LIPH
Your Next Step In Aviation Photography
Fri Nov 17, 2006 12:55 am
Ok, we all have some pics in the DB and this is just a big goal itslef for most of us. But which is your next challenge in aviation photography ? A cockpit shot ? A shot made with the "panning" tecnique ? A night shot ?
Life sucks. Then you die. Live fast, die young.
linco22
RE: Your Next Step In Aviation Photography
Fri Nov 17, 2006 12:58 am
Well my next step is in photography as a whole. Well its an idea. Its to build a good portfolio for myself and produce my own website. But heck, I don't have much of a clue how to do either  Confused
Colin  Smile
Rotate
Fri Nov 17, 2006 1:07 am
I ve got different things on my radar for the next time. Some are places I want to visit, some are different style of photography.
Places:
a) AYT during summer, the IL86 headquarter of the World. (Pretty challenging as Avphotography is not so popular in turkey ...)
b) Machynlleth Loop area.
c) INN and SZG this winterseason.
Technic:
a) A2G photography at a place like LAX or so.
b) A decent long exposure nightshot of an aircraft taking off on the 32 or 34 @ ZRH.
Robin
ABC
aero145
Fri Nov 17, 2006 1:09 am
Mine is to get a good panning shot using my non-stabilised telelens. My bests are:
300mm, 1/100th, IS
200mm, 1/100th, non-IS
My goal is either 1/50th or lower, non-IS, 200mm
or
1/30th or maybe lower, IS, 200mm+
David  Silly
TransIsland
Fri Nov 17, 2006 1:23 am
My goal is to stick to not smoking... I've quit 3 1/2 weeks ago.
What this has to do with aviation photography: the money saved is going straight into my new camera fund.
Also, it may prevent me from burning my arm again while holding the camera in front of my face with a burning fag hanging out of the corner of my mouth.
I'm an aviation expert. I have Sky Juice for breakfast.
JRadier
Fri Nov 17, 2006 1:41 am
Quoting Rotate (Reply 2):
when are you going to INN? AirKas1 and me will be there 5-8th of Jan.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
NicolasRubio
Fri Nov 17, 2006 2:09 am
Well, my main goal is to get my first DSLR... Then a top of the day and my website...
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
jetcrazy
Fri Nov 17, 2006 2:57 am
I would like to be able to make high quality and interesting photos at bad weather conditions such as rain, dust fog and grey sky. These are the weather conditions at my home area for the most time so I try and try and try....
Jens
bmibaby737
Fri Nov 17, 2006 4:04 am
I'm aiming to get more artisitic (That, for myself and not aimed at Airliners.net). Shots I have in mind are those at sunset, and paticulary sunrise with low fog/mist.
I'm wanting to get far more interesting and more 'wow' shots, so thats my aim for Winter 2006/2007. Weather I get frozen or not, I won't care as long as I get some results that *I'm* pleased with.
Photo © Florian Trojer - AirTeamImages
Photo © Sven Hagström
Bmi!
ANITIX87
Fri Nov 17, 2006 4:35 am
Equipment:
Zuiko Digital 50-200mm f2.8-3.5
Zuiko Digital 1.4x converter
The above combination will give me a lens that is a 140-560, adding 260mm to my present maximum.
Shots:
I really want to go spotting at EWR to get some widebodies. I don't get to go often, and here at ABE there's rarely anything really interesting, unless US sends a special-scheme aircraft, or if there's a diversion.
TIS
Lanas
Fri Nov 17, 2006 4:45 am
Quoting NicolasRubio (Reply 6):
Same goal here as well.  thumbsup
I usually borrow a DSLR from my girlfriend´s brother, so next time I get it I want to try some sunset shots in AEP (a very humble goal, but it´s a good start).  ashamed
Cheers!
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
soon7x7
Fri Nov 17, 2006 5:09 am
Build a client base, make photomoney and pay off all this equipment...
NSMike
Fri Nov 17, 2006 5:16 am
I'd really like a chance to do some air-to-air shots. That's my goal for next year.
Pearl Snares, Taye Drums, Sabian Cymbals, Remo Heads, Los Cabos Sticks
Ander
Fri Nov 17, 2006 5:48 am
Quoting Aero145 (Reply 3):
or
David,
let me suggest you use a good and sturdy tripod if you want to get that slow.
Good luck,  Wink
Ander
Born to tri.
INNflight
Fri Nov 17, 2006 6:13 am
Panning with at least 1 sec exposure at night  Smile Working hard already.
Quoting Soon7x7 (Reply 11):
Sounds foolproof and easy, can I join?  duck
Jet Visuals
QantasA332
Fri Nov 17, 2006 6:16 am
Quoting Ander (Reply 13):
David,
Tripod for 1/30th?! No way! Handheld is more challenging and ultimately more rewarding when you get nice results! I would only consider use of a tripod below 1/10th... Big grin
aero145
Fri Nov 17, 2006 6:19 am
David,
Hmm, I'm talking about panning, not static...  confused
timdegroot
Fri Nov 17, 2006 6:41 am
Quoting Aero145 (Reply 16):
Tripod heads can usually pan too David
Tim
Alderman Exit
eadster
Fri Nov 17, 2006 7:08 am
For me, a top of the day shot - Only ever been as high as 3.
But more importantly I'd love to have the opportunity of doing some Air 2 Air of something like a 737 or bigger of course. I've done heaps of small aircraft but would like to try something bigger and faster.
Ander
Fri Nov 17, 2006 7:17 am
Yes, David,
me too  Big grin
Ander
Born to tri.
Ander
Fri Nov 17, 2006 7:19 am
Quoting QantasA332 (Reply 15):
If you are only looking for a challenge, then it's ok.
If you're looking to get a good shot, then you better use agood tripod.
Other than that it is a matter of luck.
Ander
Born to tri.
aero145
Fri Nov 17, 2006 7:57 am
Quoting TimdeGroot (Reply 17):
Tripod heads can, I know, but I haven't been lucky with a tripod (the head is fixed), and its head is a bad one. When using the 70-200 f/4L with the tripod mount ring, the handle has to be faced forward to be able to put the camera on with the grip. It's a real pain in the neck to remove the E1 and grip only to get the handle in the back. I guess I'll be panning on little higher speed in hotter weather, shaky hands is a no-no when panning, IMO, and probably IOO too.
Rotate
Fri Nov 17, 2006 7:58 am
Quoting INNflight (Reply 14):
Panning with at least 1 sec exposure at night Working hard already.
Flo, thats nearly ( blockhead  ) impossibel. If you get it right .... , let me know! If so , I am 100% sure u want get it into the DB  devil .
Quoting Ander (Reply 20):
Ander
I asume you are not talking static. What does the tripod give u? A more "stabalized" vertical movement .... , so what? I fyou look for panning - get rid of the 1 or 3 -pod ... , it does NOT help you.
Robin
ABC
Ander
Fri Nov 17, 2006 8:23 am
Quoting Rotate (Reply 22):
Yes, of course. And it will also get rid of some inevitable shake of your hands.
And it will let you shoot much longer. I've done a few panning sessions and after a while a long lens will droop unless you have big arms.
If you don´t like it don't use it, but it will deffinitely help you get more good shots.
Ander
Born to tri.
Rotate
Fri Nov 17, 2006 8:57 am
Quoting JRadier (Reply 5):
Dont know yet. I ve got a spare weekend in FEB. I really not spontanious as I have my small family ... , might be that I take a fast 2 hrs drive to INN from ZRH with my car, if weather is good on a saturday ...
Robin
ABC
AdamWright
Fri Nov 17, 2006 12:45 pm
Shooting purely for monetary gain. NO more BS trips just for pictures
scottieprecord
Fri Nov 17, 2006 1:47 pm
GOALS!
-Shoot more at other airports across the state... 80 of my 98 shots are from SAT
-Try to work out a little something with the SAT security. haha
-Really start to learn all the spotting at AUS (I'll be attending UT-Austin next fall... Hook 'em Horns!)
-Get some beautiful night shots at SAT... IAH spotters have been pouring out night gems for years now!
-And mayyybe a few trips around the country this year.. (I'm thinking PHX, maybe LAX, ATL, a few others)
As for panning, I've never gotten one on here...  Sad JPnet took two of mine: IS lens, handheld... 1/30sec; one was at 300mm, and one at 400mm. So I guess another goal would be to get a few panning shots here on Anet! haha
-Mike
INNflight
Fri Nov 17, 2006 3:15 pm
Flo, thats nearly ( ) impossibel. If you get it right .... , let me know!
You think? I've met a magazine staffer two years ago who had quite a few reasonable ones. Let me know when you're at INN.  Smile
I have a long and dark winter ahead I guess...  Embarrassment
Jet Visuals
IL76
Fri Nov 17, 2006 5:51 pm
I'd rather look at this question as "next step in photography". I think I have greater and more rewarding challenges for myself photographing other things than airplanes: people, sports, landscapes & animals for example.
Of course, in aviation I'd love to take air-to-air/ground shots, but that just isn't going to happen anytime soon. I don't travel around chasing airplanes on spotting trips, so I'm basically limited to AMS and the occasional airfield I come across on my holidays. Of course I thoroughly enjoy that, but at some point you get stuck in a rut. So... Non-aviation is where the challenges are for me, which also has a lot more diversity and possibilities.  Smile
Ed
timdegroot
Fri Nov 17, 2006 7:19 pm
I'm not going to take any big step, but there are some things I have on my to-do list.
Like Ed I think in non-aviation there is a lot to learn and it's there I'll be taking some steps ahead.
Tim
Alderman Exit
LHRSIMON
Fri Nov 17, 2006 10:07 pm
Aviation
1) Try to get a best of the day photo
2) Try to get a photographers choice photo
3) Upgrade from 20D to 1D Mk II
4) Try to tackle my backlog of photo's. (Impossible task as im only now doing Jun 05 !!!!! )
Non Aviation. (Sport)
Get a full page poster or front cover in a magazine. (Already done it many times for newspapers (back page) , but not yet in a magazine)
Improve income from freelance sports work that i currently now handle. To pay for the above camera upgrade.
Simon C
[Edited 2006-11-17 14:09:13]
Canon 1D Mk III,Canon 20D+17-40 L f4.0,70-200 L IS USM f2.8,400 L USM f5.6,135 mm L f2.0, 50 mm f1.8,1.4 x II extender
aviopic
Sat Nov 18, 2006 5:14 am
Fill my portfolio to 500 somewhere next year and quit.
After which I will concentrate my self on UFO photography......... a lot less busy so it seems Big grin
The truth lives in one’s mind, it doesn’t really exist
