A320 landed?  Smile
engineergreg
Fri Sep 22, 2006 7:14 am
Great photo!
You may want to sharpen the landing gear areas, they apear a bit soft on my screen, but I could be wrong about that.
Anyway, I beilieve you have a decent chance at it.
Good luck!
pavvyben
Fri Sep 22, 2006 7:17 am
Hi guys,
Thanks for that, ill add a little contrast
Quoting Globalpics (Reply 2):
Yep it was  Smile First visit to LTN and a pretty good one at that.
Ben
Psych
Fri Sep 22, 2006 7:26 am
Hi Ben.
This is a nice shot - I do like those where the sunlight is able to illuminate the inside of the engines. I think there are small issues:
I think the sharpening could be slightly more, and I wonder if you have slightly overdone the editing for the levels - the nose looks slightly 'overcooked', and the lower fuselage looks a bit too light. You haven't used the dreaded shadow/highlight tool have you? If you look at the edge of the fuselage just under the engine something doesn't look quite right.
This could be enough to cause the photo problems in the screening process.
Cheers.
Paul
bubbles
Crew
Fri Sep 22, 2006 7:34 am
Quoting Psych (Reply 5):
Very nice shot, indeed!  Smile And I agree with Paul. I feel this photo looks a little bit soft. Giving slightly more sharpening may help or just use 'sharpen tool' to selectively sharpen some parts.
_Hongyin_  wave
