locsta
Opinions On This Single-engine Shot
Thu Oct 05, 2006 2:10 am
http://myaviation.net/?pid=00859717
I realize that the upper wings edges are a bit soft, but there is a cool lighting effect that makes the tail section look transparent.
I don't know if/when I will get a chance to re-shoot. There is not a pic of this plane in the DB (that I could find), so is it worth uploading?
p.s. Would someone mind checking the info I supplied....is it correct?
Thanks for the feedback!
Kevin
Missed 4 chasing 1
eadster
RE: Opinions On This Single-engine Shot
Thu Oct 05, 2006 5:57 am
Not sure on the info. Is there a site that you can visit to check serials or construction numbers? That would be the best way of checking the info.
Photo looks fine here on my shitty notebook screen. Nice capture on the tail. It does actually look like its transparent!
jogales
Thu Oct 05, 2006 7:02 am
There is some vignetting, it's a bit grainy and there seems to be a light colored border around both sides and the top of the image. I'm afraid it would get rejected for quality and border  no
The reflection on the tail really does make it look transparent though!
oly720man
Thu Oct 05, 2006 7:37 am
http://registry.faa.gov/aircraftinqu...t=30143&cmndfind.x=15&cmndfind.y=5
Serial Number 5540
Type Registration Corporation
Manufacturer Name WACO
Certificate Issue Date 08/20/2001
Model UPF-7
Status Valid
Type Aircraft Fixed Wing Single-Engine
Type Engine Reciprocating
Pending Number Change None
Dealer No
Date Change Authorized None
Mode S Code 50623011
MFR Year 1941
Fractional Owner NO
