A388
Canon EOS350D Not Always Working, Need Help!
Thu Nov 02, 2006 11:59 pm
To all,
I have been shooting some photos at the airport as well as with my friends and my EOS350D Rebel XT at some points stopped snapping photos. The camera does focus and everything appears to work but when I press the button to take the photo the camera doesn't react or make the photo. After several clicking attempts it works again but how come it does not work at the time I want to make the photos? I hear the camera beep before pressing the button but the camera doesn't make the photo after pressing the button. Is this a familiar problem with the EOS350D Rebel XT? What causes this error? Is it easy fixable or will it just stop doing this after a while? Everything seems fine with the camera but it just doesn't make the photos sometimes which is not good.
A388
flugnord
RE: Canon EOS350D Not Always Working, Need Help!
Fri Nov 03, 2006 12:26 am
have you checked if the timer is on???
flugnord
Fri Nov 03, 2006 12:33 am
http://www.airliners.net/uf/536909426/1162481433MBArwY.jpg
You push the button that has red around until it becomes like the other thing that has red around.
It realy sounds like this is your problem.
JakTrax
Fri Nov 03, 2006 12:58 am
I have on occasion accidently pressed the timer button, which until pressed again will unfortunately cause you problems, however in this instance I doubt this is the case.
In certain conditions, usually cold weather, the battery and/or battery compartment can experience problems, usually resulting in a blank LCD (except for the little battery symbol which flashes indicating battery empty) and no response when the shutter release is pressed. On occasions, the LCD screen can even appear entirely blank and the camera won't function at all.
I sometimes experience the latter and although it's a pain if it suddenly happens when something tasty taxies by, it can be easily and quickly remedied by removing the battery entirely and then replacing it.
Unfortunately, I think it's something we'll just have to put up with - possibly a software error. Luckily it seldom happens.
Karl
jorge1812
Fri Nov 03, 2006 2:28 am
Quoting A388 (Thread starter):
A common but not to be solved problem with this cam. No usage error by the photog. Happened only few times to me. In a very good German forum I read taking out the battery or simply pushing the preview button helps for the moment. Switchig on and off doen't help in this case.
Also updating the firmware can help you in some cases.
Georg
aero145
Fri Nov 03, 2006 5:55 am
It has happened to my camera (not 350D) also... it did stop happening after I removed the battery and re-inserted it... Haven't seen it on my net myself though.
A388
Fri Nov 03, 2006 6:06 am
Hmmmm thanks for all the tips. I did see the same thing on my LCD screen as circled in red by Flugnord. I also removed and re-inserted the battery so hopefully the problem is solved. It just caught me by surprise as the camera did work afterwards, even though it sometimes made two shots when I pressed the button which is also strange. I will wait and see if this happens again so I can bring it back to the photo store. Thanks for all the tips and replies and please do post more info if you have it.
A388
flugnord
Fri Nov 03, 2006 10:08 am
Quoting A388 (Reply 6):
Then you must of pushed the button as shown above in read once to many, but that's ok.
A388
Fri Nov 03, 2006 11:56 am
But how come the camera works normally and at other times it doesn't? If I had pressed a button that results in the camera not doing what I want it to do, shouldn't the camera be doing this constantly instead of occasionally?
A388
rufruf
Fri Nov 03, 2006 6:05 pm
Ahhh the digital age. Think about what your camera is doing. I t has to focus , move mechanical things, to focus and then snap the picture . Try it 10 times in a row.
What ever happened to 35 mm.
I suggust buying a Nikon ( top of the line digital ) Mine you I am a Nikon person. Anyways your camera can't keep up with what you want it to do. Kinda like computers.
You can only go so fast with what you got ( camera ) and computers
JakTrax
Fri Nov 03, 2006 10:16 pm
Quoting A388 (Reply 8):
Not really. As I mentioned, I occasionally (and purely accidently) press the timer button, but it is very rare I do so. If the problem isn't the timer, it will definately be the battery.
Quoting Rufruf (Reply 9):
Well that's a really good remedy! Stick with your Canon, Nikons have problems too! Besides, Canon lenses tend to be better.
Karl
Alibo5NGN
Fri Nov 03, 2006 10:44 pm
You may also want to check your lens. Some lens like Sigma have a lock switch. If you do not push the button to lock position and the lens loosens, you will not be able to take shots.
It takes knowledge to make a career. It takes wisdom to live a life.
JGPH1A
Sat Nov 04, 2006 9:58 am
Quoting Alibo5NGN (Reply 11):
Ah - I have an old Sigma lens that I was using on my XT and the same thing would happen - it wouldn't shoot, came up with an error message on the screen. I stopped using the lens, my other Canon lenses work fine.
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
A388
Sun Nov 05, 2006 10:32 am
Hey thanks for the input everybody. I went to the airport for some aircraft photography and the camera worked fine. I only had one incident where my lense had trouble focussing on a stationary aircraft which I never encountered. I will keep an eye on my lense (Canon EF90-300mm 1:4.5-5.6 USM) and my camera in case similar incidents occur. If so I will let you know for more opinions before taking it back to the store again. The thing is that it will take two months to fix in case I bring it back because the camera will be sent to the U.S. (Florida most likely) as these type of cameras cannot be fixed here on the island. Very irritating but I have no other choice unfortunately.....
A388
viv
Sun Nov 05, 2006 7:59 pm
Now that's excellent advice!
JakTrax
Sun Nov 05, 2006 10:13 pm
Quoting Viv (Reply 14):
Last time I checked, neither manufacturer made better cameras than the other. It's called personal preference, and my personal preference for aviation is Canon. Look at your local airport or at an airshow and see how many people are using the grey Canon L lenses. They can't all be wrong now, can they.....?
Karl
viv
Mon Nov 06, 2006 9:31 pm
Quoting JakTrax (Reply 15):
Quite possibly ....  Smile
rufruf
Tue Nov 07, 2006 2:03 pm
I have to say that in my travel's around the world it is actually against the law to photograph a plane from a plane ( Try it in Bangkok ) . Be careful cause they will take your equipment. All photos taken at airports are contraband.
Same same at Tripoli, Praque,Viena , Kathmandu ,.......
jorge1812
Tue Nov 07, 2006 8:10 pm
Quoting Rufruf (Reply 17):
Wrong thread?
Georg
AviatorG
Sun Nov 12, 2006 1:39 pm
Jus an option..
When I first got my camera, I used to forget that I set the automatic shut-off feature to one minute. Left me boggled that nothing happened when I pressed the shutter in. (Just for the first few days) Almost lost a few good shots had I not quickly reset the power. Doesn't sound like this is the case with your situation though.. Have you tried contacting Canon at all? Never heard of anything like it.  old
rufruf
Sun Nov 12, 2006 7:14 pm
To Jorge1812,
Probaly
jorge1812
Mon Nov 13, 2006 1:22 am
Quoting AviatorG (Reply 19):
My 350D reacts within parts of a second when pressing the shutter after it turned off after 3 minutes.
Georg
A388
Mon Nov 13, 2006 9:08 am
Hey everybody,
Thanks again for all the replies and advice. My camera is working properly again. So I guess I did press the timer butron accidentally. My other camera (EOS300D) is under repair now to be used as back up. This camera just stopped working back in January. I first only worked when using it fully manually after a while it didn't work at all.
A388
flugnord
Mon Nov 13, 2006 4:58 pm
Quoting A388 (Reply 22):
So I was correct?
A388
Tue Nov 14, 2006 8:21 am
Quoting Flugnord (Reply 23):
So I was correct?
Well, it appears so unless I will have the same problem more often which I hope will not happen.
A388
JakTrax
Tue Nov 14, 2006 1:34 pm
Unfortunately at some point you will come across the problem I described towards the beginning of the thread - unless you're extremely lucky!
Well if it does happen and you do encounter the battery problem, at least you'll be well prepared for it!
Karl
Users browsing this forum: AlexC and 1 guest
