singel09
Canon EOS 1d Mark II Or The Mark II N
Sat Nov 25, 2006 7:56 pm
All,
I am in doubt whether I should buy the Canon EOS 1D Mark II or the Canon EOS 1D Mark II N?
I can buy a Canon EOS 1D Mark II for Euro 1250, NEW, body only. Norwegian camera.
Seems like a very good price, but not sure if I should save more money and go for the Canon EOS 1D Mark II N.
Any advice ??
Mause
INNflight
RE: Canon EOS 1d Mark II Or The Mark II N
Sat Nov 25, 2006 9:23 pm
1250 euros for a NEW 1DmkII??? That's a hell of a deal, should be rather careful I guess. New one's here (acc. to a lowprice website) are around 3200 and up Big grin
Jet Visuals
Interpaul
Sat Nov 25, 2006 10:31 pm
Get the 1D2. I love my 1D2n, but the difference between them is not worth 2000 euros. If you can get a new one for 1250 euros (!!!), then don't hesitate to buy it....if you trust the seller.  Wink
Jan
tappan
Sun Nov 26, 2006 1:21 am
How about the Mark 11 N or the 5D ??
aero145
Sun Nov 26, 2006 1:42 am
Quoting Tappan (Reply 3):
Quoting Singel09 (Thread starter):
It's also two, not eleven.
or the 5D ??
Hasn't got in-built vertical grip, hasn't got weather sealing, hasn't got 1.3 crop, hasn't got 8.5 fps. (just 3 fps.).
JeffM
Sun Nov 26, 2006 1:54 am
Quoting Aero145 (Reply 4):
That is exactly why people buy it.
Fiveholer
Sun Nov 26, 2006 2:15 am
Heh, I am starting to wonder how things would be without the crop. Alas, I don't have 4K to spend on a camera body...not yet anyway. Big grin
Danny
Bring back Bethune!
AC773
Sun Nov 26, 2006 2:58 am
Quoting Fiveholer (Reply 6):
Well, the 5D is something like $2500. Just a thought.
Then again, every lens you use for aviation photography would suddenly become less adequate...
Better to be nouveau than never to have been riche at all.
aero145
Sun Nov 26, 2006 3:22 am
Quoting JeffM (Reply 5):
Yep, but wouldn't want your 100-400 to be 640mm on your 30D (or 520mm on the 1D) rather than 400mm on a 5D?
INNflight
Sun Nov 26, 2006 4:19 am
Yet once again David tells a pro (not the average A.net-pro, but the Mark Garfinkel-pro  ) about equipment, advantages and disadvantages. Yay, pleasure to read.
I guess Mark is well aware it's not 1D 11(eleven)N but rather 1D 11(two > II)N
Wanted to ask this in the thread for Sabena690 already, why would somebody be so obsessed by grips?
hasn't got 8.5 fps
Ever needed those for aviation? Must be a darn fast Cessna you shoot...
Cheers and a plesant Sat evening!
Florian
edit: spelling
[Edited 2006-11-25 20:22:23]
Jet Visuals
Interpaul
Sun Nov 26, 2006 4:26 am
Quoting INNflight (Reply 9):
hasn't got 8.5 fps
Ever needed those for aviation? Honestly?
I hope nobody buys a 1D only to take pictures of planes.  worried
Jan
locsta
Sun Nov 26, 2006 5:38 am
Quoting Aero145 (Reply 8):
Please correct me if I'm wrong, but can't you crop the full frame 5D image down to the 1.4 of the 30D and still have at least equal if not better quality?
5D is 12.8mp. I love it but, I also like wide angle shots.
Missed 4 chasing 1
aero145
Sun Nov 26, 2006 5:47 am
Quoting LOCsta (Reply 12):
I'm not going to make a single correction on what you said 'cause I'm not going to stand under still other bashing from the "pros".
But, from my experience with the 5D, you don't get the equal or better quality, you get less quality, but still very good! Close to the 20D/30D 1.6 croppes IMO.
Maybe someone else has got better quality by cropping from the 5D photos... that's of course very good.
Dehowie
Sun Nov 26, 2006 8:38 am
Comparinga 5D to a 1 series body is like comparing apples to oranges.
The 1 series is built like a tank,shoots at 8.5fps has a AF system that leaves every other camera i have ever seen except the Nikon F5 for dead.
1.3 crop is good with aviation but it shines when shooting stuff like motor car racing/boat racing at close range where the AI servo truely shines.
Little difference between the 1Dmk2 and the MK2n so if you can getr it at that price run to get it.
You will not regret it for a second.
Darren
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
Stealthz
Sun Nov 26, 2006 10:22 am
Quoting Aero145 (Reply 11):
You want to get the best, and shoot many frames to get something to browse through.
Ah, the machine gun approach to photography, on your 5fps camera if your shutter speed is 1/500 sec you will miss 99% of the action.
So 8.5FPS is better because at 1/500 sec you only miss 98.3% of the action!!
Understanding your subject, anticipating what is likely to happen counts for much more than FPS
The 5D & 30D, I believe(and I should research this perhaps) the actual pixel density on the sensor of the 5D is slightly less than the 30D so applying the equivalent crop factor to a 5D image will likely produce an inferior image, all other things being equal.
EDIT: I did do the research, cropping a 5D image down to give same field of view as a 30D image results in 5Mpixel image compared to the 8.2Mpixel from the 30D.
Having said that would I turn down a 5D? no way, but will likely keep saving for the ID mkII N
[Edited 2006-11-26 02:30:32]
JeffM
Sun Nov 26, 2006 11:40 am
How would you do that? My 100-400 is 100-400 on my10d and 30d.
Cropping the image is not the same as increasing the focal length.
res
Mon Nov 27, 2006 11:01 am
 eyebrow I'm in the same situation, trying to make a decision on a Mark II or Mark II N.
Other than the Mark II N being two years newer, how do the two cameras compare when it comes down to the sensor? One is 16.7mp (wow!) and one is "only" 8.2mp.... Is it noticeable? I know there's a point where anything more than a certain amount of mega pixels is not noticeable, but how about these cameras?
Appreciate any input.
Thanks!  wave  wave
FLY NAVY
aero145
Mon Nov 27, 2006 5:14 pm
Quoting JeffM (Reply 15):
Urgh, I forgot to put effectively there!  banghead
linco22
Mon Nov 27, 2006 6:02 pm
I've had the pleasure of trying the N. Its in a different league to 300/350/400/30/20/5D in terms of speed performance. All other points from above included.
You really don't need anything more than 300D for speed for aviation photography. Forward thinking is the key.
Colin
Interpaul
Mon Nov 27, 2006 7:08 pm
Quoting Res (Reply 16):
Thanks! wave wave
I think you're confusing something here. Both the Canon 1D Mk.II and the newer Canon 1D Mk.IIn have 8,2mp with a 1,3 crop factor. A new 1D2n is sold for around 3000 euros. The 1D Mk.IIn has a bigger 2,5" display and some additional features but both cameras produce the same image quality in my opinion.
The one with 16,7mp on fullframe is the 1Ds Mk.II. which costs around 6500 euros.
Jan
res
Tue Nov 28, 2006 12:28 am
Quoting Interpaul (Reply 19):
Yes, Thats what i meant - the 1Ds Mk II versus the 1Ds Mk II N
FLY NAVY
Interpaul
Tue Nov 28, 2006 2:09 am
Quoting Res (Reply 20):
1Ds Mk II N
But there is no 1Ds Mk.IIn.
Jan
res
Tue Nov 28, 2006 4:49 am
Right. I typed both too fast to notice the SMALL mistake.
Now....any feedback to my original question?
Quoting Interpaul (Reply 21):
Jan
FLY NAVY
chris78cpr
Tue Nov 28, 2006 5:22 am
I own the 1dmkii and have used it for 2 years now. I LOVE this camera, it's built like a tank, takes awesome photos, has amazing speed and is the perfect camera for what i shoot.
I have also used an N and to be honest the only thing i like about the N is the bigger LCD screen, but to be honest the amount i actually use the screen for i do not have any need for the bigger one. I only use the screen for checking histogram and sharpness.
Buy the 1dmkii original and use the saved money on new glass, or a monitor calibration tool or take your wife for dinner.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
jorge1812
Tue Nov 28, 2006 5:27 am
Quoting Chris78cpr (Reply 23):
Yes, but don't spent the whole money on that dinner.
Nice to read such words on Anet were most people seem to be married with their acceptance ratio these days.
Georg
[Edited 2006-11-27 21:29:11]
singel09
Wed Nov 29, 2006 3:21 am
Thanks for all the feedback. Seems the 1D MARK II is the one, dont care for bigger lcd. I considered the 5D, but that is slower then the Mark II, has less focus points, and 1:1 .. interesting for studio work, not in aviation!
I will check this price out, called the dude offering this. Camera's from Norway. I dont care as long as the menu is in English  Smile
I can see the bodies, so will check it out this week.
Will keep you posted
Mause
Honcircle
Wed Nov 29, 2006 3:29 am
I would take the 1dMKIIN . I have also one and when you are spotting and you start with 8,5 pics in the second it is so great. Take the N and you will be happy speed is more important in this category than quality, although the N has a super quality.
regards maximilian
INNflight
Wed Nov 29, 2006 4:20 am
Quoting Honcircle (Reply 26):
Would you mind posting some of your 8.5fpsN photos?  Smile Can't wait to feel the speed ( I only have 3.6 pics a second or something  Sad ) and would love to see yours. Quality is not important to me.
 Smile
Flo
Jet Visuals
tom3
Wed Nov 29, 2006 4:39 am
Nice that you own such a great camera for your age (13-15)  eyepopping   Yeah sure
Please show us some examples  Wink  spin
Tom
Tom Mousel - Lap
jorge1812
Wed Nov 29, 2006 5:01 am
Quoting Tom3 (Reply 28):
Well spot, reminds me of the 13-15 yr. old talking about his S500 Mercedes he owns and the ones his wife and kids were driving.
Maybe that isn't the correct age.
Honcircle
Sounds like he's flying in LH First Class FRA-SYD every second day.
Georg
INNflight
Wed Nov 29, 2006 6:09 am
Now we've got two that should blend in perfectly  bigthumbsup   duck
Jet Visuals
Stealthz
Wed Nov 29, 2006 6:30 am
Quoting INNflight (Reply 27):
Can't wait to feel the speed ( I only have 3.6 pics a second or something ) and would love to see yours.
I am with Flo, I would love to see what this 8.5FPS rate does for you, my humble 5FPS frustrates me so much I use single shot mode 90% of the time
aero145
Wed Nov 29, 2006 6:34 am
at
Yeh! I'm interested in seeing that 8.5 fps. too.
LHRSIMON
Wed Nov 29, 2006 8:41 pm
Im saving at the moment for a 1D Mk II N.... The 8.5 FPS is the main reason for me as i cover Ice Hockey. And you sure do need the speed , unlike in aviation where IMHO its not important.
Im also looking forward to being able to have AF on my 400 L F5.6 with the 1.4 extender. Something the 20D cannot offer.
One thing... On my 20D with grip i have a shutter button + selector wheel on the grip. This allows photo to be taken while i hold the camera to the vertical ,with these button still on my right finger. Do you have these still on the 1D MK II N.
Canon 1D Mk III,Canon 20D+17-40 L f4.0,70-200 L IS USM f2.8,400 L USM f5.6,135 mm L f2.0, 50 mm f1.8,1.4 x II extender
aero145
Wed Nov 29, 2006 8:50 pm
Hello Simon.
Sorry that I used a 1D II for this, but AFAIK 1D/1DII/1DIIn/1Ds/1DsII share the same body, so the selector wheel is there, and the buttons on the back:
http://www.dpreview.com/reviews/CanonEOS1DMkII/Images/allroundview.jpg
LHRSIMON
Wed Nov 29, 2006 9:03 pm
Thanks for that David.. The photos i found did not show what i needed. But the ones you supplied clearly show the buttons are where i need them.
Thanks again
Simon
 Smile
aero145
Wed Nov 29, 2006 9:16 pm
Quoting LHRSIMON (Reply 35):
My pleasure!
Very good! Now, you know.  Smile
David
Honcircle
Fri Dec 01, 2006 12:43 am
Quoting Jorge1812 (Reply 29):
Here is my 1DMKIIN
http://i61.photobucket.com/albums/h79/hon2/IMG_1704.jpg
http://i61.photobucket.com/albums/h79/hon2/IMG_1705.jpg
And for the other ones which kind of pics do you want. Of the 8,5 sec pics are 1 or 2 super and the other ones are deleted. But you have more chances to take the right moment pic.
Regards m
jorge1812
Fri Dec 01, 2006 12:56 am
And here's the pic of my Porsche (the red car in the background is my Ferrari)....just kidding.
Those pics tell nothing. But there's no way for you to tell us if it's really yours or not. So I believe you.
Can I ask how you can own such a camera on your age? It's just for personal interest. Do you have any aviation pics online somwhere?
Georg
aero145
Fri Dec 01, 2006 1:01 am
Quoting Jorge1812 (Reply 38):
Yes, and the Canon EF 28-300mm f/3.5-5.6L IS USM lens attached.
 Smile
David
LHRman
Or is it your mum or dads?
Thanks..
Dave
Always after the picture you can't get..
Honcircle
Fri Dec 01, 2006 2:02 am
look at my homepage
melichtenheld.funpic.de
there are some examples of my pics
regards m
jorge1812
Fri Dec 01, 2006 2:46 am
Quoting Honcircle (Reply 41):
So 13-15 isn't your real age????? If it is than working as freelance Press Photog isn't allowed, at least in Germany IIRC.
Georg
Honcircle
Fri Dec 01, 2006 3:55 am
I am from Austria and it is OK for me ok won't start a discussion about it.
Regards maximilian
INNflight
Fri Dec 01, 2006 4:18 am
IF you are the freelancer you claim to be you might update your website, 80% of your photos are non-existant  Smile
A bit of friendliness on the forums might be nice also...
Florian
Jet Visuals
Honcircle
Fri Dec 01, 2006 4:37 am
Yes sorry but this discussion was discussed to often in forums. the homepage is now updated and everybody is able to see the pics.
regards maximilian
tom3
Fri Dec 01, 2006 5:42 am
Can't see any real pics of aircrafts , just of the interior..
And in the section ''About me'' you say that you own only the Canon 350D*+18-55 and not the 1DMKIIN..
And your equipment list can't impress anyone..
Tom
Tom Mousel - Lap
Honcircle
Fri Dec 01, 2006 7:03 pm
Didn´t say that there are any pics of planes . I said that I started with an Eos 350 D. I don´t want to impress somebody , I don´t have to impress somebody.
But I do not think Singel09 is interested about me, his question was which camera he should buy.
@Singel09 I suggest you the 1DMKIIN you will have a lot of fun with it , the operation is quite difficult at first, but after 3 days you know how to do it and then it is so great.
Regards maximilian
manzoori
Fri Dec 01, 2006 8:50 pm
Bringing this topic back on track, Whilst I don't own either the 1DmkII or 1DmkIIN I have had the pleasure of using the 1DmkII briefly and was mightliy impressed.
The solidity & balance of the body felt very good to me, and the speed and accuracy of the AF was astonishing (compared to my elderly 10D). Sadly as it was a wedding I didn't get the opportunity to try the machine gun fire rate!  Wink
Rez
 Big grin
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
Honcircle
Fri Dec 01, 2006 9:04 pm
Yeah it sounds like a machine gun.
The Af is soooooo fast if you compare it with a 350D or so. It i great,
