Avro85
Some Help Needed To Improve The Quality
Tue Sep 26, 2006 11:46 pm
Can someone point me out how I could improve the quality of this shot ? IT was rejected for quality ?
http://www.airliners.net/addphotos/r...ections/big/20060926_LN-RCT_01.jpg
Thanks all
Chris
 wave
lasham
Crew
RE: Some Help Needed To Improve The Quality
Wed Sep 27, 2006 12:01 am
Quoting Avro85 (Thread starter):
First time I have seen this shot. Looks like the front of the aircraft is blurry/soft. One extra note is the crop is a bit odd.
Tony
No sun no fun
bubbles
Crew
Wed Sep 27, 2006 12:03 am
Hi Chris
I think the quality rejection may come from the fact that the image looks grainy (especially the sky), and the plane appears to be soft somewhat. I know there is only a silhouette of the plane, but the edge of it gives me an impression that it is slightly soft.
The problem of being soft is easy to fix. But the grainy sky might not be easy.
Anyway, it is still a lovely sunset shot.  Smile
_Hongyin_
Avro85
Wed Sep 27, 2006 12:14 am
Allright thanks for the comments so far. I'll try to improve the picture.
Quoting Lasham (Reply 1):
Could you explain why you think the crop is odd ? Could it warrant a motiv rejection?
Chris
diezel
Wed Sep 27, 2006 12:26 am
Quoting Bubbles (Reply 2):
I'm not sure of that. I think the grain is in this case easy to fix and the softness rather tricky to fix.
I am almost afraid to name the N-word in this forum but in this case it would be a good idea to get Neatimage out of the (locked) safe. It will reduce that grain to zero without doing a lot of harm to the rest of the image. That is because the grainy area is isolated in the left upper corner and can be sampled by Neatimage very well so it can adjust to that specific area and do its job.
When fixing the softness, be careful not to introduce halo's as you are working with pretty strong contrast.
I personally would crop a lot tighter, with the sun in the upper right corner and the wing tips almost touching the left and right edge of the picture. But I guess that is just a matter of taste.
Roel.
Never be afraid of what you like. (Miles Davis)
ptrjong
Wed Sep 27, 2006 12:50 am
Quoting Avro85 (Reply 3):
I think the aircraft is too high in the frame considering that the dark bottom isn't of interest. I'm not sure if I'd crop tightly around the wingtips - that does nothing for the quality, too - but I would make the space at the left and right more or less equal. Currently, the space at the left is much wider.
This crop didn't strike me as odd immediately but I do think it will look a lot better with the aircraft lower and horizontally centered in the frame.
Peter Smile
lasham
Crew
Wed Sep 27, 2006 12:56 am
Might get a distance reject.
A crop will get rid of the nasty dark left side of the shot
Tony
No sun no fun
Avro85
Wed Sep 27, 2006 12:58 am
Thanks for the tips Peter.
I can put the aircraft lower in the frame that's no issue. But for the horizontal centering I had a motivation to keep space on the left as well.
In fact I wanted to show the old airport building of Brussels on the photo as well since the silhouette is nicely visible....
Will try several crops
Chris
EDIT: Thanks for the very usueful tip Tony  Smile
[Edited 2006-09-26 17:58:42]
Avsfan
Wed Sep 27, 2006 3:54 am
Chris,
I would say that you have a very awesome looking photo there. I would agree with everything that has already been said. If you can get all of the minor problems fixed, then you should have a good shot at getting it added to the database.
Lasham...I commend you for your responses in this thread. You are the only screener lately that I have seen provide inputs on how to correct problems with rejected photos. Maybe some of the other screeners and regulars to the forums will take note and look at changing their ways.
"Oh I have slipped the surly bonds of Earth...Put out my hand and touched the face of God"
Avro85
Wed Sep 27, 2006 6:11 am
Quoting Avsfan (Reply 8):
Thanks  goodvibes
Here's a link to the second edit. I tried to keep in mind the comments made i.e. I removed some noise in the sky, I tried to sharpen the plane a little bit more and to re-crop the picture.
All comments are welcome (bad or good  Wink )
http://www.airliners.net/addphotos/big/ready/LN-RCT_02.jpg
Chris
bottie
Wed Sep 27, 2006 7:41 am
I think the plane is a little soft, Chris
D L X
Wed Sep 27, 2006 11:47 am
You shot this in JPG mode didn't you? You also shot it with the "Sharp" developing preset, didn't you? Then you resized it down on your computer. Right? YOu might have even added a little USM before uploading it.
The problem is, you've overworked the image. I'd try this: if you're going to shoot in JPG mode, turn your development to VIVID or none. Don't use SHARP, because the D70's in-camera sharpening seems to oversharpen with the expectation that you're not going to crop and scale much. So, turn the in-camera sharpening off. Then do the sharpening in software AFTER you've resized it, fixed the colors, adjusted the levels, etc. That will dramatically improve your shots.
lasham
Crew
Wed Sep 27, 2006 4:21 pm
Quoting Avro85 (Reply 9):
Like the crop now, but the front of the aircraft is still soft. If it was blurry to start with then you will never get it looking good, even with loads of PS!
Tony
No sun no fun
Avro85
Fri Sep 29, 2006 2:17 am
Sorry for the late reply but I wasn't online yesterday...
Quoting D L X (Reply 11):
I'm using the EOS300D as a camera and not a Nikon....... Or are those settings also valid for Canon?
Quoting Lasham (Reply 12):
I'll try to see what I can do.. Otherwise it'll stay in my own collection...
Chris
D L X
Fri Sep 29, 2006 6:16 am
Quoting Avro85 (Reply 13):
Hmm...
I could have sworn that was you looking for D70 advice earlier. Sorry for the mistake.
Avro85
Sun Oct 01, 2006 12:22 am
Quoting D L X (Reply 14):
No problem  Wink
HI Tony, I finally ofund some time and tried a new edit. Is the softness now ok ?
http://www.airliners.net/addphotos/big/ready/LN-RCT_03.jpg
Best Regards
Chris
Avro85
Tue Oct 10, 2006 7:07 pm
I just wanted to thank everybody for the help in the forum as the picture just made it  Smile
Have a nice day
Chris
 wave
ptrjong
Tue Oct 10, 2006 7:13 pm
Photo © Avro
 Smile
Users browsing this forum: solro and 1 guest
