andrewuber
Aerial Photo Shoot - What Should I Charge?
Mon Nov 27, 2006 12:14 pm
An airline has asked me to do a photo shoot of an upcoming even where they will have a TON of heavies on their ramp, and I'm trying to figure out what to charge them. Here's a LITTLE background info that will be necessary:
I am the "official" photographer for the airline, and I receive benefits for providing the photos.
I do charge them for prints, but it's usually a very modest fee, covering the expense of the print and the frames.
I will have to rent an airplane, and either take a pilot with me or use an instructor for an hour as I will be preoccupied with cameras and lenses.... I don't want to be on the news for losing control and crashing while trying to get a photo or two!!!
My question is - what should I charge them? Is there a normal "fee" for aerial photography? I was thinking about the a/c rental (probably around $100) and a fellow pilot (any volunteers???), plus a couple hours of my time...
I don't want to rip the airline a new one, but at the same time I want to be appropriately compensated.
Your thoughts and suggestions are appreciated! Thanks!
D r e w  wave
I'd rather shoot BAD_MOTIVE
JeffM
RE: Aerial Photo Shoot - What Should I Charge?
Mon Nov 27, 2006 1:02 pm
Quoting AndrewUber (Thread starter):
Why not give them a list of the things you need...plane, pilot, etc... and then quote them a price based on your going rate for the time, processing and prints? I'm sure the 'airline' has many contacts and can round up a plane and pilot.
andrewuber
Mon Nov 27, 2006 1:08 pm
Quoting JeffM (Reply 1):
Under "normal" conditions that would work - but the reason they turn to me is because I provide a complete service, and they don't have the time to deal with all the little details (especially now with their traffic tripling for the next month).
All they want is an e-mail with high res photos and an invoice attached.
Drew
QantasA332
Mon Nov 27, 2006 2:34 pm
I would start by simply adding up all of the material costs to you - aircraft hire, pilot (unless you employ a friend or someone else willing to fly free of charge...), prints, etc.
Then, based on the total time and effort you've put towards it, add a profit amount which you think adequately compensates you. Is the airline in question a major, or a relatively small operation? Depending, I would think that something around $200-800 profit would be reasonable.
Cheers, and good luck with it.
IngemarE
Mon Nov 27, 2006 6:04 pm
Drew,
I think that there are about as many "normal" fees for aerial-photography jobs, as there are aerial-photographers out there!
When I've done them, I applied sort of a "Robin Hood-payscale".
The old lady with the little cottage in the middle of nowhere didn't have to pay as much as the couple who wanted to have a picture taken of their mansion-ish estate. However, the old lady still had to cover for my expenses. In your case I'd say you're dealing with the other end of the pay-scale.  Wink
Other than that, make sure to get a hold of a driver that knows how to slow-flite (relativel) close to the ground,...."lest the earth will rise up and smite thee!"  eyepopping  As you mentioned,...you wouldn't want to end up on "the wrong side of the news". Right!?
Also make sure what type of insurances that might apply, since you are doing a commercial photo-job in an aircraft, and not just the random fly-around-shooting-at-everything deal. Things have probably changed since I was in the US back in '98-99, so make sure to cover your behind!!  Wink
FAR's might have changed as well, so I think your best pilot would probably be a CFI who also do some meat-bombing every now and then. (He knows the reg's and how to slow-flite!!  Wink )
In thrust I trust.
AviatorG
Mon Nov 27, 2006 10:59 pm
- Don't think that would be good, especially for the airline you represent  flamed
Quoting QantasA332 (Reply 3):
-  checkmark  Great suggestion. Its easy and very effective to work out costs this way. Also, you may want to consider planning a route around the airport (or location) you want the pilot to fly.Doing so may give you more time to shoot, rather than point to where you want to go after takeoff. Contacting the local ATC where you will be operating prior to the set date may also get you some 'special' airspace transition allowances, providing better angles and aerial views as a result.
jetav8r
Mon Nov 27, 2006 11:55 pm
Andrew,
I've owned an aerial photography business for a little while now. We charge $200 per hour in the air, with a one hour minimum. It is broken down into $100 for the airplane (which we own, so you may need to adjust the price), $50 for the pilot, and $50 for the photographer. We also charge a $50 processing fee if the customer wants anything done with the photos. Our average invoice is around $300 and most of that is profit. The only true overhead we have is the gas seeing as how we would have the plane and I would have the camera with or without the company. If I were you I would just try to make sure I made $50 per hour after all the expenses are paid.
Alex.
CalgaryBill
Tue Nov 28, 2006 7:43 am
I approach any photography "suppliers" as standard subcontractors. If it's something easy to arrange (such as booking an airplane) then tack 15% onto your cost when you invoice the client. For more complex "supplies" such as the pilot (who you will have to spend time with planning the shoot, etc) add 30%. Even though they are providing the service, you still have to account for the time you spend organizing all the work.
Quoting AviatorG (Reply 5):
This is very good advice. The only thing I'd do differently is meet with the pilot, plan the shoot, then have him/her contact ATC, airport authority etc to get special permission. As a pilot myself, I'd never bite if a photographer said "don't worry, I've got special permission for us..."  Smile
Quoting IngemarE (Reply 4):
I'm not sure which country you plan to shoot in, but in Canada it's illegal to fly lower than 1,000 feet over a built-up area. And unless you have special permission from ATC, you'll likely be restricted to 1,500 and above over the airport. At those altitudes slow flight in a small plane won't be necessary as things go by slowly even at 80 kts.
Preferences for a plane would include a C177 (Cardinal) or C210 as neither have struts to get in the way. But some of them have sealed windows and shooting through old plexiglass isn't fun...
B
BoeingOnFinal
Tue Nov 28, 2006 9:04 am
JetAv8r: That's gotta be one nice job, and a nice way to collect hours as well. A little OT, but I'm curious: Do you rent an aircraft from your local club, or do you own/lease?
Are there any legal issues with selling photographs taken from a rented plane without making some sort of an arrangement with the club first?
norwegianpilot.blogspot.com
jetav8r
Tue Nov 28, 2006 10:04 am
BoeingonFinal,
It is a great job. My partner in the business owns the airplane (a 172) we do the photos from. He also owns a flight school, but we rarley use those three airplanes for reasons I'll exlpain later. I also have an airplane that we can shoot out of if we need to, but the 172 works much better.
There is a huge insurance problem with using a rented airplane. Almost all schools have in their insurance policy that no airplane shall be used for commercial purposes outside of school business. So unless you actually partner up with the flight school you maybe in serious trouble if you bend the plane on an aerial photography flight.
Alex.
P.S. Pay the pilot if you take one along, even if it is a friend. It would not be very fair to keep all the money to yourself when he or she is provided a required service.
f4wso
Tue Nov 28, 2006 12:04 pm
Hope you have good weather and you let us know how it goes when you complete the project.
Gary
Cottage Grove, MN, USA
Seeking an honest week's pay for an honest day's work
SkyexRamper
Wed Dec 06, 2006 2:40 pm
Quoting JetAv8r (Reply 9):
The FBO/flight school I work for does photo flights ( cessna 172) for any photographer. The CFIs detach the support arm of the window so that the airflow holds the window in the upright position against the wing.
But for the subject matter at hand. Charge them for all cost associated with this photo shoot, the prints or digital files and 15-20% over for your commission.
Good Luck to all Skyway Pilots! It's been great working with you!
jetav8r
Wed Dec 06, 2006 11:01 pm
Quoting SkyexRamper (Reply 11):
That would not be outside of flight school business then.
Alex.
f4wso
Thu Dec 07, 2006 12:38 am
The airport I used to keep my Ercoupe tied down in Dayton would use their Cessna 150 for photo work by taking the door off. It was a Part 61 school so there was more latitude for doing sightseeing rides than a Part 141 shool would have. When I did my commercial pilot oral exam, there was much discussion about what could be done with the new license I was going for. Sightseeing and aerial photographers were accepted since it was not carrying persons or cargo from point A to B for hire. For the three aerial photography companies I worked for, we did not take non-employees aloft to do photography.
Gary
