jetcrazy
Which One Is Centered?
Sat Nov 25, 2006 4:12 am
Hi !
I often ask myself what perfectly centered means....
is this centered, where the row of windows is exactly in the middle of the frame or....
...is this centered, where the top part of the plane has the same distance from the frame as the lowest part:
Thanks for your help.
Jens
ptrjong
RE: Which One Is Centered?
Sat Nov 25, 2006 4:26 am
Somewhere in the middle, but closer to version #1.
The tailfin is part of the aircraft, and should not be ignored. But it has limited 'weight' in the picture because of its small area. If the tailfin extended forward to the nose, making the aircraft shape a square, #2 would be OK.
Peter Smile
acontador
Sat Nov 25, 2006 5:52 am
For me the first is centered.
Just sit back, relax and have a glass of Merlot...enjoy your life!
ptrjong
Sat Nov 25, 2006 6:15 am
In this case, yes, the first one looks good. That's because it's nice to show a bit of the ground. If it was all sky it would be slightly high in the frame for me. Certainly, centering the fuselage/window line doesn't always work.
Garri767
Sat Nov 25, 2006 10:26 am
Id say the 1st is more centered then the 2nd. interesting shot since you can see part of the old titles behind the new ones.
Two wrongs may not make a right, but three lefts do!
NIKV69
Sat Nov 25, 2006 1:04 pm
1st one.
Just looking at the thumbnail the second looks too low.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
Users browsing this forum: Catalin81, Majestic-12 [Bot] and 1 guest
