robban75
How Is It Possible?
Wed Nov 29, 2006 8:58 pm
I got this photo rejected because it was over sharpened?
http://www.airliners.net/addphotos/r...ections/big/20061128_mirage2K1.jpg
Thing is, apart from adding a tiny bit of contrast, the only modification to the original is that it has been downsized. The original size is 3008X2000 and the format is JPG.
What to do?  Sad
//Robert
linco22
RE: How Is It Possible?
Wed Nov 29, 2006 9:06 pm
Robert,
Very nice image! To be honest i've never experienced major jaggies when re-sizing and NOT applying sharpening but I have heard that perhaps re-sizing in stages might help reduce this.
Good luck with it
Colin
flyingzacko
Wed Nov 29, 2006 9:35 pm
Quoting Robban75 (Thread starter):
What to do? Sad
Sounds to me like you might have the in-camera sharpening set too high. Check the camera settings and make sure to have the in-camera sharpening turned off, or set to 0.
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
ThierryD
Head Support
Wed Nov 29, 2006 9:37 pm
What to do?
If you didn't sharpen the shot you could still, after resizing, use a softening mask to eliminate the jaggies.
Here's a quick edit, though since I'm not at my "post-processing computer" I'm not 100% sure about the result:
http://www.airliners.net/addphotos/b...g/ready/20061128_mirage2K1edit.jpg
Thierry
"Go ahead...make my day"
jid
Wed Nov 29, 2006 11:06 pm
Down sizing an image will normally soften it just a touch. If your image has come out of the camera oversharp, as said above turn off your camera's sharpening process. One thing you can try in PS is when you re-size your image, set the Resample Image choice to Bicubic Smoother. This will not try and add any sharpening to the resizing process.
Good luck,
Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
jajo
Wed Nov 29, 2006 11:36 pm
Robert,
What program and method did you use to downsize the image? I have seen this kind of "over-sharpening" look on pictures which was resized using a bad image editor or wrong method of resizing.
"The Gimp" is an excellent image editor. Both open source and free of charge.
Kind regards,
Jacob
dbudd
Thu Nov 30, 2006 12:30 am
Thierry
Tell us newbies more about this 'softening mask'. Seperate layer and then what??
Dave
ThierryD
Head Support
Thu Nov 30, 2006 12:45 am
Quoting Dbudd (Reply 6):
Well, first you gotta create a duplicate layer which you'll then soften as much as required with the normal softening option (now the whole image is treated); you'll cover it with a mask layer (all softening disappears again) and then you take the brush tool and remove the mask (thus making the softening visible) where it is required.
After having treated all the required areas you merge the layers and you're done.
You can of course repeat the step as often as you want.
In addition the masking method works with about any tool, like sharpening, saturation, contrast, lighting, ...
That way you'll get the required changes only on those parts of the photo where you need them.  Smile
Thierry
linco22
Thu Nov 30, 2006 1:02 am
Quoting ThierryD (Reply 7):
mask
NOT available in Elements! I must save up for CS2 someday
garry
Thu Nov 30, 2006 2:29 am
Hi Colin - get yourself onto e bay you can pick a copy of cs2 up for £10. Also Elements 5 is either just out or coming out and it may have Masks built in? I believe they have updated the file browser to Adobe Bridge too which is the browser in CS2 and is excellent.
Garry
www.garryridsdale.com
ThierryD
Head Support
Thu Nov 30, 2006 2:49 am
Quoting Garry (Reply 9):
maybe the upgrade or the handbook but surely not a fully functional Full version of CS2! ...not even on ebay!
Thierry
Avsfan
Thu Nov 30, 2006 4:47 am
I have PSE 5.0 and it does not have the capability to make masks. An individual would have to use the different versions of PhotoShop.
"Oh I have slipped the surly bonds of Earth...Put out my hand and touched the face of God"
robban75
Fri Dec 01, 2006 7:40 pm
Thanks for the replies all!  Smile
Quoting Jajo (Reply 5):
Hi Jacob,
I usually downsize the images in photoshop, and sometimes in MS paint.
jajo
Fri Dec 01, 2006 11:56 pm
Quoting Robban75 (Reply 12):
No good idea!
That would explain the sharp edges on the photo, MS paint has a very bad resize feature.
/ Jacob
