schreiner
Auto Level Function In PS
Thu Sep 28, 2006 4:14 am
Im messing a bit with PS CS 2, what do you guys think? Is the auto level function usefull? Sometimes I use the lightest and darkest point in the picture to get the levels right. But that takes a lot more time. Whats your guess? Thanks!
Soaring the internet...
JeffM
RE: Auto Level Function In PS
Thu Sep 28, 2006 4:23 am
Quoting Schreiner (Thread starter):
No. And that is not a guess.  Wink
Newark777
Thu Sep 28, 2006 4:32 am
Learn to use Levels manually, it is much more helpful.
Harry
Smalbany
Thu Sep 28, 2006 4:37 am
In my experience, the auto levels tool does not work well for aviation pictures. If the picture is pretty straight forward (ie sky as the background) I usually use levels and then adjust the levels based on the histogram by sliding the right and left sliders to remove the empty space from the histogram.
If it's a more complicated composition, I mark the darkest spot and the lightest spot and then use the curves tool to adjust.
Just my 2 cents,
Dan
schreiner
Thu Sep 28, 2006 5:00 am
Okay, Dan, thats also what I am doing sometimes, but what do you do with the middle marker in the histogram?
Schreiner
Smalbany
Thu Sep 28, 2006 5:16 am
Quoting Schreiner (Reply 4):
Usually I just leave it alone.
If the picture still looks too dark, I may move the middle one to the left a bit but it's only a small adjustment. It's easy to over-adjust that one.
schreiner
Thu Sep 28, 2006 5:37 am
And what if you have clipped sides on both sides?
Schreiner
diezel
Thu Sep 28, 2006 5:51 am
As a rule of thumb, to avoid messing too much with the levels afterwards in PS, it is good practise to have a look at the histogram on your camera when you are shooting. Most DSLRs support this feature. By looking at the histogram you will know instantly how to adjust your exposure. It is a lot easier than judging the exposure by the picture in the little LCD screen on the back of your camera.
Another usefull feature on many cameras is the "show the blown out whites by flashing". Using both features together will give you less work in PS.
Roel.
Never be afraid of what you like. (Miles Davis)
Newark777
Thu Sep 28, 2006 5:54 am
Quoting Schreiner (Reply 6):
Then your photo has too much contrast and you should lower it. This usually means that the blacks are pure black and the whites have been blown out, and is not necessarily fixable.
Harry
