Brett
Critique Before Uploading
Sun Nov 12, 2006 12:45 pm
Hi guys, just wanted a critique on these before I try to upload. Be critical but also give me clue as to "how" I can change/correct the problems.
http://www.airliners.net/uf/view.fil...9581&filename=1163302816ql6Zsd.jpg
http://www.airliners.net/uf/view.fil...9581&filename=1163302462gBQBWo.jpg
[Edited 2006-11-12 04:46:39]
QantasA332
RE: Critique Before Uploading
Sun Nov 12, 2006 1:09 pm
Hi Brett,
Unfortunately, neither photo will make it.
The DJ shot is backlit, soft, and grainy, and it appears to have a blue-ish colour cast. While most of the problems could be fixed with careful editing, the backlighting remains a problem. The simple solution is to reshoot with the sun positioned correctly.
As for the FedEx shot, the overall quality isn't the best, with softness in some places and jaggies in others. Also, the sky is quite grainy (again, preventable with selective sharpening) and it seems to have a greenish colour cast.
edoca
Sun Nov 12, 2006 1:13 pm
Hi Brett - welcome to the forum... Both look a bit soft and grainy to me. Did you scan these or do they come from a digital camera?
The Fedex is also slightly overexposed (which causes a loss of detail in the white sections). You'd see plenty of examples in the database of similar pictures that are just much sharper, and that happens to set the standard...
Not very helpful but anyway...
