Chukcha
Puzzling Rejection - Help Needed
Sun Nov 19, 2006 3:40 am
Hi all,
Normally, when I get a rejection, after having another careful look, I see what needs to be improved - even if the reason given is the unhelpful 'quality'. Yet for the first time a rejection sent me scratching my head - I just don't know what to fix. If it's the proverbial log in my own eye that I don't see, then maybe someone could point it out to me...
First time, this picture was rejected for 'quality':
http://www.airliners.net/procphotos/...ain?filename=20061111_ab03617n.jpg
I thought it could be because of some noise in the darker red and green areas, as well as the sky, so I fixed that.
Second time round it came back with 'quality, oversharpened':
http://www.airliners.net/procphotos/...ain?filename=20061117_ab03617o.jpg
'Oversharpened' - maybe, even thought I don't really see any obvious 'juggies'; yet I might tend to oversharpen a little since I've received a few rejections for 'soft' of pictures that didn't seem soft at all to me. But what else could be improved, I mean the 'quality' part?
Any help would be greatly appreciated...
JeffM
RE: Puzzling Rejection - Help Needed
Sun Nov 19, 2006 3:55 am
Both photos have a grainy, underexposed fell to them. Definitely oversharpened. WB looks off to me as well.
Chukcha
Sun Nov 19, 2006 4:41 am
Thanks for the reply, Jeff.
Quoting JeffM (Reply 1):
Here is the original shot, unprocesseed, just cropped and resized. Any suggestions what could be done to fix it, if anything?
http://photofile.ru/photo/chukcha63/1205058/39244798.jpg
I'm not arguing this part.
Exactly how, to what colour, what do you think? I mean the uploaded version, not the original one.
Chukcha
Sun Nov 19, 2006 9:36 am
It seems to me that the graininess in this case might be resulting from oversharpening as well...
Chukcha
Mon Nov 20, 2006 6:45 am
Looks like no one has anything else to say. I was hoping for some practical advice, but... Thanks anyway.
eadster
Mon Nov 20, 2006 7:06 am
Hey Andrew,
The first rejected shot was a little grainy yes. With the second one that seems to be better slightly, but the quality was still a little off.
The final one there I think is alot softer. The colours seem very washed out on the third, more-so than the other two. I can have a look at the original if you like, and see what I can make of it.
Let me know if you would still like some help on this one.
Martin.
Chukcha
Mon Nov 20, 2006 7:28 am
Hi, Martin,
The third one is the original, it only was rotated, cropped and resized. As you might see, the grain must have come from the sharpening. Concerning Jeff's comments above - do you also think it was underexposed? And what about WB in the edited versions? A lot of very yellow grass in SA this year, yes  Smile ...
eadster
Mon Nov 20, 2006 9:27 am
Quoting Chukcha (Reply 6):
I actually mean't the full sized original....
Anyway it is slightly underexposed yes. There is a strong yellow cast, but changing the levels will soon show you what looks better.
I've had a play with the shot here, but got nothing that I was impressed with. It could be a shot for the personal collection. However I would like to try an edit with a higher resolution before I write the shot off totally.
Chukcha
Mon Nov 20, 2006 10:52 am
Martin, does this one look any better to you?
http://photofile.ru/photo/chukcha63/1205058/39327796.jpg
Anyway, about the colourcast... Please don't get me wrong, I'm not trying to question your expertise , I'm still learning (always learning), so... How do you personally identify colourcast - with any software or just arbitrarily, by eyeballing? I mean I have some software that is supposed to correct colorcast, but quite often I'm not happy with the result. On the contrary, after processing the photo seems to acquire a new tinge. Okay, sometimes it is quite obvious, you look at the picture and you can tell that it is bluish or yellowish, but other times, like in the case of this picture, yes, it may seem yellowish, but there is a lot of yellow grass around, and even the white surfaces will reflect it. There is no such thing as pure white in real life anyway, it will always reflect the strong colours around. As for this particular picture, the lighting may seem a bit strange, but I think it is because right at that moment there was a bit of cloud over the sun, you might have seen yourself how sometimes the lighting may change dramatically when it happens...
Well, in the essence - does it mean that whether the picture has this slight colourcast or not is up to the eye of the screener or the editor, or is there any objective means to identify it?
[Edited 2006-11-20 02:53:23]
Users browsing this forum: PanAm_DC10 and 1 guest
