flugnord
Will I Make It?
Tue Oct 31, 2006 6:54 am
http://www.airliners.net/addphotos/big/ready/IMG_5474tf-fts9okt.jpg
I like that one because the plane is bright when the clouts are dark.
http://www.airliners.net/addphotos/big/ready/IMG_6567tf-ejg28okt1.jpg
That's cool.
Although this question might be annoying to some i am hoping that some other can pre screen it for me.
9V
RE: Will I Make It?
Tue Oct 31, 2006 7:01 am
Softness and grain on both of them I'm afraid. If they are both in the queue then I suggest you take them out and avoid both being rejected.  Smile
JeffM
RE: Will I Make It?
Tue Oct 31, 2006 7:05 am
Quoting Flugnord (Thread starter):
First might if it gets fixed. Second one won't.
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 7:08 am
Quoting 9V (Reply 1):
Where is the softness??? plese tell me, I'm sick and tired of being rejected.
aero145
RE: Will I Make It?
Tue Oct 31, 2006 7:28 am
Nr 2, too dark and grainy.
Nr 1, grainy and soft., and I can see a tiny amount of jaggies caused by oversharpening blurriness. Washed out feeling among in shadow under wing.
Aero145
Quoting Flugnord (Reply 3):
By taking a lot of time editing your photos, looking at photogs with many new photos in the DB, and make them as good as possible, you won't get so many rejections. Take a look at me... I uploaded 15 last Saturday. 13 of the photos made it last night, and I took a lot of time for one image. They may not be the best, but still better than they were from the orginal. If you want I can take a look at the FTS photo and maybe fix it if the orginal will be IMO good enough.
[Edited 2006-10-30 23:33:08]
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 7:32 am
Quoting Aero145 (Reply 4):
Is this one sharp enough?
no.
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 7:34 am
If you want I can take a llook at the FTS photo and maybe fix it if the orginall will be IMO good enough.
What does IMO mean??? And by the way there is only one L in look Big grin
aero145
RE: Will I Make It?
Tue Oct 31, 2006 7:38 am
Quoting Flugnord (Reply 6):
In My Opinion
Sorry, noticed that just a few seconds after I posted.  stirthepot
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 7:42 am
Hey I'll send you the original pic.
aero145
RE: Will I Make It?
Tue Oct 31, 2006 8:08 am
You used ISO 200, f/11, 1/640th.
I'd use ISO 100, +1/3 exposure, f/8, Av (or M if you know how to use it).
Not great, not great photo either, at least I M O
EDIT: Forgot; why do you say "Will I Make It" instead of "Will They/It Make It?"?
You're not making your way into the DB, it's the photos taken by you.  Smile
[Edited 2006-10-31 00:19:32]
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 8:20 am
Quoting Aero145 (Reply 9):
I always use M, thoug I'm not a genius Smile
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 8:22 am
Aero, Do you mind if I upload your edit?
eadster
RE: Will I Make It?
Tue Oct 31, 2006 8:28 am
I wouldn't upload that edit - its still grainy in dark areas.
Not overly true. The more time some take, the more the pic gets screwed up. I find and it varies with different people, that if a pic takes 10 - 20 mins to edit, then why bother? If it does not look right after a crop, level, sharpen, colour check, histogram check, and a dust spot check, then its not going to star. All that should take a few mins.
[Edited 2006-10-31 00:30:17]
flugnord
RE: Will I Make It?
Tue Oct 31, 2006 8:35 am
Well can some of you take a look at this list A Biiiiiiig Will I Make It Question. (by Flugnord Oct 29 2006 in Aviation Photography)
An tell me wits one to upload next??
eadster
RE: Will I Make It?
Tue Oct 31, 2006 9:58 am
Ok I've had a look at the ones in the other discussion.
They all have their own issues. Some are soft, some are blurry, but I still notice that many have alot of grain or image noise on them. As mentioned try with a lower ISO to see if this fixes the noise issues. Also maybe try a lower shutter speed, remembering to adjust other settings to match. The grain seems to be a bit of an issue so once that is cleared up, you may have a better chance. Depending on what the histograms say on the originals, maybe some exposure compensation may help too.
So I would forget about the other pics on the other discussion for the moment. Go and get some other shots on a nice fine day (hopefully not to rare in your location) for practise and see how they come out before getting too ahead of yourself.
aero145
RE: Will I Make It?
Tue Oct 31, 2006 4:32 pm
Quoting Eadster (Reply 12):
Not overly true.
Well, actually right.
You should know that I have bad experience with noise reduction in PS9  Smile
Users browsing this forum: Baidu [Spider] and 1 guest
